Faulty memory slot on Tekram Slot 1 motherboard
  • Byte_76
    • Apr 2024
    • 44
    • Namibia
    I have a Tekram P6PRO-A5 Rev. 1.01 which has an issue with one of the memory slots and with the floppy port.
    When a memory module is installed into the slot which is closest to the north bridge, the board will beep and won't post. The same memory module works in the two remaining slots.
    Also, the floppy drive does not work regardless of bios settings.
    Please help me to identify the possible cause of the faulty memory slot and the floppy drive port as well.
    I have examined the board under my digital microscope and did not find any broken traces.
    I have a multimeter but I do not have an oscilloscope.
  • FriedFred
    • May 2024
    • 140
    It's possible that some of the pins or contact surfaces have become somewhat "blind" due to dust, oxidation, etc. Installing and removing the RAM a few times should make the surfaces electrically conductive again. If that doesn't solve the problem, you'll probably need to perform pin-by-pin comparison measurements between the three slots without the RAM installed to see if all three slots behave identically. So, measure pin by pin in diode mode. If two slots are identical, but a different reading is displayed for the slot in question, there may be a defect.
    • Byte_76
      • Apr 2024
      • 44
      • Namibia
      I have cleaned the board and the contacts thoroughly. Today I measured each pin in the slot and compared it to the slots below, with each pin giving me the same readings.
      There does not appear to be a disconnect or anything which is obviously faulty, yet the board simply beeps and won't post with a module in that slot, while it works just fine with the module moved to any of the other two remaining slots.
      • Roli
        Lenovo C440 CIH61S1 motherboard , wont post with 1 slot of memory
        by Roli
        Hello , i got this lenovo C440 , with moderboard CIH61S1 , the problem is that when i put 1 memory in slot 1 the system wont post , ocasionaly it works but most of the time it doesnt and when it works , it gives BSOD-s and freezez a lot , if i put memory in 2nd slot , the system will work fine , if 2 put 2 memories again system will crash /freeze /bsod / or it wont post .
        I tried changinc CPU , other memory .
        05-01-2025, 08:48 AM
        Where can I find a DD3 128000 type memory but 32 MGB in one module because this laptop has only one slot
        This Dell computer is a pain in the a** because of it only has one memory slot this computer only had 4 megabytes of memory and slower than shit I found a 8 megabyte memory module and it is better but still slow as shit the maximum is 32 megabytes of RAM but I was not able to find one I found some that are 16 megabytes but they are 1600/128000 type and I am not sure if this computer will work with this type of memory or not
        Dose anyone knows where I can find a 32 megabytes memory module for this computer because the battery still works fairly well still I would like to use it on my...
        07-07-2024, 02:34 PM
      • szepesif
        Lenovo Ideapad 3 15IIL05 working perfectly with onboard RAM but it doesn't start when I add a memory into the RAM slot
        by szepesif
        Hey guys!
        I don't know the solution to this problem, but this is definitely not unique and I would like to figure out the solution to fix these in the future.
        I have two identical Lenovo Ideapad 3 15IIL05 laptops with integrated 4GB DDR4 memory. Both work perfectly with that. BUT... if I add any extra memory to the single RAM slot, it never gives a picture. I thought the RAM slot pins would be the problem but no, all pins are solid (I checked them under the microscope). The RAM in the slot has 1.2V, so the voltage is present on the module. I flashed the latest BIOS, so
        04-19-2025, 10:18 PM
        Fujitsu CELSIUS H730 Mobile workstation H Specification for Upgrade or Repair
        This specification for the Fujitsu CELSIUS H730 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the H730 boardview and H730 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Fujitsu...
        09-06-2024, 05:27 AM
