Pre-heating your motherboard.
  • Neo2_000
    • Apr 2005
    • 180
    Hi y'All.
    I have just bought a new temperature controlled soldering station.
    When de-soldering PCB joints positioned in large copper lands, I find it takes considerable time (6 to 8 seconds) to get the solder to melt because of the considerable heat drain, even at high temperatures.
    So I am going to experiment with pre-heating the motherboard using home appliances like my gas oven or a hot air hair-dryer.
    Has anyone tried this before or can anyone offer advice from personal experience?
    Must be someone else out there bent enough to try this before!
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: Pre-heating your motherboard.
    Don't do that. Simply reflow some new solder into the joint, that'll melt it fast.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      i dont like either idea, with an oven it would be difficult to control the exact temperature and also if your oven is anything like mine the temperature is not constant all over the oven and is excessive in some places. plus you would be cooking some components which are sensitive to certain temperatures. bad idea.
      like i said before, the hairdryer probably would not be hot enough. paint stripper heat gun would be good and there are references on the net to people doing smt work with them. i assume it would be best to heat up the rear of the board using it. still dangerous though unless you know how much heat you are applying.
      KC8 was talking about pre-heating one time.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        using a heat gun in moderation is fine.
        just watch out for plastic hsf clips like used on chipsets.
        i have done this on 6-8 layer boards where a really hot iron threatened to lift traces before the solder would melt completely down the hole so the desoldring machine could suck it out.
        if you severely overdo it you can have smt stuff lying on your bench afterwards!
        • Neo2_000
          • Apr 2005
          • 180
          Thanks to all for helping with advice.
          I bought the iron from Computronics in Perth.
          I spoke to a rep from Computronics today and explained to him the difficulties I was experiencing: Even after applying heat for considerable time with the iron on a difficult joint, the cap will often emerge with a solder cast of the joint attached to the lead. I find this very worrying and this is what he advised.
          He reckons that I should only be running the Hakko at 350 degrees C.
          We discussed the optional "high thermal mass soldering tips" which provide more stable heat delivery and I ordered two different styles.
          He also offered to sell me a professional pre-heating unit for A$450 which I graciously declined. He said that they work on heat convection supplying a temeprature of 100 to 150 degrees C and take about 2 to 3 minutes to heat up a board.
          Based on this I have tested my free 1000W hair dryer. It will heat up a temperature probe to 100 degrees C in 30 seconds. Another 30 seconds will produce 130 degrees C which is approaching it's limits. This is also within the suggested range recommended by kc8adu using his heatgun method so I will give it a try.
          Looking at the gas oven, it's minimum setting is 120 degrees C. If I were to preheat the oven to this, then turn it off and let it stablize before placing the motherboard inside for a conservative minute or two, I am thinking that this would be a reasonable replica of the professional heating unit. But maybe the griller would be better since it would not supply heat to the component side of the board. I can just hear the laughter as you are reading this!
          I will experiment with some old discard boards before committing to any one method but admittedly the hair-dryer would be more convenient if it works.
          Topcat: Don't do that. Simply reflow some new solder into the joint, that'll melt it fast.
          I will also give this a try. For the sake of comparison, I would be interested to know what soldering station are you using TC and it's power rating.
          Dickin around with all this funky stuff - I feel just like the guys on Myth-busters lol - assuming that you guys get that show on your TV.
          Feel free to offer any comments, criticisms, sarcassams, ridicule, referrals, etc. etc.
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            the rep is spot on. nichicon recommend 350oC+/-10oC for 3 second.
            and that would be recommended for installing new caps. the old ones you dont care about damaging. for removal, there is more concern about dwelling too long and damaging traces so fast in and fast out at high temp.
            i hope you have more success with your new tips. i feel bad that you are not happy with your new station. I think you will have more success adding solder to the joints before you remove the caps. personally i cant work without doing that.
            your hairdryer is unexpectedly hot, tell us how it works. the oven is still a BAD idea....
            • Neo2_000
              • Apr 2005
              • 180
              Thanks Willawake, talks a bit about pre-heating (caps?) there too.
              Pre-heationg : Less than 150°C, 90 seconds max.
              Don't get me wrong, it's not that I am unhappy with the new iron. I realise that I just have to work out the correct proceedures to use it properly. On regular joints, it works great. It's just the ones in the large copper lands that present a problem at this stage.
              In contrast to my old Scope Iron, I feel that the motherboard is very safe when using my new iron but your point about dwelling too long on a joint and the associated risk of damaging the bord is my main concern. The resulting solder cast on the extracted cap lead after six to eight seconds on a difficult joint at 450 degrees worries me. So my aim is to reduce the dwell time and improve the solder flow.
              In regards to applying solder to the joint. Are you just applying it to the tip of the iron before use or do you actually apply it to the joint jsut as you would when soldering a new component in place?
              Using this technique, how long would you typically dwell on de-soldering a large landmass joint and what would you consider to be the maximum safe dwell time at 450 degrees C?
              Sorry for sounding like a rank novice but this is just what I am with this new iron.
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                you should always apply a small amount of solder to the tip of the iron and then wipe it off on the sponge (or flick off the excess) before starting. the procedure is called tinning the iron. i am sure you know that anyway
                you heat up the joint and then add a dab of new solder directly to the existing solder on the joint.
                still figuring out that one myself.
                • acedogblast
                  by acedogblast
                  11-02-2024, 05:13 PM
                • glovecaps
                  by glovecaps
                  11-25-2024, 04:23 PM
                • Docus
                  Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                  by Docus
                  Hi everyone 😀,
                  I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                  To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                  Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                  1. I already own the exact same model, but its plastic chassis is badly damaged.
                  06-10-2025, 04:24 PM
                  ASUS P5GC-MX motherboard recap
                  by momaka
                  Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                  This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                  So here is what the motherboard looked like with its original caps:
                  CPU VRM area up close…...
                  01-27-2021, 11:59 PM
                • dhenion
                  Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
                  by dhenion
                  I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
                  The original board was:
                  ASUS X510UNR REV 3.0 A
                  The replacement board is:
                  ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
                  It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
                  01-30-2024, 01:45 PM
