looking for patches or patched bios for advanced menu, overclocking, undervolting lenovo p51 & p52
  • backdoorsecurity
    • Nov 2024
    • 7
    • united states
    both my laptops are in the yes list for patching bios however the digmorepaka github repo does not contain patches for p51 or p52.
    I read that the t or w 530 patches may work, can anyone confirm or deny this?
    All specs are in hardware-info.txt in the zip file i uploaded.
    p51 board number: DP510 NM-B041
    p52 board number: EP520 NM-B561
  • dj-bobr
    Thinkpad W541 (20EG) Q1, weird behavior after SPI flashing (3 flashes of power button LED)
    by dj-bobr
    I kindly ask for help with Thinkpad BIOS/ME repair.
    Thinkpad W541 board bought from Aliexpress, so I have no service tag nor S/N. It is 1GB version Q1 (K1100 nVidia GPU). BIOS 2.23, EC 1.13, ME 9.1.32.1002.
    It worked fine until I tried to remove whitelist.
    Steps taken:
    - battery out, CMOS coin cell out, laptop disassembled; I kept LAN/USB subboard connected
    - i took SPI programmer (CH341A with 3.3V mod) and SOIC clip and did a full backup of all SPI flash chips (SPI1 and SPI2 - BIOS, EC, ME, GbE; SPI3 - video BIOS; SPI4 - Thunderbolt fw) for several...
    03-05-2024, 04:28 AM
  • ArtMov
    [HELP] Asus g732lv ami bios overclocking lock reseting after reboot
    by ArtMov
    Hi guys, i have a problem , my bios resets disabled overclocking lock setting to enable after reboot, please tell me which function can be responsible for restoring the stock config for this option, loading parameters from nvram and so on, like bios ,protection, from asus. My bios made me angry) Set default parameter to disable in amibcp 5 , doesn't help(
    1. I made overclocking lock disabled the default in amibcp
    2. I changed the varoffset to the wrong one, but it led to the programmer, it was very tedious and nervous, I really regretted it, my chip is on the back of the...
    03-31-2023, 01:30 PM
  • esolks
    Lenovo thinkcentre M70q Gen 2 advanced menu unlock
    by esolks
    Hello to all
    i have a lenovo m70q gen 2 , i need to unlock hiden advanced menus to configure tdp ( i'am using currently an i7 10700 ( non T ) and need to customize PL1 and PL2 )
    can someone please help me ?
    best regards...
    07-11-2025, 05:03 AM
  • ahmadhiderthx22
    acer a315-58g advanced unlock
    by ahmadhiderthx22
    bios unlock all power and advanced settings thanks ram settings everything in advanced and power otpions bios heres my bios dump...
    09-08-2023, 03:54 AM
  • dmcabs
    SHARP LC-60LE640X display flashing white noise patches and totally dropping out randomly
    by dmcabs
    Hey guys,
    I have a SHARP LC-60LE640X TV that has suddenly developed an intermittent fault of flashing white noise patches (appears like an Analog tuner off signal) and then totally dropping out.
    This model I believe is also known as LC-60LE600U or LC-60LE640U in other regions.
    FYI, a long time ago I was a component level repair tech for all consumer electronics and IT equipment.
    I'm a bit rusty but still have ability to dig right down.
    I measured all power supply lines and checked them for AC ripple voltage. Noting any lines that exceeded about...
    09-21-2024, 11:09 AM
