Anyone ever hear of this solder brand before?
  • jayjr1105
    • 281
    Need some .6mm solder. I gave what was left of my cheap 63/37 to a friend who needed some. Stumbled on this brand. I figured "made in Japan" it must be half decent but it doesn't give flux percentage or flux type unless you can read japanese maybe. Anyone hear of it before? As long as it has 2% flux it pretty much checks every box for me. 63/37, .6mm, 2% or more flux.
    Ryzen 3600x
    16GB Patriot 3600MHz
    MSI B450 Gaming Plus
    MSI Air Boost Vega 56
    Acer 32" 1440P Freesync
    Rosewill Capstone 750W
    Hakko FX-888D Station
    FX-8802 Iron
    MG Chem .8mm 63/37 RA 2.2%
    • 31296
    Re: Anyone ever hear of this solder brand before?
    i hope that doesnt mean it's made in november 2005!!
    would be nice to know if the flux contains Halide.
    because Halide is good, but unhealthy to breath - so a lot of solder is Halide free,
    but you need the Halide to solder to things like brass.
    • jayjr1105
      • 281
      Yeah I messaged him to ask about the flux type and he wasn't sure but said he would contact the distributor. The date code is the 21 I believe (2021)
      https://www.ebay.com/itm/254928162490
      Was able to translate it but no flux info unfortunately.
      Ryzen 3600x
      FX-8802 Iron
      • megaraider
        • Jul 2015
        • 307
        • Portugal
        According to the label we can only tell it contains flux type P2 > hence Rosin.
        As for percentage it's unspecified.
        It's a little worse... if "Val." stands for "valid / validity" as it should, then it was made even before 2005!
        • clearchris
          • Dec 2013
          • 687
          I highly recommend getting a pound of solder from digikey or mouser. It's much cheaper than you think (iirc, a pound of AIM was around 20 USD), and it will last you a long time. Cheap solder really stinks.
            • 31296
            lucky you, in the u.k. we are getting fucked by exchange rates.
            500grams of decent solder is about $100!!!!!
            the same roll from poland - half that.
            • petehall347
              • Jan 2015
              • 4450
              • United Kingdom
              maybe you are looking in the wrong place ?
              https://uk.rs-online.com/web/c/power...ons=4294378735
              • clearchris
                • Dec 2013
                • 687
                I paid 16usd a two years ago for this. It's 32 now, but that's still not 100.
                https://www.mouser.com/ProductDetail/738-13977
                  • 31296
                  no, your forgetting i use lead-free, that averages £70 a roll for standard crap
                  i use one with added nickel and germanium for use on fine copper wire/traces.
                  https://www.tme.eu/en/details/sn100k...tannol/810916/
                  • jayjr1105
                    • 281
                    Are you obligated to use lead free or just a glutton for punishment?
                    Ryzen 3600x
                    FX-8802 Iron
                      • 31296
                      the good stuff works just fine thanks
                      i use it partly because it's stronger so things that have heatsinks wont need resoldering in future so much,
                      and partly because any comercial repair on goods made after 1996 i think it is, must use leadfree.
                      military,aviation and medical exemptions exist - but they are being slowly phased out with the newer solder formulations.
                      • jayjr1105
                        • 281
                        I bought a 1lb roll of lead free for $8 which was possibly a pricing error just so I have some lead free if anyone ever requests it...
                        Is this stuff any good? I have another leaded MG chemicals roll and it's my go to.
                        https://www.amazon.com/gp/product/B072JKFDCH
                        Ryzen 3600x
                        FX-8802 Iron
                          • 31296
                          the metal blend is o.k.
                          i wouldnt mind seing the flux ingredients - it's the flux that really matters.
                          i'v said it before a lot, HALIDE is your friend - as long as your not snorting the fumes
                          it will make the solder take to stuff like brass contacts and maybe even aluminium or some types of steel.
                          if you get halide-free flux then your shit out of luck soldering to brass.
                          found it!
                          Halide confirmed!
                          • jayjr1105
                            • 281
                            I took a gamble and bought this stuff and it arrived already. Wets really nicely and has adequate flux content from the residue you have to clean up afterwards. It doesn't finish quite as shiny as my MG Chemicals or Chipquick spool but it's miles better than the chinese .6mm stuff it's going to replace. It smells different than my other two as well but not sure what to make of that.
                            Ryzen 3600x
                            FX-8802 Iron
                              • 31296
                              the chinese use pure rosin usually,
                              the chipquick is water soluable flux - thats toxic just so you know and has to be cleaned off.
                              the others dont say
                              all fluxes smell different
                              • jayjr1105
                                • 281
                                the others dont say
                                According to the datasheet the Chipquick flux can be left on the board.
                                https://cdn.badcaps-static.com/pdfs/...98b4ece8e5.pdf
                                Same with the MG.
                                https://cdn.badcaps-static.com/pdfs/...f6f36653f4.pdf
                                Ryzen 3600x
                                FX-8802 Iron
                                • jayjr1105
                                  • 281
                                  Well, you live you learn. without cleanup my MG chem stuff is a clear winner. The new stuff leaves an almost burgundy crust that is really difficult to remove even with 99% alcohol.
                                  Ryzen 3600x
                                  FX-8802 Iron
                                    • 31296
                                    thats rosin - mostly.
                                    if you see milky light brown flux then it may be stannol HS10 - it's very common because it works well but it's hard to remove.
                                    the other common one in europe is stannol krystal, it's only in lead-free solder but it's completly colourless and water-clear.
                                    it's the only one i use
                                    stannol seems to license or supply their fluxes to other solder makers.
                                    • jayjr1105
                                      • 281
                                      I should clarify. The pictures there are both uncleaned and the MG chemicals is the very shiny one.
                                      Ryzen 3600x
                                      FX-8802 Iron
                                      • acedogblast
                                        by acedogblast
                                        11-02-2024, 05:13 PM
                                        Multifix 425-01 and 450-01 Rework Flux Datasheet
                                        REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                                        - No Clean Formulations
                                        - Low residue
                                        - Range of activity to deal with different component solderability
                                        - Halide free
                                        - Suitable for dispensing
                                        - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                                        Both products are supplied in syringes or cartridges for application by dispensing....
                                        10-07-2024, 06:02 AM
                                      • chth96
                                        Is it good to use chemistronic flux off es835b for flux remover?
                                        by chth96
                                        I want to purchase any good flux remover But "chemistronic flux off es835b" is the most common flux remover in my nation..
                                        Or I have to purchase "3m novec flux remover" which is quite expensive in my nation?
                                        11-17-2023, 07:25 AM
                                      • myth77
                                        UV solder mask - high temp resistent, recomendation?
                                        by myth77
                                        Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                                        Is there any solder mask...
                                        03-28-2022, 04:04 AM
                                      • G-Gamer
                                        Please tell me where I'm going wrong with hot air!
                                        by G-Gamer
                                        So I'm trying to get into micro soldering, repairing tech etc.
                                        I bought a load of equipment, The YIHUA 853D 2-in-1 station, 1080p Microscope with 10", I do not have low-melt or leaded solder yet, I have tried flux 'paste' in a tube, very liquidy seems to blow away, I've tried flux paste in a tub, still no luck.
                                        I have tried 3 different boards, a router, an Xbox One Fat and now a Pi400, none show ANY signs of melting solder, components don't budge.
                                        My method:
                                        Preheat board with hot air (Small nozzle as it's directed, as I'm told) at 250c
                                        Apply flux to component...
                                        11-13-2025, 10:25 AM
