Hi
I have an Achi IR6000 rework station. It was working normally until recently. It does ramp the temprature very slowly on the top heater.
Precisely, on the Heater temperature controller LCD, the SV only added up 1C° when the PV reaches the SV temp. For example, the SV will only change from 25C° to 26C° if the PV reaches 25C°. Therefore, the difference will only remain 1C° during the rework process.
Now, this sounds OK at lower temperatures but as soon as the temp is above the 200C° The it take ages to ramp up. Imagine the top heater is 201C° and the temp on the chip is 200C°. And you should wait for the 200C° to ramp to 201C° before the top heater "SV" temp temp to 202C°. Insanely slow at this stage.
So basically there is not respect to the ramping time on this device.
Therefore, I would very appreciate if someone helped me to fix this issue. Maybe to reset the PC410 temperature controller or configuring some of its setting. But I have a limited knowledge about that.
Thanks in advance.
Thanks in advance.
