Hi, so I do console repairs normally, but I have a friend that needs me to reball their 2080ti GPU, does anyone have a profile for the ACHI IR PRO SC they could share. I know i my need to adjust is slightly to match my machine, I don't have any other GPUs to run a test on to build a profile. Thanks inadvance
ACHI IR PRO SC bga rework profile needed
For this type of intervention, the power of the bottom heater is very important. I think your machine has an IR top heater and not an air one and this could be a problem. The profile I see seems slightly too low in terms of temperature at the end of the process. The temperature on the sides of the GPU during removal must not be lower than 235 240 degrees celsius as there are areas that absorb a lot of heat. What software do you use? can you post a photo of the machine and the bottom heater thermocouple?Comment
Helo, I have just purchased the CHI IR PRO SC, termo couple standard. Before I had a chance to do any test I already have a work on it. Before I do a mess, can anyone help me out with this one please and share the prifile?
Acer KAV10 LA-7781P bosad
To desolder is a Intel's 945GSE Express ChipsetComment
REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
- No Clean Formulations
- Low residue
- Range of activity to deal with different component solderability
- Halide free
- Suitable for dispensing
- Compatible with solder coatings and/or No Clean flux cored solder wire product range
Both products are supplied in syringes or cartridges for application by dispensing....-
Channel: Common Parts Library - Datasheets
10-07-2024, 06:02 AM -
by WeelcupHi
I have an Achi IR6000 rework station. It was working normally until recently. It does ramp the temprature very slowly on the top heater.
Precisely, on the Heater temperature controller LCD, the SV only added up 1C° when the PV reaches the SV temp. For example, the SV will only change from 25C° to 26C° if the PV reaches 25C°. Therefore, the difference will only remain 1C° during the rework process.
Now, this sounds OK at lower temperatures but as soon as the temp is above the 200C° The it take ages to ramp up. Imagine the top heater is 201C° and the temp on the chip... -
BIOS file needed
HP PROBOOK 445 G6
DA0X9KMB8E0 REV E
S/N 5CD92213CN
No backup available-
Channel: BIOS Requests ONLY!
by moscastHi everyone, I recently purchased a BGA machine (ACHI IR PRO SR, 2400W IR Bottom and 450w IR Upper) but I don't know how to create the processing profiles. I need to desolder a faulty GPU on a laptop.
As software I was thinking of using this:
https://www.badcaps.net/forum/troubl...hi-ly-by-psoft
Can anyone tell me the most suitable or common heating curves for soldering and desoldering?
Thank you -
by karim011Hi everyone. Plz needed bios file For Acer Nitro N50-620
- Motherboard DIB56L 202019-1 348.0EZ07.0011-
- Loading...
