Achi IR6000 rework station issue. Please help?
  • Weelcup
    TopTech
    • Oct 2017
    • 307
    Hi
    I have an Achi IR6000 rework station. It was working normally until recently. It does ramp the temprature very slowly on the top heater.
    Precisely, on the Heater temperature controller LCD, the SV only added up 1C° when the PV reaches the SV temp. For example, the SV will only change from 25C° to 26C° if the PV reaches 25C°. Therefore, the difference will only remain 1C° during the rework process.
    Now, this sounds OK at lower temperatures but as soon as the temp is above the 200C° The it take ages to ramp up. Imagine the top heater is 201C° and the temp on the chip is 200C°. And you should wait for the 200C° to ramp to 201C° before the top heater "SV" temp temp to 202C°. Insanely slow at this stage.
    So basically there is not respect to the ramping time on this device.
    Therefore, I would very appreciate if someone helped me to fix this issue. Maybe to reset the PC410 temperature controller or configuring some of its setting. But I have a limited knowledge about that.
    Thanks in advance.
  • pecrie
    • Nov 2011
    • 182
    Re: Achi IR6000 rework station issue. Please help?
    Have you read the posts of IR6000 in the other forum ? Look in the Equipment , soldering , heat stations - forum on here.
    In the Badcaps main forum folder ...
    • Weelcup
      TopTech
      • Oct 2017
      • 307
      Thanks for the replay. Yes I did. but I could not find any post referring to any sort of reseting the PC410 (the temp controller). or experiencing such issue.
      • jasko_jacker
        • Oct 2014
        • 1140
        • italy
        You have to do some tests:
        The ssr relay could give these problems but first
        test the REX C100 without the top heater and check that the temperature rises correctly.
        Also check the top heater, without the altec pc410, you should warm up very quickly.
        The altec pc410 cannot be reset. You can test it with the program on their website -> AL808 communication test software (.rar).
        If the altec has problems and you have to buy it, pay attention to the seller, there are models that, being clones, are not compatible with your station
        • Weelcup
          TopTech
          • Oct 2017
          • 307
          Thanks for the great information. I will try to test the controller first with the mentioned software. And will come back with the results.
          Thanks again
          • dellxps15
            • Feb 2014
            • 1598
            • italy
            1st u shoud see if top heater actually heat..... after starting the process, with ur hand touch all heater and see if they get warm but ofcourse take care of hot temperature.
            if all heaters get hot then its probably a software problem.
            • Weelcup
              TopTech
              • Oct 2017
              • 307
              Thanks for the reply.
              Yes the top heater is heating up. But it heats up in relation with the actual temp. I mean the top heater increases by "exactly" one degree if and only if the actual temp on the board matched the degree on the top heater.
              Which I also assume a software problem.
              I was suggest a software to check pc410 by :jasko_jacker" but the software is only in chinese lang and I spend so many hours on the net to find or translate it but no luck. So still no idea if replacing pc410 will help or not. And pc410 is relatively expensive so I need to be sure it is the cause.
              Thanks again for your advice.
              Kind regards
              • dellxps15
                • Feb 2014
                • 1598
                • italy
                also check if top heater distance from pcb is correct. that ir6000 is a cheat bga rework, maybe there is not a proper profile in it but just it warm all heater same way and only height make difference.
                just my opinion, dunno how an ir6000 works and im just thinking about all possible common problem.
                • Weelcup
                  TopTech
                  • Oct 2017
                  • 307
                  Thanks for the reply. I see your point.
                  The thing is that it was working absolutely fine before. And this issue occured suddenly.
                  I used to connect it to laptop and use the ir6000 software to monitor the temp graph. And was working fine.
                  However, I tried to obtain bottom side thermal sensor readings but I had no luck. I was suspecting the pc410 controller.
                  I believe I will try to buy and fit another pc410...
                  Thanks again for you reply..
                  • lazaro.089
                    • Jun 2014
                    • 87
                    • Mexico
                    pc410 has an internal config menu. In this video it tells you how to factory reset.
                    https://www.youtube.com/watch?v=GYLINvukFHU
                    • Weelcup
                      TopTech
                      • Oct 2017
                      • 307
                      Thanks for the advice.
                      All these sttings are similar to the ones on my pc410.
                      Nothing has changed.
                      Still has the issue.
                      • jasko_jacker
                        • Oct 2014
                        • 1140
                        • italy
                        Have you check the SSR relay ? (try exchanging relays one with another).The Led on it goes on and off ? All hardware outside the controller is very simple:
                        Check heater with multimeter in ohm
                        Regard thermocouple see if the controller shows the correct temp. Don't use pc , remove connection and use controller directly.
                        As I said the altec pc410 is not resettable or reprogrammable even you desolder the micro, you can only change the setting to a manifacture values.
                        If all hardware outside controller works fine probably you should buy another altec. The value on bottom side thermocouple regard rex controller and this circuit is separate from altec. If you disconnect rex the top must work anyway
                        • Weelcup
                          TopTech
                          • Oct 2017
                          • 307
                          Thanks for the reply. I will check it this week hoping it is not the pc410 that is causing the issue.
                          Thanks again
                          • Weelcup
                            TopTech
                            • Oct 2017
                            • 307
                            Hi again
                            some how I think the pc410 was not working correctly at the beginning but it working now. apparently what was worsening the issue is the bottom heater which was ramping up very fast. so the top heater, in my consideration, was following the same pattern even after 190C.
                            in other words, because of the bottom heater heating very fast, the top heater only needed a very little power to follow the profile. most of the power was laying on the bottom heater. so when the bottom heater stops on 190C the top heater had to consume much more power than the whole process from starting. here the top heater was not able to do so for some unknown reason. so it was keeping the same power pattern as what it started with.
                            I got to this conclusion because when I manually control the bottom heater during the process to reach the 120C first then waiting for the top heater to pass to 150 then increasing the bottom heater to 180C during the process. the top heater works as it should. no slow ramping at all... and worked well …
                            just wanted to share this solution with you friends...
                            best of luck...
                            • koesoeng9
                              • Aug 2017
                              • 17
                              • indonesia
                              Re: Honton HT-R392 rework station issue. Please help?
                              can anyone help?
                              problem in the upper thermostat in the standby state the power output is 220vac. within seconds the upper elements flushed instantly. I have tried to change the SSR, the problem is still the same.
                              • mon2
                                • Dec 2019
                                • 14720
                                Hi. Just want to ask...have you attempted to contact the manufacturer of the tool? From the many visits to trade fairs in Asia, most of them claim to take pride on their service and support mechanism to retain you as a life long customer.
                                As an example, I recall meeting with BEST Tools in HK about 2 years ago and only recently purchased their hot air tool to replace an aging Weller setup. Amazing device and at a very fair cost with DHL shipping to Canada. Works great on multilayer PCB repairs (ie. macbook, etc.). Had a quick chat with the factory and they stated that all parts are available to service this hot air tool or any other widget we wish to purchase from them.
                                I would think that you will be able to source the spare parts directly from the manufacturer.
                                If not, then consider to service at the component level.
                                • Weelcup
                                  TopTech
                                  • Oct 2017
                                  • 307
                                  Thanks for the great advice. I probably had to do that. But i have already modified the device. I.e. the top and bottom heaters were replaced now. And i manage to modify my profile. Seems to work ok now. I just adapted with. Besides, i am not doing much work on it recently.
                                  I will consider that option. I really appreciate your help.
                                  • longmax
                                    • Dec 2021
                                    • 4
                                    • Romania
                                    Hell, can anybody help me with some profiles for scotle ir6000 rework station?
                                    Thanks!
                                    • shahnld
                                      wds-580 rework station issue
                                      by shahnld
                                      Good day.
                                      i received used bga rework station wds-580 which was not going above 300c despite the parameter was set to 350c, Everytime beeps at 300c so i did a factory reset and by mistake washed data and log etc. now the station boots to a white screen.
                                      Does anyone has a firmware for this station and want to share with me. i will really appreciate any help possible..
                                      kind regards...
                                      03-28-2024, 01:14 PM
                                    • minimania
                                      Need Schematic for jbc am6800 rework station
                                      by minimania
                                      hi all im looking for a Schematic for jbc am6800 rework station
                                      mine has stopped working fully
                                      it started with turning off when switched on then after a few off and ons it worked sort of for awhile
                                      now it wont turn on at all...
                                      01-28-2025, 03:44 PM
                                    • Peter_1402
                                      Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
                                      by Peter_1402
                                      Hi Everyone,
                                      I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
                                      1. Soldering iron works great
                                      2. There is a burnt mark on the hot air gun handle.
                                      I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
                                      Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
                                      Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
                                      Reed switch tested ok with a magnet.
                                      From the above test, I can conclude...
                                      07-12-2025, 11:50 AM
                                      HP Station de travail Z2 format tour G4 i7-8700 Specification for Upgrade or Repair
                                      This specification for the HP Station de travail Z2 format tour G4 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Station de travail Z2 format tour G4 boardview and Station de travail Z2 format tour G4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                      09-12-2024, 02:20 PM
                                    • livo
                                      ACHI IR PRO SC bga rework profile needed
                                      by livo
                                      Hi, so I do console repairs normally, but I have a friend that needs me to reball their 2080ti GPU, does anyone have a profile for the ACHI IR PRO SC they could share. I know i my need to adjust is slightly to match my machine, I don't have any other GPUs to run a test on to build a profile. Thanks inadvance
                                      11-14-2023, 05:36 AM
