xytronic solder tip
  • dgfullin1
    • May 2010
    • 3
    xytronic solder tip
    I am looking for a 0.2mm replacement solder tip for a xytronic LF1600 solder station. The smallest that xytronics makes is 0.4mm.
    Thanks in advance.
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: xytronic solder tip
    ok... well... then you are stuck. as you may know, grinding down tips is a bad idea as tips are plated... and if they don't make it, then they don't.
    perhaps you could make a .4mm work?
    sigpic
    (Insert witty quote here)
    • dgfullin1
      • May 2010
      • 3
      Used the 0.4mm last time and it is just too big for small pitch devices. I was hoping perhaps another manufacturer was compatible.
      Thanks,
        • 30985
        mod-chips?
        tbh when your getting that small it's hard to get the heat to the end of the bit.
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          Originally posted by stj
          mod-chips?
          thats what i was thinking as well. smaller int not always better.
          sigpic
          • dgfullin1
            • May 2010
            • 3
            I know smaller is not always better, but trying to solder .015 pitch devices with the .4mm tip was very hard. I either missed joints, or was getting bridging. This board is very compact, so there is not a lot of room to get the best angle on leads at all times. Perhaps a chisel tip instead of round?
            • smason
              • 1652
              Chisel might help, and lots of flux.
                • 30985
                screwdriver style with a sharp end is better for getting the heat down.
                • PlainBill
                  • Feb 2009
                  • 7034
                  One approach I've used is to accept there will be bridging. Concentrate on soldering every pin, then go back over the work carefully and use solder wick to remove the excess solder.
                  PlainBill
                  • corrize
                    Best way to solder LVDS connector for beginner (and qfn) ?
                    by corrize
                    Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                    I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                    I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                    See the test :
                    https://youtu.be/bNAzC-EvqHs?t=1767
                    With hot air from bellow the board, that's...
                    03-09-2023, 02:57 AM
                  • myth77
                    UV solder mask - high temp resistent, recomendation?
                    by myth77
                    Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                    Is there any solder mask...
                    03-28-2022, 04:04 AM
                  • petemanuk
                    BGA solder balls not connecting - help pls
                    by petemanuk
                    So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                    I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                    I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                    11-16-2022, 05:21 AM
                  • acedogblast
                    by acedogblast
                    11-02-2024, 05:13 PM
                  • sircastor
                    Solder not reflowing - what am I doing wrong?
                    by sircastor
                    I'm trying to fix a broken MacBook Air, and got a parts board to salvage components from. Following the suggestions of many folks here, I wanted to get in a little practice of using my hot air station (A Quick 957DW+) on the parts board so I know what kind of behavior to expect.
                    For the life of me, I can't get anything done with this thing. I have tried multiple temperatures (from 210-425c), different air speeds, preheating the board (with the hot air, just warming it all around). I have applied what feels like excessive amounts of flux (Amtech V2-TF-559) and the solder on these components...
                    03-03-2024, 02:44 AM
