Recommendations of quality soldering station and (separate) hot air station
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8339
    Re: Recommendations of quality soldering station and (separate) hot air station
    That’s the only thing I could find out back then.
      • 31246
      then maybe i'll get a T3a and a micro-pencil and make a splitter with a swutch - save wearing the plugs out
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8339
        Why not a dual station setup and have a T245 on one side and the other one on the other side? No change required.
          • 31246
          they make one - it's fucking expensive!
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8339
            Nothing is cheap these days…
              07-01-2024, 06:34 AM
            • chth96
              What soldering station should I purchase for 900M-TJ-I tip?
              by chth96
              hello.
              A few months ago,I have purchased 0.1mm Soldering Iron Tip of below aliexpress link,But I noticed that It is totally impossible to use this 0.1mm iron tip in the T12 soldering station
              https://ko.aliexpress.com/item/4001275635593.html
              Is there any good soldering station which is possible to use 900M-TJ-I tip and have inexpensive or reasonable price in aliexpress?
              Any reply would be appreciated.
              11-24-2023, 05:08 PM
            • mkbehbeh
              KSGER C245 Soldering station PSU 220V only?
              by mkbehbeh
              I purchased this soldering station when it was on sale at amazon. It had a slew of one star reviews, but the price was low enough that even if the controller and PSU were toast, the handle tips and stand were worth more than the price. All of the reviews mentioned that the unit was either DOA, or died on the first use. I looked on Aliexpress and the first clue was that KSGER still sold the 220V version of this station, but all of the 110V versions had been discontinued. I figured That there was a problem with the 110V on the power suppply and the controller would be fine.
              I am...
              04-17-2023, 03:11 PM
            • Peter_1402
              Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
              by Peter_1402
              Hi Everyone,
              I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
              1. Soldering iron works great
              2. There is a burnt mark on the hot air gun handle.
              I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
              Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
              Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
              Reed switch tested ok with a magnet.
              From the above test, I can conclude...
              07-12-2025, 11:50 AM
            • nbdy
              QUICKO soldering station
              by nbdy
              HI,
              Have a QUICKO soldering station with no numbers for the model ... (think it's a KSGER or similar copy)
              All worked nice, till some day it heats the iron till it was RED (HOT) ...
              Turned it off, and tryed today again, and all the same, even with a second iron ...
              The display shows that the iron is not connected, like not inserted in the handle ...
              The second thing is that it has 6 pins connector and can't find a handle that is similar for my station ...
              Has someone some advice what to do, where to look, even how to...
              01-07-2024, 05:44 PM
