Soldering tips N9-XXX for ZD-8916
  • jm1234
    • Jan 2024
    • 80
    • Slovakia
    I have soldering station ZD-8916 and I only see like 6 different soldering tips being offered, eg. by tme: https://www.tme.eu/ie/en/details/zd-...er-peak/n9-26/
    Very limited variety, I'm missing a chisel ones, it just doesn't exist.
    I thought to myself everything is available in china, but they don't seem to be using the same nomenclature. Searching in aliexpress or temu for N9 tip doesn't find anything.
    Is there perhaps equivalent type to N9 I should be searching for?
    Or is my soldering station that weird and I just shot myself into a foot?
    I measured the diameter of the heating element of my solder gun and it's 4.3mm, so the solder tips should have a hole of that diameter.
  • Agent24
    I see dead caps
    • Oct 2007
    • 5401
    • New Zealand
    • Electronics and computer repair
    They look like Hakko 900M style tips to me...
    -David VanHorn
    • jm1234
      • Jan 2024
      • 80
      • Slovakia
      The diameter of the whole in N9 tips seems to be 4.6mm and the diameter of the heating element on my iron is 4.3mm. I don't think that matches Hakko 900M, but pls correct me if I'm wrong here.
      Fwiw I bought these https://www.temu.com/goods.html?_bg_...01102661131350 just to see if they match, but they don't. They are too loose for my iron.
      • Agent24
        I see dead caps
        • Oct 2007
        • 5401
        • New Zealand
        The cheap tips are usually loose anyway, even when they're the correct model. The genuine ones fit better.
        -David VanHorn
        • jm1234
          • Jan 2024
          • 80
          • Slovakia
          For anyone who landed here looking for the n9 tips, I don't have any good news, but at least I want to report my findings.
          I measured the temperature of the tips by:
          1. Setting the soldering temperature to 315C.
          2. Waiting for it to reach 300 (on the display)
          3. start 5min timer
          4. measure the temperature of the tip
          The old ones that I'm using now: 170
          new ones from Temu: 100 (loose fit)
          New ones from local e-shops (not branded): 100 (loose fit)
          new ones from TME (branded Solder Peak, so should be original): 110 (they fit snug)
          So after paying 100eur for the soldering station back in Nov 2023 and some 50eur for the tips from various sources in 2026, I can only conclude that I need to buy a new soldering station
            • 31925
            how you decided to buy that instead of a T12 or C245 based station is hard to understand.
            • jm1234
              • Jan 2024
              • 80
              • Slovakia
              I knew next-to-nothing about soldering at the time, had no knowledge of different tips. Still don't have, tbh. Went strictly by price, didn't expect to dig myself into the n9 hole.
              Can you point me to a reputable source where I could learn?
              • jm1234
                • Jan 2024
                • 80
                • Slovakia
                Looking at this shop, it has 149 welding stations. Not one mention of T12, how is that possible, am I not looking right?
                https://www.tme.eu/sk/en/katalog/sol...Dir=ASC&page=2
                You probably will be able to easily spot the ones that you would decide to choose for yourself, can you recommend few?
                  • 31925
                  this guy does good reviews.
                  https://www.sdgelectronics.co.uk/
                  i now have a Geeboon TC22 with a 245 handpiece
                  https://www.aliexpress.com/item/1005006397758007.html
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5401
                    • New Zealand
                    I'm quite surprised you're only getting 100 degrees when the iron is set to 315.
                    Even if the tip wasn't making good contact with the heater, it should still heat up well in free air.
                    I think you have some other issue here, a faulty heater/sensor, faulty controller/power supply, or the iron is calibrated very badly.
                    The OEM of your station is ZhongDi (https://china-zhongdi.com/product/po...ering-station/ for your ZD-8916 model)
                    They make many models of irons. I myself have two:
                    The ZD-919 https://china-zhongdi.com/product/to...ring-stations/
                    and the ZD-912 Hot air/Soldering station https://china-zhongdi.com/product/2-...ework-station/
                    Both of the irons in those stations work well and I have not had any performance problems.
                    They do both use different heater designs to yours, but I don't see why yours should be problematic.
                    I think there is something else going on.
                    -David VanHorn
                    • jm1234
                      • Jan 2024
                      • 80
                      • Slovakia
                      Agent24 you were right, the issue was with my measuring method - I used InfiRay P2 Pro camera. When I used Brymen BM 789 multimeter (with a wire), it showed values above 300C, even for the noname tips and even for Geeboon TC22 with C245 tips.
                      Anyhow, I learned something and am looking forward to my soldering experiences using Geeboon TC22, thanks stj.
                      • GraphicMan
                        852D close soldering station heating element replacement issue
                        by GraphicMan
                        Hello guys
                        I have got the A1321 heating element, i think there was a mistake in the listing on aliexpress as it states it is compatible with my soldering station but the problem is that i found it is not, the original and burnt heater have a thermocouple sensor (polarity matters) and the new one have a themistor sensor (resistance output, no polarity) the heater is compatible, the sensor is not
                        i have seen a video where someone did use it though as a replacement after adding a resistor on perhaps one of the inside pcb's of the station, i would like to make sure if that is possible...
                        05-26-2026, 07:12 AM
                        07-01-2024, 06:34 AM
                      • chth96
                        What soldering station should I purchase for 900M-TJ-I tip?
                        by chth96
                        hello.
                        A few months ago,I have purchased 0.1mm Soldering Iron Tip of below aliexpress link,But I noticed that It is totally impossible to use this 0.1mm iron tip in the T12 soldering station
                        https://ko.aliexpress.com/item/4001275635593.html
                        Is there any good soldering station which is possible to use 900M-TJ-I tip and have inexpensive or reasonable price in aliexpress?
                        Any reply would be appreciated.
                        11-24-2023, 05:08 PM
                      • caprider
                        Recommendations of quality soldering station and (separate) hot air station
                        by caprider
                        Hey,
                        I'm looking for some recommendations of a decent quality soldering station and a separate hot air station. I'm just a hobbyist, so even if (ultra)premium tools are not required, I still want some good tools. They should be available in Europe.
                        I now have a TS100 and some soldering irons and looking for some better tools.
                        1. Soldering station, budget around 200-240€
                        JBC BT-2BWA seems to be a good product in the budget.
                        2. Hot air station, budget around 200€
                        Up to now I've found ATTEN ST-862D to be a good option....
                        01-15-2022, 02:05 AM
                      • Peter_1402
                        Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
                        by Peter_1402
                        Hi Everyone,
                        I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
                        1. Soldering iron works great
                        2. There is a burnt mark on the hot air gun handle.
                        I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
                        Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
                        Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
                        Reed switch tested ok with a magnet.
                        From the above test, I can conclude...
                        07-12-2025, 11:50 AM
