Re: KSGER STM32 T12 soldering stations
Did you get this soldering controller to work again or is it history
But if you have a hot air gun put a very small nose cone on air gun and point it away from the main controller board and go around in a circle until the solder melts and bang on the table to nock most of solder off it you might have to do a few times or when the solder melts pry up on the board until you clear the boardLeave a comment:
The GX12 has 1.6mm pins and the desoldering tools I have couldn't clear the holes. No tips fit over the pins close spacing. I thought hot air would melt everything around it like the JST power connector and capacitor, buzzer?
The temperature I am talking about is always displayed on the bottom right, even if the handle is unplugged and ERROR is up.
When the handle is unplugged it goes to the default value from menu 4.
I suspect the firmware 2.10 got a sneak update or they programmed the STM32 wrong, as the hardware works fine on the defective controller.Leave a comment:
That funny because the version I have which is the 2.1 if you do not have the soldering iron hook up it shows error message on it which I prefer and not some temperature
Because I was able to remove the one on one of mine it was a little bit difficult but not impossible to do I had to more solder on the joints a couple times and then I was able to remove it
But come to think about I also think I had to use a temperature controlled hot air gun to help it along as wellLast edited by sam_sam_sam; 06-30-2019, 11:57 AM.Leave a comment:
Anyone know the T12 handle components? They ship two NTC thermistors and two different motion switches, a ball shake switch and a mercury switch.
The black blob NTC I have only seen on a controller board and the glass MF58 part I used. The 0.1uF cap sometimes across the NTC, other times across the heater, the handle wiring is always different.
Got a replacement T12 controller board V2.1S and the cold-junction temperature is now working. Display shows !24°C if the handle is unplugged, where the old one was just stuck at what was entered at the cal menu.
Impossible to desolder the GX12 connector, I had to trash it to get the board out.Last edited by redwire; 06-30-2019, 10:03 AM.Leave a comment:
Yes I agree with you about that I am surprised that this was doneLeave a comment:
That's the better one, it's still pretty good for stuff out of china, with the usual couple of weak points.
I think most important is adding a PE ground wire from the IEC outlet to the chassis.Leave a comment:
I have the version the one on the right side of the photoLeave a comment:
A person could grind off the fin on the heatsink for more clearance. I used Kapton tape and lifted the heatsink up a bit, it does have sharp edges which would cut solder mask.
It really does take several seconds to light up the red LED on the 24V rail. Not as long if you switch it off and then on.
I can't find datasheets for the CR8642S PWM IC. It has 1.5MEG HV DC feed and 22uF 50V cap, so I'll bet it's taking its time charging that to start up. Or a 120VAC version needs a lower resistor value. It's kinda weird. Voltlog is 240VAC so maybe that is covering it.
edit: Changed out the 22uF 50V 105C Chong-X capacitor. It tested fine. No difference in 3 second start-up time. Power-off it quickly goes from 16V to 9V and takes many minutes to discharge to zero. When it still has charge, next start-up is quicker, maybe 1.5 seconds.Last edited by redwire; 06-12-2019, 03:36 PM.Leave a comment:
btw, i dont think it does take a few seconds to power up,
i saw a video - may have been VoltLog, with a meter on the output.
the psu startup was instant but the controller firmware took a few seconds to init the oled display - maybe while it averaged some samples from the thermocouples.Leave a comment:
Which of one of photos is a good quality one let see if the one I have is a good one or I should use the medical grade switching power supply that I just bought and change the low voltage power cord onLeave a comment:
It's a good power supply. Just the two issues with 100V snubber cap and heatsink on the HV pcb trace, and it takes a few seconds to power up which is strange. KSGER sells it with their better soldering stations.
Actually you don't need 3A for very long, just bursts.
There are a few other T12 soldering station PSU's out there- this one pictured below is what I consider not very good. KSGER, Quicko, Banggood sell them too. At $12.50 it is $1.50 USD cheaper than the previous one.
It has 1A rectifier diodes, small heatsinks, very small primary caps 22uF 450V each, super thin PE GND trace. Runs hot, high stress on parts and not for heavy duty use.Leave a comment:
I have to wonder how long this switching power supply would last if you ran it 5 or 6 hours a day 5 days a weekLeave a comment:
Semi's are isolated TO-220 parts (fullpack), but the heatsink mounting pin pads have very little clearance to the fills. So the path is PCB trace->heatsink->mounting pads-> nearby pours.
I'll put Kapton tape over the two traces if I can fit that in.
The older version 24VDC PSU (left) is apparently not very good. Primary capacitors are low value 2x22uF, 1A diodes instead of 8A bridge, no 3A fuse but a 1R resistor in heatshrink. The Schottky rectifier runs 112C at steady 3A. Quicko sells them too.
But it has to put out 3A for short periods.Leave a comment:
are the heatsinks insulated? the semi's are.
it's a good design - caps well away from the sinks - unlike japanese shit i used to fix.Leave a comment:
Here's the schematic I drew of the KSGER soldering station 24V PSU for service and repair.
Soldering Power V2.04 and pig with bull horns icon on the silkscreen.
KSGER 96W 24V 5A Electric Power Supply Unit For STM32 STC OLED T12 Digital DIY Soldering Station Controller.
It has some clearance mistakes running +HV trace underneath heatsink and a thin PE ground trace, no connection to the chassis
The TL431 is set to over 25VDC output and it has no bias resistor. The snubber cap is pretty cheap. Could not find datasheets on the CR8642S PWM controller.
Earlier version PSU's like V2.01, V2.02, V2.03 are the same but no pads for a mystery DPAK part or different DC connector.Leave a comment:
Thanks for sharing it I am going to get one in couple of weeks I am going to remove the switch and put a non conducting cardboard ( under the switch ) that is used battery pack so I do not have that problemLeave a comment:
by mkbehbehI purchased this soldering station when it was on sale at amazon. It had a slew of one star reviews, but the price was low enough that even if the controller and PSU were toast, the handle tips and stand were worth more than the price. All of the reviews mentioned that the unit was either DOA, or died on the first use. I looked on Aliexpress and the first clue was that KSGER still sold the 220V version of this station, but all of the 110V versions had been discontinued. I figured That there was a problem with the 110V on the power suppply and the controller would be fine.
I am... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by chth96hello.
A few months ago,I have purchased 0.1mm Soldering Iron Tip of below aliexpress link,But I noticed that It is totally impossible to use this 0.1mm iron tip in the T12 soldering station
https://ko.aliexpress.com/item/4001275635593.html
Is there any good soldering station which is possible to use 900M-TJ-I tip and have inexpensive or reasonable price in aliexpress?
Any reply would be appreciated. -
by capriderHey,
I'm looking for some recommendations of a decent quality soldering station and a separate hot air station. I'm just a hobbyist, so even if (ultra)premium tools are not required, I still want some good tools. They should be available in Europe.
I now have a TS100 and some soldering irons and looking for some better tools.
1. Soldering station, budget around 200-240€
JBC BT-2BWA seems to be a good product in the budget.
2. Hot air station, budget around 200€
Up to now I've found ATTEN ST-862D to be a good option.... -
by Peter_1402Hi Everyone,
I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
1. Soldering iron works great
2. There is a burnt mark on the hot air gun handle.
I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
Reed switch tested ok with a magnet.
From the above test, I can conclude... - Loading...
