Recommend me a MultiMeter
This topic is closed.
Re: Recommend me a MultiMeter
FLUKE 17B
Made in China
http://www.dealextreme.com/details.dx/sku.28659
Wrong! Only the low end models (sub $150) are made in China.
The 70 series and higher are still made in the US.
Honestly when I opened a China model they were still as well built as the USA Flukes beautiful flawless soldering, dead on component placement, and not a drop of flux to be seen. They definitely made an effort to keep the quality up overseas.Last edited by Krankshaft; 11-12-2010, 02:07 AM.Elements of the past and the future combining to make something not quite as good as either.Comment
Amazing that someone that's too cheap to buy a -real- ESR meter looks for ads for DMM's that cost over $200.Mann-Made Global Warming.
- Dr Seuss
I personally use
http://www.kew-ltd.co.jp/en/products...ers/1109S.html
I personally use
http://www.dyinstrument.com/duoyi/?q=node/33
http://www.jestineyong.com/?p=2841
http://www.jestineyong.com/?p=2851
lol my first multimeter was his:
http://www.electronicplus.com/images...cts/DT860D.jpg
got it for $19.99
but it fried iteslf (nothing i did, i just measured a cap and it died!)
now i have some $15.99 analog multimeter that i have no clue how to use
something similar (not same) to this:
http://www.google.com/imgres?imgurl=...t:429,r:10,s:0Comment
How did you use your multimeter to measure a cap?lol my first multimeter was his:
got it for $19.99
but it fried iteslf (nothing i did, i just measured a cap and it died!)...
What range did you have it on?________________________________________________
Invisible airwaves crackle with lifeBright antennae bristle with the energy________________________________________________Comment
Very good multimeter.
http://gsmserver.com/shop/equipment/...t_mt_2007n.php
by aaronkatriniHi all,
- Autorange
- DC volts up to 30V
- Accurate Resistance
- Diode test (Beep mode)
- Frequency up to 200MHz
- Capacitanze up to 5000uF
- as cheap as possible
Other functions are not needed but those which are needed... -
by dj8452000I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
by trex66My daily carry just stopped working only me. Started last week with the voltage flickering. Found one lead was broken and I ordered new ones. New leads didn't change anything, it displays “-1” on all settings but on continuity will give the tone when touching. Checked battery and found the fuse blown. Replaced fuse but same results. Cleaned the dial and led display and its parts. Board looks nice and clean no burned or broken components. Nothing traumatic happened to this multimeter I put it aside when I found the lead broken and didn't touch it until I got the neAnyone have any ideas what's...3 Photos
by Sofian75I started to learn laptop repair a few weeks ago, since then I ve ordered several dead laptops to try to fix them and learn.
I fixed some of them and some I ve made things worse by blowing components.
Every time while taking measurements with my multimeter.
Yesterday I was working on a dell laptop motherboard, I was checking the charge IC for short in diode mode and it killed the chip.
So my question is are there things I should not do with my multimeter?
Or measurements I should do only with the charger and battery unplugged?... -
by max_smartHi all,
First off, this forum really helped me out by advising me to cut some ribbon connectors to the LCD panel in order to fix a 70" TV (lots of threads on Sharp TVs with this issue). I didn't believe that it could work, but it did.
Now I've been encouraged to try to diagnose something quite a bit more complicated. That is an old T430 motherboard. I work on a college campus so I have access to pretty decent tools. I found the schematic for the motherboard on the site, and have been following traces and taking DC measurements from things. I also don't mind...3 Photos - Loading...
