bench multimeter pushbutton switches
  • redwire
    • Dec 2010
    • 3912
    Got a Wavetek/Amprobe/Meterman BDM-40 bench DMM with a broken pushbutton switch.
    Looks like the buttons got hit and one broke the end and the contacts popped out. Ouch.
    Service manual gives Alps part numbers that I have no data for:
    3202-3500960 SPUN50A802-GW 12P*3 ,IL 12P*1 ,PP 6P*1 PP
    3202-3701080 SW PUSH SPUN70A802 12P*4 18P*2 IL 6P*1PP
    Closest I can find is Alps SPUN194700 4PDT. But ALPS catalog has momentary and latching parts and instead these switches stay in until the next button is pressed (i.e. V, A, ohms select buttons).
    There must be a lever running between the switches for the one-of feature.
    It looks like switch bank is in a metal rail. I'm not sure how that rail works.
    Anyone worked with these switches, know if this whole bank has to be pulled or how the lever works between switches. Would I order momentary or latching?
    • 31315
    Re: bench multimeter pushbutton switches
    the switches fit into a metal chanel with a sliding bar that releses one switch as you press the next.
    as for the actual switch, the only difference between latching and momentary is a metal "S" shape pin that you can remove that is in the latching ones.
    so you can use either.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8716
      It looks like you have a Intersil 7135-based DMM there (4½ digit integrating). I wonder if anyone tried "overclocking" these ADCs?
      Mine (B&K) is really slow... if I could get it 33% to 50% faster that'd be nice...
      Probably not though. When I was trying to compare the 7106/7107 based DMMs versus my LD110/LD111 DMMs, the 7106 are pitiful...
      • redwire
        • Dec 2010
        • 3912
        I had to pull the entire switch bank, then pry up the locking tabs to get that switch out. The cam lever is just in the way otherwise. Note it includes a tiny spring, the kind that shoot into outer space when you aren't looking
        Looks like Alps SPUN pushbutton assemblies are factory-made by sliding in the switches and then crimping the tabs. I see only push in/push out (latching) switches have a pin on the top.
        I'd order the new switch but but no momentary 4PDT in Alps catalog.
        I'd have to get SPUN194700 and pull the latching pin I guess?
        I got the DMM free, save it from the garbage, and I think better quality than the $25 banggood things.
        Yes I'd like to overclock it, it does need turbo. I got a 100kHz clock (2 readings/sec; and rejects 50/60/400Hz). Max. is 120kHz (1979 datasheet typo still there: 1200 kHz max. lol).
        "The maximum conversion rate ... is limited by the frequency response of the comparator. The comparator in this [ICL7135] circuit follows the integrator ramp with a 3μs delay, and at a clock frequency of 160kHz (6μs period) half of the first reference integrate clock period is lost in delay. This means that the meter reading will change from 0 to 1 with a 50μV input, 1 to 2 with a 150μV input, 2 to 3 with a 250μV input, etc. This transition at mid-point is considered desirable by most users; however, if the clock frequency is increased appreciably above 160kHz, the instrument will flash “1” on noise peaks even when the input is shorted."
        Teledyne (Microchip) obsolete TC835 can go to 200kHz and is pin-compatible; integrator cap change too but more info on overclocking is there. I'll look into it because I like fast update rate too.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8716
          I think mine's also 100KHz or so, just eyeballing it (should be 2.5 readings/sec?) I have an LD110 DMM that's closer to 4 or 5 readings/sec...
          Would be interesting. I'm thinking I could just bodge a resistor in parallel if it's an RC clock oscillator, though I haven't taken a good look at what's generating the clock in my meter.
          The power consumption of my meter is already pretty terrible, so I guess I don't care too much. I wish it could run 200 hours off a PP3 but probably the decoder and other logic is precluding that... (though it is LCD it uses UM2's because it eats so much power...)
          • redwire
            • Dec 2010
            • 3912
            I can't get the spring in.
            Held it in tweezers and as I released the tweezers, it shot across the room Hours later I found it, using a magnet.
            The spring goes between two switches and presses the lock lever for the 1-of-3 latch (V, A, ohms).
            Spring gets trashed because you have to come in parallel to the switch when installing the adjacent switch into the metal rail.
            Next I tried a piece of scotch tape to compress the spring while putting in the adjacent switch. Spring got smeared again. Shot out 10 times. I am not a Zen Master.
            Any suggestions? The gap is only a couple mm and no room to work as it's all switch on either side, and the rail forces things to be tight.
            It looks like I have to somehow put the whole 4 bank together including spring-from-hell, then put in the rail and crimp. The end switch is push on/off power so it can go in alone.
            I think Alps uses a jig to assemble these all at once, then installs the rail and does the final crimp.
            No mention of the spring or lock lever on Alps website or Internet I'm sure you can't purchase them. Weird because these switches are also used on signal generators and audio gear.
              • 31315
              compress the spring with a loop of cotton/nylon?
              • redwire
                • Dec 2010
                • 3912
                Follow up for anyone repairing these Alps SPUN pushbutton switch banks.
                I made a spring compressor out of a back-back strip of tape, and taped down the ends. Installed the adjacent switch and gently cut/slid out the piece of tape.
                The spring gets smeared easily and pops out and shoots like crazy. I made a tent around the work area (draped a shirt) and the spring usually hits that. HDD magnet on the bench helps catch it too.
                Confirm the spring alignment/operation before soldering in the switch bank.
                When converting a push-on/push-off switch to momentary or one-of, you have to disassemble the switch and remove two springs in the top cap.
                Momentary/one-of have a super tiny clear plastic plug, to stop dirt getting in with the removed spring (last pic).
                Putting the switch back together is also very hard, because one hand is compressing the main spring to install the plunger. I crushed some contacts doing it.
                Best to slide the plunger in, instead of putting it on top of the base.
                Hope this helps people doing this surgery.
                • CoinCoin88
                  Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                  by CoinCoin88
                  I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                  Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                  09-15-2025, 03:36 AM
                • tbsmith
                  Ninja DCT401 Double oven/air fryer Possible microprocessor issue?
                  by tbsmith
                  I'm having a random issue with this otherwise nice double oven/air fryer. It sometimes does not respond to the controls. Sometimes only the upper control buttons work, sometimes they all work and sometimes none of them work. The power supply is good as the control board has a steady 5V and 3.3V. The pushbutton switches are all good as tested with multimeter. When the buttons are working, there is about 2.5V to the high side of the pushbutton. I'm assuming pressing a button grounds the input pin to the microprocessor. When the buttons are not working, there is about 0.3 volts on the high side....
                  07-12-2025, 11:40 AM
                • dj8452000
                  How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
                  by dj8452000
                  I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
                  02-18-2025, 08:28 AM
                • shamsudeen
                  Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                  by shamsudeen
                  Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                  I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                  i know that in linear power supply the noise will be very low comparing to SMPS supply....
                  07-19-2025, 07:14 AM
                • Eniaro
                  Bench test a series X
                  by Eniaro
                  How do you bench test a series X? I was planning to find a defective PSU to use its connector, but before I go about doing this, I was wondering if there's any bench PSU to the series X connector adapter available
                  06-17-2025, 01:46 PM
