Best tips for Weller WMRP?
  • jacobtc
    • Apr 2016
    • 283
    • Denmark
    I'm looking at getting some new tips for my Weller WMRP for micro soldering. I currently only own a 0.8mm conical tip, which leaves a lot to be desired when soldering pins etc. I'm probably going to get a bent chisel 0.8mm (RT5), for better access in crowded areas, but what else do people have as their favorites?
  • jacobtc
    • Apr 2016
    • 283
    • Denmark
    Re: Best tips for Weller WMRP?
    No one? Could also be for other soldering systems, its just the shape of the tip that would be interesting to know.
    • redwire
      • 3912
      In general, conical shaped tips are terrible. They are too thin to have decent heat transfer, they can't keep hot once touching the work unless you set the iron's temperature way high and even then it's a disaster.
      If you're soldering larger through-hole headers and such, use the biggest tip possible. WMRP is a micro-iron, I would not expect it to do everything.
      we talked about tips a lot here: https://www.badcaps.net/forum/showthread.php?t=67800
        • 31315
        i love conical tips, if you cant get the heat then your not using a cartridge system
        for the speacial hard to reach places i use a curved conical,
        and for big cleanups with desoldering braid i use a knife-tip
        • jm1234
          Soldering tips N9-XXX for ZD-8916
          by jm1234
          I have soldering station ZD-8916 and I only see like 6 different soldering tips being offered, eg. by tme: https://www.tme.eu/ie/en/details/zd-...er-peak/n9-26/
          Very limited variety, I'm missing a chisel ones, it just doesn't exist.
          I thought to myself everything is available in china, but they don't seem to be using the same nomenclature. Searching in aliexpress or temu for N9 tip doesn't find anything.
          Is there perhaps equivalent type to N9 I should be searching for?
          Or is my soldering station that weird and I just shot myself into a foot?...
          12-02-2025, 05:45 AM
        • clearchris
          Old Weller 100/140 Watt Soldering Gun
          by clearchris
          Someone gave me two of these 100/140w weller soldering guns. Yes, I know it runs current right through the tip, but might be nice to really get some heat into some big wires that need to be soldered.
          So, worth a place on the bench, or chuck it?
          10-04-2023, 01:27 PM
        • aed040
          Tips when soldering U6960/TPS62180
          by aed040
          I am trying to fix my macbook.
          Can you give me some tips when replacing the U6960 chip.
          What Hotair temp and fan speed do you use?
          How long do you usually wait before you can remove a chip? Ive been watching repair videos and they can easily remove a chip after a few seconds but I've been heating the part on a test board for almost a minute and it wont budge.
          Does a really good flux help in melting the solder? I am not sure if my amtech flux is fake that is why its taking a long time.
          The flux is also being blown away from the...
          11-25-2022, 06:18 AM
        • Prott
          Soldering flex cable - tips & tricks
          by Prott
          Hello fellow badcappers,
          I have to solder a MacBook (A1708) screen flex - one of the two data flexes got slightly torn (2 broken traces). I've seen some videos on youtube where people scrub the coating and then simply apply flux and solder to the exposed copper traces (and then run a jumper wire). However no matter what I try the copper does not take the solder at all - the more flux I add the more it actually stays only on the iron itself.
          I am practicing on a spare flex cable and it's gettiing quite annoying - to a point I am actually thinking I have to be doing something...
          10-04-2023, 06:25 AM
        • Ady2017
          SMD fuse soldering advice please
          by Ady2017
          Hi all. I need to replace an SMD fuse on my camcorder and this is the first time I have had to do any SMD soldering so your advice would be appreciated. Below is a picture of the board that I am working on and I have highlighted the fuse that needs to be replaced. I managed to zoom in to take this picture but the fuse is really tiny and is sandwiched between other components so this is going to be a new milestone for me. I appreciate that I am going to have to buy a new soldering iron if you could advice on what I need please. I was thinking about putting a big soldering iron across the whole...
          11-07-2025, 12:03 PM
