Pre-heating your Mobo
  • Neo2_000
    • Apr 2005
    • 180
    I have arrived at a novel but effective way of preheating motherboards before attempting soldering work. This negates the need to purchase a $700 factory convection unit which a salesman tried to sell to me.
    You take 2 common house bricks and an old shirt made of non-flamable material. You position the bricks about 300mm apart and cover them with the shirt. Then tuck the ends in under the bricks.
    You then place the outlet of a hair dryer under one side, wrapping the material around the outlet to prevent air escaping.
    Place your mobo on top of the shirt so that it sits between the housebricks weighing down on the material. Turn on the hair dryer and pump hot air into the enclosure.
    The hot air is forced evenly and gently upwards through the shirt material and after a few minutes the PCB is nice and hot making desoldering much easier.
    You can repeat this as required to maintain temperature or focus the hair dryer on the working area of the PCB to maintain heat when addressing stubborn joints. The more stubborn the joint, the more I heat the surrounding copper landmass with the hot air stream rather than using the soldering iron which may cause damage if applied too long.
    Before desoldering, I also first pretend that I am soldering the joint, adding plenty of fresh new solder to it. This was originally suggested by Topcat and makes a big difference when desoldering those stubborn joints. The fresh new solder seems to meld with the old solder making it flow much easier.
    This has helped me greatly reduce the likelyhood of failures when recapping.
  • ChaosLegionnaire
    by ChaosLegionnaire
    09-13-2022, 09:02 AM
  • Cerberuska
    Mobo MSI B550-A PRO password popup
    by Cerberuska
    Hello guys,
    I have interesting problem. My MoBo MSI running on Ryzen 7 w/o graphics just good. I swapped to Ryzen 5 5600G and on the boot I stuck with screen on picture. Enter Password. I checked BIOS setting with Ryzen 7, no security is enabled, BIOS password or TPM.
    BIOS I updated to last one.
    any suggestions?
    And same thing for two different 5600G, and yes, MoBo supposed to support it.
    Thank you...
    11-10-2024, 01:23 PM
  • mrsith
    Dell G3 17 3779 - no display after mobo replacement
    by mrsith
    Hi guys,
    I have a friend's Dell 3779 that came to me with severely shorted mobo. Did not manage to isolate the cause, most likely that was a bga shorted. Went for a replacement motherboard. Got one from China, apparently it's been tested prior to shipping. The mobo starts up normally but I am getting no display whatsoever.
    Tried using external monitor, but being blind I am not sure if laptops goes as far as booting to Windows, a d without it I cannot get hdmi to work. Can't see boot menu options to make sure it boots to Windows. Went ahead and did a blind bios update,...
    04-30-2023, 05:11 AM
  • Ibod
    Corsair cx600 psu & ASRock B450Pro4 mobo wont start
    by Ibod
    HI I have a PC using a Corsair cx600 psu & ASRock B450 Pro4 mother board that won't power on after a shutdown (replaced a dead drive in a raid array) Not the boot drive.
    With most things unplugged, including the 24 pin ATX connector, but not the ATX12v to cpu, I have +5.01V on the +5vsb pin 9 from the PSU. When I plug the 24 pin back in to the mobo, the +5vsb fluctuates between 1.1v & 1.9v.
    Not sure where to go from here ?
    Is the PSU at fault or is the mobo causing the problem
    Look forward to any help :-)
    If I plug the 24...
    02-08-2023, 11:00 AM
  • Felipe_Serra_83
    Dell Inspiron 14-5448 - fan turns off and mobo keeps running
    by Felipe_Serra_83
    Hi, everyone. First post of an actual repair. I'm a technician but a complete newbie with laptops.
    So I got this Dell Inspiron to play with.
    No charger, so I connected to my bench PSU.
    The laptop also didn't include: hard disk (I added one of my own for testing, see below) and wireless PCB (but I doubt this could have anything to do with this particular failure).
    ------What it did (and didn't do)------
    1) I turned it on and it powered on. Powered down in 2 seconds by itself.
    2) Removed RAM, changed slot. Same...
    04-04-2024, 12:39 PM
