EVB meter little help please?
  • supadupanerd
    • Mar 2010
    Hello long time reader first time poster... yadda
    I recently aquired a kit for the EVB meter and while most of the installation has been a rewarding and fun experience i think i might have bitten off more than i can chew!
    So far have troubleshooted a few component placement issues myself
    - put the pots in the wrong spots, swapped them... now good
    - put the diodes in the wrong spots (got the mounting positions mixed up with the 4 flat square shaped capacitors), bought new ones, these are good
    - installed incorrect resistor, tested all resistors now all are ok
    Currently the issue i have, is that when i have the 9v battery (test leads in series with board) i get a current draw of ~8.6mA.
    Any ideas?
    • 31198
    Re: EVB meter little help please?
    wouldnt the leds need a few ma?
    • supadupanerd
      • Mar 2010
      Wrong terminology usage. What i meant to say is that the probes of my multimeter are in series with the battery and the board. haha
        • 31198
        i knew that - same thing applies.
        • Radio Fox
          • Jan 2010
          • 281
          Are you saying that circuit is drawing current without you pressing the ON/OFF button?
          Can you post a photo of both sides of the board.
          ________________________________________________
          Invisible airwaves crackle with life
          Bright antennae bristle with the energy
          • chth96
            by chth96
            03-09-2024, 10:03 PM
          • marce002
            UT210E clamp meter amps measurements wrong
            by marce002
            Hello all
            I have an UT210E clamp meter that went wrong doing amps measurements in continuity DC, it shows an offset of around 4/5A when first set, (lever at DC 10A) at 2A DC shows fixed 0L always......,,,,,, and also does not allow me to (zero button) , and as i said it is even worse in the 2A !! setting which do nothing and shows "0L"... when you can measure DV in 20A after achiving a ZERO with many RESET ZERO times , you can measure with a lot of offset..... eg 1A current is measured at around 650 mamps, . Similarly, a 4A current is shown at around 3A. |O
            05-08-2020, 11:52 AM
            12-31-2023, 06:04 AM
          • jorpec
            by jorpec
            Hi
            Thnaks
            01-23-2023, 10:37 AM
          • ttmi100x
            HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
            by ttmi100x
            Greetings everyone,
            I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
            The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
            Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
            Upon closer inspection...
            07-31-2024, 06:36 PM
