Koban - Current Clamp Meter - DMM
  • neuron
    • Feb 2013
    • 126
    • Portugal
    The factory / reseller ... don't know anything about the device (Schematic, Service manual, etc) and I need to repair this DMM - Clamp Meter.
    2TY - Transistor - Q5 (Diode mode ok)
    CHX ??? 5 Pins - U3
    C31 ??? Burn,
    Tested - V, Ohm, Diode, ºC ... don't see any errors
    Thanks in advance for all info
    Ruy
    • 31050
    Re: Koban - Current Clamp Meter - DMM
    CHX may be XC6116H028MR
    • neuron
      • Feb 2013
      • 126
      • Portugal
      Thank you,
      I can't find PDF with that reference.
      Thank
      Ruy
      • megaraider
        • Jul 2015
        • 307
        • Portugal
        @neuron
        stj is most likely right! A simple quick search returns:
        Part No.: XC6116H028MR, SmdCode: CHX, Manufacturer: Torex, Package: SOT-25, Pin: 5, Memo: XC6116H028MR, Description: 2.8V Voltage detector, 0.1%, Delay time = 1.6s
        The datasheet may not be easy to find but that`s not your major concern, right?
        Either way, you can find here the datasheet.
        • neuron
          • Feb 2013
          • 126
          • Portugal
          Originally posted by megaraider
          @neuron
          Boa tarde megaraider,
          And the procedure to test ?
          The last letter ... is necessary?
          C31 no info?
          I can follow the tracks in the board and
          tested 2TY and all resistors around the C31.
          C31 in the board ...?
          Thank you
          Ruy
            • 31050
            mabe you can find a schematic for a similar meter with the same chip.
            Semico CS7721CN
            i also found this:
            "The CS7721CN is pin for pin compatible with Fortune Semiconductor FS9721"
            and a LOT of meter info is here:
            https://sigrok.org/
            • megaraider
              • Jul 2015
              • 307
              • Portugal
              A long list of chips, schematics, teardown, ... info on Multimeters (DMM):
              http://improwis.com/projects/reveng_multimeters/
              You can find a long list of devices using the CS7721CN chip along with detailed info.
              A very quick look pop-up UT61E (schematics) and Wintex TD2200, quite similar to UT61E. The later as "IC11: some tiny SOT-25 thing..." that might well resemble to the "U3" you found.
                • 31050
                ut61e has nothing in common with those chips.
                • neuron
                  • Feb 2013
                  • 126
                  • Portugal
                  Semico CS7721CN
                  i also found this:
                  https://sigrok.org/
                  Thank you stj, megaraider
                  2TY 2 - Emitter -> down -> 2 Layer, through hole.
                  2 - Emitter -> up , Left -> C letter ->
                  U3 pin 2 VSS -> C31
                  U3 - pin 1 (down) -> 2 Layer, through hole -> the other C31 pin
                  Testing U3 (Diode Mode) I get +- 0,56V
                  Other procedure to test this IC?
                  Regard,
                  Ruy
                  • megaraider
                    • Jul 2015
                    • 307
                    • Portugal
                    Regard,
                    Ruy
                    Some thoughts:
                    U3 is an IC, see the attached image taken from the datasheet.
                    Follow the 5 pins traces back to the connected points and test if it`s working.
                    Q5 is most likely a transistor. Remove it from the board and test it.
                    C31 was a capacitor... value and type remain unknown.
                    From the previous, and compared to other similar schematics, you should be able to sort it out.
                    • neuron
                      • Feb 2013
                      • 126
                      • Portugal
                      UT61E is ES51922 !!!
                      IC11 I can't find ...
                      DMM use Semico CS7721CN - Semico CS7721CN: UT60C, UT60A
                      Some thoughts:
                      Diode mode?
                      2TY - I don't need remove from the board.
                      All my DMM can test Transistors in Boards.
                      And where I can find that schematics?
                      In your attach XC61xx.PNG the cap between Vin and ground ... value?
                      Ruy
                      • megaraider
                        • Jul 2015
                        • 307
                        • Portugal
                        Ruy
                        See datasheet here.
                        • neuron
                          • Feb 2013
                          • 126
                          • Portugal
                          stj - the only info is MASTECH MS8250B (sigrok.org)
                          See datasheet here.
                          It's in japan. and no info about the cap ...
                          • televizora
                            ghettomodmaster
                            • Nov 2016
                            • 957
                            • Bulgaria
                            I wonder what happened so the PCB is so burned.
                            Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
                            1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
                            • neuron
                              • Feb 2013
                              • 126
                              • Portugal
                              Only C31 Burn
                              I power up and tested all function
                              V, Ohm, Hz, Diode, ºC, ... don't see any errors
                              Zero, Hold, Select.
                              Ruy
                              • megaraider
                                • Jul 2015
                                • 307
                                • Portugal
                                See datasheet here.
                                From the above datasheet, page 11:
                                4. Noise at the power supply may cause a malfunction of the watchdog operation or the circuit.
                                In such case, please strength the line between VIN and the GND pin and connect about 0.22μF of a capacitor between the VIN pin and the GND pin.
                                • eccerr0r
                                  lowest current galvanometer/analog meter (passively powered!)
                                  by eccerr0r
                                  Most analog meters are actually current driven - a current is needed to deflect the pointer full scale. They can be lots of different values. There are ones that can take several amperes to swing the pointer as they have internal shunts.
                                  On the other hand there are many that are rated in microamps for the intent that they draw as little power as possible from the devices under test. Some are 1mA, 500µA, 200µA, 100µA, and the ubiquitous 50µA frequently used in analog VOMs. There are even 20, 25, 30 µA and even down to 10µA. Been collecting a bunch of different ratings and...
                                  04-16-2025, 12:41 AM
                                • quickname
                                  Cyberpower 1500AVR UPS repair
                                  by quickname
                                  I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                                  Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
                                  I decided to verify that the batteries were...
                                  11-12-2023, 09:57 AM
                                • bauto601
                                  KDM 480W PSU upgrade succes! (opinions?)
                                  by bauto601
                                  Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                  A "nice" YoungYear unit? - Badcaps
                                  The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                  12-26-2023, 03:05 PM
                                • Baldbentley
                                  repairing a Fluke 335 clamp meter
                                  by Baldbentley
                                  I am repairing a Fluke 335 clamp meter. After contacting fluke it appears there is no service manual or circuit board/ component list available. I have determined that there us a faulty PNP bipolar junction transistors shown in the pictures. I am having trouble sourcing this transistor. I pulled a good one off of the board and tested it with my component analyzer but I cannot find anything that matches the specifications. Any help locating this part or a replacement would be greatly appreciated.
                                  Thanks...
                                  10-18-2023, 02:05 AM
                                • petehall347
                                  anyone recommend an earth leakage clamp meter ?
                                  by petehall347
                                  have been looking at earth leakage clamp meters and its like a minefield out there . i wondered if anyone here had bought one that actually works properly ?...
                                  04-17-2024, 01:31 PM
