Tips after unsuccessful recap?
  • tnynyn
    • Jun 2005
    • 9
    Hey guys,
    Just recapped my Abit SA6R (jackson for rubycon) but seems it still wont post. Before the recap, I get a blank screen but everything still turns on. Same results afterwards. The LED and fans power on but it wont post with just cpu, memory, vid. I resetted the CMOS, battery, re-seatted the cpu, but still nothing. Any ideas (if i might of done a bad recap job)?? Any way to test the caps I replaced?
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Tips after unsuccessful recap?
    what was the status of the board before recapping?
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      vrm damage that happened before the recap.
      is the cpu ok in another board?
      with the cpu in the board measure the voltage across the caps near the cpu and post the readings.
      • tnynyn
        • Jun 2005
        • 9
        status of the board was same, powers on, no post. suspected of bad caps (leakage and bulkiness). cpu is in working condition (tested in another system) how do i measure the voltage on teh cap?
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          turn it over while connected to psu.
          power on and test with v.o.m on low dc v range.
          • tnynyn
            • Jun 2005
            • 9
            ok here are the readings:
            2x 1.668 (closet to cpu)
            1x 1.5
            1x 1.8
            rest are 3.3 and 5.0
            • tnynyn
              • Jun 2005
              • 9
              also, the heatsink doesnt seem to be hot after powered on. Im using the stock socket 370 p3 heatsink (very small aluminum type w/ 40mm fan)
              heres the specs:
              Abit sa6r recapped w/ rubycon (18)
              p3 800 (pulled from a different working system)
              128 pc133 memory
              antec 350w
              • tnynyn
                • Jun 2005
                • 9
                ok forget about teh post above, but i think i recapped it wrong. the caps before were 1500uf 6.3v but i used 1500uf 10v on all caps. is there certain caps that i am supposed to keep it at the same voltage?
                • willawake
                  Super Modulator
                  • Nov 2003
                  • 8457
                  • Greece
                  i dont see a problem there
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    using slightly higher voltage caps wont hurt a thing.
                    voltage readings suggest the vcore is ok.
                    without the board on my bench its hard to troubleshoot further.
                    i would verify any parts you are using by testing in a known working system.
                    clear the cmos esp since fsb/multiplier ect are set there.pop out the battery and let it die a few hours.
                    • tnynyn
                      • Jun 2005
                      • 9
                      WOOOOOOHOOOOOOOOOO!!!!!!!!!
                      Got it to work!!!
                      Did what kc8adu said, left the battery out, put it on clear cmos for TWO days before I got around to testing it again. This time, did one thing different, left the cpu fan unplugged from the mobo. Fired it with just cpu and heatsink and heard the sweetest music ever: beeps indicating no memory.
                      THANK YOU GUYS FOR THE ADVICES!!! If I never stumbled on this forum, would've thrown out 3-4 boards.
                      • willawake
                        Super Modulator
                        • Nov 2003
                        • 8457
                        • Greece
                        great, another happy ending. good work guys.
                          ASUS P5GC-MX motherboard recap
                          by momaka
                          Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                          This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                          So here is what the motherboard looked like with its original caps:
                          CPU VRM area up close…...
                          01-27-2021, 11:59 PM
                        • estabilito
                          Tips geting oxidized when using wick
                          by estabilito
                          Hi, i have weird problem - when i'm using soldering wick to clean BGA balls under CPU or PCH on motherboard my tips(different types) getting oxidized very fast and lost all power.
                          i Was trying different types of wick, flux - no difference. I can't even clean one full socket and i need to use deoxidizer in half-time.
                          Temperature: 350-365celsius
                          station: jbc cd-2bqe
                          Wick: edsyn
                          flux: warton hf rework jelly
                          Do you have any tips?...
                          04-12-2025, 11:55 AM
                          no-name Radeon 9600 XT recap and cooler
                          by momaka
                          I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
                          This one was actually suggested to me by ChaosLegionnaire....
                          11-06-2020, 07:54 PM
                        • laskr1999
                          DFI Lanparty NF3 250GB complete recap help
                          by laskr1999
                          Hello!
                          I have got a DFI Lanparty NF3 250GB motherboard, that have all of the capacitors failed, board still working.
                          I have read, that I need to match ESR, Capacitance, Voltage to have a quality recap, but with ESR im in a problem. 0.012 ohm is what i see on the vrm caps specs, but lowest I could find is 0.018 and up, usually 0.04. Can someone help me find good replacements?
                          I'm located in EU, and I have found a guy here on the forums who listed the caps, so here are they:
                          - 20 x Nichicon 1000uF 6.3v HM 105C
                          - 5 x Chemi-con KZG 1000uF 10V
                          - 1 x Chemi-con KZG...
                          Today, 03:27 PM
                        • Shredder11
                          BoardViewer Files Needed For M-Audio Ozonic Firewire Keyboard Audio Interface + Any Repair Tips
                          by Shredder11
                          As per title and also any tips on what to test first would be welcome on fixing this keyboard, which worked 100% and then upon the next power on, no display or response from keys, buttons, sliders, dials etc. However the Firewire audio interface section still works.
                          Thanks.
                          10-14-2025, 01:42 PM
