DMM overclocking!
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    DMM overclocking!
    I had some thoughts earlier in an earlier topic bit curious if anyone went ahead with it?
    Anyway a lot of the older DMMs have clocking that ultimately determines how fast it comes up with a reading. Because of this clocking, DMMs can take several hundred milliseconds to make a reading, some DMMs up to a half a second to refresh.
    I don't have any of the really modern DMMs that are much faster, but perhaps an overclock of 500ms refresh rate (2 samples/second) to 250ms (4 samples/second) would make it nicer. I suspect that jitter would worsen. Also not sure how the LCD will respond to faster updates, it may just blur out or something.
    Anyone tried, and what issues did you run across? What brand/chipset meter was it? Was it worth it?
    • 31091
    Re: DMM overclocking!
    the D/A sampling circuit will go unstable if you run it too fast - it takes a minimum time to get a value from the input
    you will also dim the display a bit as it multiplexes faster - but you can compensate for that.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      There is a S&H but it's just a 1-bit DAC, there is a bit of settling time with the comparator, which would just add to, as said, the jitter. Or maybe it will read a little low for each sample?
      Anyone actually tried for fun? Wonder if the reference design DMMs are more likely overclockable... the custom ones may be running at their limits already?
        • 31091
        update rate is a selling point, so they probably already push them,
        although the datasheet for the dreamtech 0660 says clockspeed is tied to battery current.
        so it's a compromise
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          Well jitter is another thing that would be affected by a higher clock rate, but this could also be binned. Easier to make all devices along a line the same but some could potentially take an overclock just like any other electronic device...
            • 31091
            well you can try - every chip is gonna be different
            it wont be fun if you have to re-calibrate the meter though - specially if it's using an eeprom
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              Well integrating ADC DMMs won't have eeproms, they don't have computers!
              Then there's the thing that a whole lot of DMMs end up using canned chips like ICL7106's... granted the DMMs I have, this is not the case...
              TBH I've never had a SA DMM. Closest I've gotten was my PWM bench PSU project that read the output voltage/current using the microcontroller ADCs and as expected, they're fast, got ~3 digit resolution updated (on a HD44780) faster than I can read.
              • redwire
                • 3910
                There's a limit to what your eyes and brain can read, as far as update rate. The noise/jitter/flicker of the A/D also affects readings, it can update fast but bobble back and forth, never steady. And worse if you have more digits like 4-1/2.
                I like my old Beckmans 310,3030,HD110 etc. because they are very fast and with their manual ranging and low jitter, I can take 10 measurements within seconds. On ACV it has fast RMS averaging. The multimeter keeps up with what I'm thinking, where to probe next etc. as I work through some gear.
                Newer DMM's are clunk clunk clunk auto-ranging and then they have to settle in, firmware averages things, 10x slower to work with. It's gross, waiting for the reading.
                On the Wavetek/Meterman/Amprobe BDM40 (ICL7135 LED) I did increase the clock from 100kHz (2.5 readings/sec) to 150kHz (~4 readings/sec) which was not easy because it uses a tuning fork crystal but I found some 149.75kHz and I remember trying 192kHz it was too fast to read the display easily (~5 readings/sec) and you need a multiple of mains frequency for the clock, to reject AC hum. The integrating ramp resistor I had to change too.
                It was an experiment, so it didn't act like some slow antique.
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  The microcontroller ADC that I hacked up I was getting probably 8 readings per second or so, at least as far as I recall, because that was the screen refresh rate. The ADC sampling actually occurs much faster than that for other reasons, but the HD44780 is only refreshed 8 times a second. Either way, yes it's way too fast to comprehend unless the voltage/current were stable.
                  The meters I was thinking about hacking was my BKP 4½ digit, which also uses an ICL7135 driving an LCD. I also have a Dana 4½ digit LED which I'm thinking about hacking too, alas this is an autoranging unit.
                  I have two 3½ digit LD110/LD111 based LED DMMs that seem so much faster in updating than 7106/7107 DMMs which started the wondering. Alas most of my DMMs are ancient antiques, my newest one died on me (autoranging 3¾ digit) so I'm trying to just use my acquired-used 4½ digit units.
                  (Incidentally, if 1999 count is 3½ digit, 19999 count is 4½ digit, 3999 count is 3¾ digit, so what are 5999 and 3199 count units?)
                  • redwire
                    • 3910
                    I find it two things - the display update rate, and the A/D filtering/averaging.
                    If you have fast updates but slow averaging, you are waiting looking at numbers slowly climbing up to the final value.
                    If you have fast averaging but slow updates, you are waiting for that last number just to show up.
                    I seem to like 4 updates/sec, like Fluke 87 although its averaging is a bit sluggish. The Beckman/Wavetek just say "response time <1 second". Older multimeters are usually 2.5 updates/sec which seems slooow.
                    I'm running some antique multimeters because they're made in USA and new crap from taiwan or china can't beat them for reliabilty. It's so bad I wanted to make an LED DMM from scratch lol but can't find Hycon IC HY3131 to buy anywhere.
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8701
                      Well on older DMMs the averaging is done by LPF, and the clock doesn't really affect the filtering though it does affect what gets read. Will get a lot more trash reads if the clock isn't matched with the filtering, which is something that will need to be looked at with the overclock.
                      I think my Fluke 77 isn't too bad for update rate or even autoranging. My Dana and my HP are dastardly slow at autoranging though I think the HP beats the Fluke in update speeds. I don't remember how bad autoranging was on my Mastech... On the other hand, the startup selftest of the Fluke 77 sometimes gets annoying. Then again the HP and Dana (and probably my Viz and Tek), as all LED meters, are specced after warmup period of 30 minutes or so, just like the 7107.
                      Then the quandary...if the all the main silicon parts are made in China and assembled into a complete unit in the USA, is it a made in the USA?
                      • redwire
                        • 3910
                        Older Fluke 77 is 2.5 readings/sec and 77-IV up is 4 readings/sec. I find 2.5 is too slow. For something like DCV, the LPF is matched to the display update rate. If you overclock, the LPF can be 'speeded up'.
                        Fluke is just an old "brand" now owned by mega-conglomerate Fortive. Milk the old cow, priority is profit.
                        FTC finally did an update to Made in USA Labeling Rule, it was old 1997 and updated last summer 2021/07. Some loopholes got closed.
                        A lot of Fluke product is from Brymen, so I would expect some changes if they get audited. I think some final assembly/test/calibration still done in Everette WA which supports "the good undergoes its last substantial transformation in the United States" for some products. The trend for profit is outsourcing as much as possible to china and no longer using union labor in the USA.
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8701
                          hmm. thought the fluke 77 was significantly faster than my b&k 4½ digit, which I thought was a reference ICL7135 design. Need to locate full docs for the b&k, seems almost impossible to find free docs for it... data is available for everything but my meter...
                          • redwire
                            • 3910
                            BK Precision 2831D uses ICL7135 and 100kHz xtal, it's similar to the Wavetek BDM40. I changed the xtal to 149.75kHz (all I could find near 150kHz) and pin 6 resistor from 100k to 82.5k and it works fine. 192kHz xtal/33k was 4.8 updates/sec and was too fast for my liking.
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              Oops. I was wrong, it uses an ICL7129 IC. Anyway it looks like I'll need to find a crystal unfortunately, else I will have to hack up a PLL or something. Probably similar crystal requirements, but I didn't look at which was installed, probably the 100KHz or maybe 120KHz.
                              One datasheet says it should be good to 360KHz... heh...
                              • Joho
                                HP PRODESK 600 G2 DESKTOP MINI starting, no picture, fan only spinning faster and faster
                                by Joho
                                Hi there, I've got a HP Prodesk 600 G2 Mini on my bench, that turns on but no picture.
                                Model: HP ProDesk 600 G2 Desktop Mini
                                Product No: Y3J22EC#ABD
                                BID=15WWP3ET6**#SABD#DABD
                                Serial: CZC632BBCJ
                                First I thought maybe BIOS got corrupted. Someone sent my corrected BIOS that I flashed. Now symptoms are: Mini starts when power is plugged in, Fan turns on and gets faster and faster until it's at 100%. Nothing gets excessibly hot.
                                When I desolder the BIOS chip I get Beep codes / LED codes "BIOS is missing"
                                Without CPU I get "CPU...
                                03-07-2025, 09:18 AM
                              • ArtMov
                                [HELP] Asus g732lv ami bios overclocking lock reseting after reboot
                                by ArtMov
                                Hi guys, i have a problem , my bios resets disabled overclocking lock setting to enable after reboot, please tell me which function can be responsible for restoring the stock config for this option, loading parameters from nvram and so on, like bios ,protection, from asus. My bios made me angry) Set default parameter to disable in amibcp 5 , doesn't help(
                                1. I made overclocking lock disabled the default in amibcp
                                2. I changed the varoffset to the wrong one, but it led to the programmer, it was very tedious and nervous, I really regretted it, my chip is on the back of the...
                                03-31-2023, 01:30 PM
                              • backdoorsecurity
                                looking for patches or patched bios for advanced menu, overclocking, undervolting lenovo p51 & p52
                                by backdoorsecurity
                                both my laptops are in the yes list for patching bios however the digmorepaka github repo does not contain patches for p51 or p52.
                                I read that the t or w 530 patches may work, can anyone confirm or deny this?
                                All specs are in hardware-info.txt in the zip file i uploaded.
                                p51 board number: DP510 NM-B041
                                p52 board number: EP520 NM-B561...
                                12-12-2024, 06:50 AM
                              • harp
                                simple win network with optimization issue
                                by harp
                                simple win network with optimization issue I like to ask some question about configuring simple room win network. So, there is 2 win computer, android4 device and wifi router not connected to internet. The purpose is storage space and manipulation with large files between any device. 1 pc - 192.168.0.2 (winxp sp2) wired to router port#1 2 pc - 192.168.0.5 (win10, enabled smb1.1) wired to router port#2 3 router - 192.168.0.1 with dhcp for wifi (192.168.0.101...) 4 main tablet - 192.168.0.101 (android4) wified to router wifi port I generally work and control transfer with my tablet via ES3 file...
                                06-23-2025, 11:01 AM
                              • DrvLikHell
                                Sharp (Hisense) LC-55p6050u - Flashing/dimming row of pixels
                                by DrvLikHell
                                Hello again! I have come back for some wisdom and hopefully for some guidance with this problem I'm having. The TV is a 4k 55" Sharp LC-55p6050u and the problem is every other line of the bottom 32 lines flickers out, comes mostly back, then flickers out again, and repeats this continually. The lines on the bottom right of the screen go out completely while the lines on the bottom left are affected so slightly that it's almost impossible to see it. There is a gradual gradient from appearing almost perfectly fine on the bottom left, to an obvious problem on the bottom right.
                                The...
                                02-05-2025, 01:44 AM
