Tops of resistor have seperated
  • Amraks
    • Nov 2011
    • 725
    Hey need a temporary solution for a emergency repair on these resistors this will not be long term but it will need to last a weekend in a cross over circuit. as I can't find these 66 ohm 20w valued resistors in Australia. The resistors are reading fine but I'm wondering what type of bonding I can use to stick these back together.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Tops of resistor have seperated
    Usually some sort of kiln fired ceramic is used to attach the two together and it had failed.
    If all you have is plastic glues which won't work well at the temperatures we may be dealing with here, I'd suggest you look for a small fan and blow air across them, probably would be sufficient to run a little while - that is if the fan is not physically an option?
    (JB Weld might be last resort option... but regular epoxy probably won't work well.)
    • petehall347
      • Jan 2015
      • 4426
      • United Kingdom
      thermal adhesive might work .bit expensive though
      • Amraks
        • Nov 2011
        • 725
        JB weld might be a go yet.
        would 3x 22 ohm 10w resistors in series work?
        to replace the 2x 66 ohms resistors which are in parallel dividing it up to 33 ohm.
        then the 10ohm 20w.
        could I use 3x 3.3 ohm 10w resistors in series.
        I have fixed another one of his crossovers and they done something similar and it seems to be working.
        This only has to work for a weekend or two I really do want to refurbish the lot of his crossovers with right spec resistors and must likely keep at least 2 sets of spare resistor in stock, if an accidental drop occurs again.
          • 31015
          test it as-is,
          the ceramic is not really going to disapate heat anymore than convection - it's more of a protective cover.
          just make damned sure you dont let any wires drape over them!
          • megaraider
            • Jul 2015
            • 307
            • Portugal
            NO (30W is less than 20+20=40W)!
            But you can replace each 66 Ohm resistor with 3x 22 Ohm 10W
            then the 10ohm 20w.
            Yes! (It will only be 1% less resistance than original, but well within the tolerance).
            Knowing Australia is a hot weather country and never seen power resistors failing in such catastrophic way
            curious to know in what device it's being used? (or are they overrated Chinese ones?)
              • 31015
              maybe the bass caused the cement to crumble.
                master hoarder
                • May 2008
                • 12170
                • Bulgaria
                I don't know if this will work, but maybe worth the suggestions anyways: clay (for potting) from any arts & crafts store?
                The dirt we have here in some parts of VA is pretty much straight-clay. Some years ago, I "potted" a piece of NiChrome wire with it in a big can. After it dried, I ran current through it to heat it up. Clay dried up and hardened nicely. I used that for making my first "solder pot", in fact (the pictures are somewhere here on BCN, but I don't remember where and what thread.)
                • Amraks
                  • Nov 2011
                  • 725
                  This is what I meant sorry for the confusion. so 2x 3x 22 ohm we will get 2x 66 resistors.
                  I am in Tasmania we are in a cold climate down here in the southern end.
                  the way it broke was it was dropped while it was being set up by someone I guess this part took the brunt of force..
                  but I believe someone has repaired it with hot glue previously and this time the glue they used has become conductive as I was missing 5 ohm on the 10 ohm resistor testing out circuit.
                  removed that piece of hot glue and the resistor was right.
                  • petehall347
                    • Jan 2015
                    • 4426
                    • United Kingdom
                    hot glue is no use as the heat will soften it . am wondering if plaster of Paris would stick the ceramic back on .
                    scrap that idea .looked it up and its not good at thermal conductivity
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      High temperature grout for fireplaces and flues. Comes in 300ml cartridges, 1200c.
                      Like this https://www.screwfix.com/p/mapei-map...ey-300ml/25153
                      • petehall347
                        • Jan 2015
                        • 4426
                        • United Kingdom
                        will it conduct the heat away from the resistor ?
                          • 31015
                          probably not.
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8701
                            If you want to "fix" the resistors, make sure you desolder and set them in with gravity, let the weight of the potting material and the resistor cores to let any air bubbles out.
                            • megaraider
                              • Jul 2015
                              • 307
                              • Portugal
                              That explains it all...
                              btw guys: all suggestions are welcome,
                              but if @Amraks can't get access to simple power resistors, on a short time and where he is located, how the hell will we find 'fancy' glue stuff
                                • 31015
                                well he could use "exhaust putty" from a car place - but i wouldnt bother as i said.
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8701
                                  JB Weld (make sure it's the high temperature kind )
                                  • Amraks
                                    • Nov 2011
                                    • 725
                                    Could of got JB weld. I opted for the option of resistors in series.
                                    Funny thing passive mode works but Bi mode is not working. Its working on all the other crossovers that have had resistors put in series.
                                    I wonder what else is broken now.
                                    • Amraks
                                      • Nov 2011
                                      • 725
                                      Thanks for all the suggestions.
                                      I opted for the later option of fixing, I ended up making 2x 66ohm resistors by using 3x 22ohm 10w resistors in series for each broken 66ohm.
                                      for the 10ohm one 3x 3.3ohm 10w resistors in series
                                      • Amraks
                                        • Nov 2011
                                        • 725
                                        found the problem with the crossover in bi mode someone had cut the bi mode capacitor lead and done a average job on trying to connect it again.
                                        I tinned up a bit of wire and inserted it into its hole and soldered the remaining bit of the lead to it.
                                        • TinkerTron
                                          Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                                          by TinkerTron
                                          Hey everyone,
                                          I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                                          Instead, here's what's been bugging me so far:
                                          The schematic...
                                          03-06-2025, 02:03 PM
                                        • artvandalai
                                          What resistor ohm will work better to repair this waterpik?
                                          by artvandalai
                                          The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                                          01-05-2025, 04:10 PM
                                        • chth96
                                          Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                                          by chth96
                                          I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                                          Since then, This AC/DC adaptor have been out of order.
                                          But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                                          After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                                          And Is there any possibility that it will suddenly explode as well as to be out...
                                          12-03-2023, 04:40 AM
                                        • flat-earther
                                          Hoover FM216LI cordless vacuum refuses to charge
                                          by flat-earther
                                          I have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
                                          I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
                                          5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
                                          So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries....
                                          06-06-2025, 03:14 AM
                                        • badcap111
                                          Xiaomi mi 9T missing resistor
                                          by badcap111
                                          Hi, while trying to replace a broken screen connector on the motherboard, I knocked off a resistor next to the connector, and the resistor vanished. I have tried to find out the value of the resistor by looking at the schematics, but I cannot find the value. The ID of the resistor, or what you should call it, is R6400.
                                          I don't know if the resistor is necessary for the phone to function, and the connector is still not soldered on to motherboard. I have contacted Xiaomi and asked them if they know the value, but they want a proof of purchase, which I don't have.
                                          Is...
                                          08-07-2023, 10:42 AM
