Koban - Current Clamp Meter - DMM
    The factory / reseller ... don't know anything about the device (Schematic, Service manual, etc) and I need to repair this DMM - Clamp Meter.
    2TY - Transistor - Q5 (Diode mode ok)
    CHX ??? 5 Pins - U3
    C31 ??? Burn,
    Tested - V, Ohm, Diode, ºC ... don't see any errors
    Thanks in advance for all info
    Ruy
    Re: Koban - Current Clamp Meter - DMM
    CHX may be XC6116H028MR
      Thank you,
      I can't find PDF with that reference.
      Thank
      Ruy
        @neuron
        stj is most likely right! A simple quick search returns:
        Part No.: XC6116H028MR, SmdCode: CHX, Manufacturer: Torex, Package: SOT-25, Pin: 5, Memo: XC6116H028MR, Description: 2.8V Voltage detector, 0.1%, Delay time = 1.6s
        The datasheet may not be easy to find but that`s not your major concern, right?
        Either way, you can find here the datasheet.
          Originally posted by megaraider View Post
          @neuron
          Boa tarde megaraider,
          And the procedure to test ?
          The last letter ... is necessary?
          C31 no info?
          I can follow the tracks in the board and
          tested 2TY and all resistors around the C31.
          C31 in the board ...?
          Thank you
          Ruy
            mabe you can find a schematic for a similar meter with the same chip.
            Semico CS7721CN
            i also found this:
            "The CS7721CN is pin for pin compatible with Fortune Semiconductor FS9721"
            and a LOT of meter info is here:
            https://sigrok.org/
              A long list of chips, schematics, teardown, ... info on Multimeters (DMM):
              http://improwis.com/projects/reveng_multimeters/
              You can find a long list of devices using the CS7721CN chip along with detailed info.
              A very quick look pop-up UT61E (schematics) and Wintex TD2200, quite similar to UT61E. The later as "IC11: some tiny SOT-25 thing..." that might well resemble to the "U3" you found.
                ut61e has nothing in common with those chips.
                  Semico CS7721CN
                  i also found this:
                  https://sigrok.org/
                  Thank you stj, megaraider
                  2TY 2 - Emitter -> down -> 2 Layer, through hole.
                  2 - Emitter -> up , Left -> C letter ->
                  U3 pin 2 VSS -> C31
                  U3 - pin 1 (down) -> 2 Layer, through hole -> the other C31 pin
                  Testing U3 (Diode Mode) I get +- 0,56V
                  Other procedure to test this IC?
                  Regard,
                  Ruy
                    Regard,
                    Ruy
                    Some thoughts:
                    U3 is an IC, see the attached image taken from the datasheet.
                    Follow the 5 pins traces back to the connected points and test if it`s working.
                    Q5 is most likely a transistor. Remove it from the board and test it.
                    C31 was a capacitor... value and type remain unknown.
                    From the previous, and compared to other similar schematics, you should be able to sort it out.
                      UT61E is ES51922 !!!
                      IC11 I can't find ...
                      DMM use Semico CS7721CN - Semico CS7721CN: UT60C, UT60A
                      Some thoughts:
                      Diode mode?
                      2TY - I don't need remove from the board.
                      All my DMM can test Transistors in Boards.
                      And where I can find that schematics?
                      In your attach XC61xx.PNG the cap between Vin and ground ... value?
                      Ruy
                        Ruy
                        See datasheet here.
                          stj - the only info is MASTECH MS8250B (sigrok.org)
                          See datasheet here.
                          It's in japan. and no info about the cap ...
                            I wonder what happened so the PCB is so burned.
                            Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
                            1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
                              Only C31 Burn
                              I power up and tested all function
                              V, Ohm, Hz, Diode, ºC, ... don't see any errors
                              Zero, Hold, Select.
                              Ruy
                                See datasheet here.
                                From the above datasheet, page 11:
                                4. Noise at the power supply may cause a malfunction of the watchdog operation or the circuit.
                                In such case, please strength the line between VIN and the GND pin and connect about 0.22μF of a capacitor between the VIN pin and the GND pin.
