KSGER STM32 T12 soldering stations
  • redwire
    started a topic KSGER STM32 T12 soldering stations
    Picked up a soldering station with H/W Ver 2.1S and S/W 2.10 from KSGER store on Ali. Build quality is very good, price was high.
    The handle has a NTC thermistor inside that doesn't seem to do anything.
    What do your station do?
    Bottom right corner of OLED shows a temperature 40°C all the time. Even with a handle plugged in or not, or shorting the "N" pin to GND.
    Menu 04. Cold End Adj. -> NTC-> 40°C {dial in}
    The temperature I dial-in is always displayed.
    I drew a full schematic of the controller board and 24VDC power supply.
    The NTC input is just a pullup resistor going to the MCU input. So the hardware seems fine, it must be crappy firmware?
    RTC battery was DOA and a new one also died quickly. Took out the stupid resistor R10 from this video: https://www.youtube.com/watch?v=B-xWhPcr6jk
  • mkbehbeh
    KSGER C245 Soldering station PSU 220V only?
    by mkbehbeh
    I purchased this soldering station when it was on sale at amazon. It had a slew of one star reviews, but the price was low enough that even if the controller and PSU were toast, the handle tips and stand were worth more than the price. All of the reviews mentioned that the unit was either DOA, or died on the first use. I looked on Aliexpress and the first clue was that KSGER still sold the 220V version of this station, but all of the 110V versions had been discontinued. I figured That there was a problem with the 110V on the power suppply and the controller would be fine.
    I am...
    04-17-2023, 03:11 PM
    by sam_sam_sam
    07-01-2024, 06:34 AM
  • chth96
    What soldering station should I purchase for 900M-TJ-I tip?
    by chth96
    hello.
    A few months ago,I have purchased 0.1mm Soldering Iron Tip of below aliexpress link,But I noticed that It is totally impossible to use this 0.1mm iron tip in the T12 soldering station
    https://ko.aliexpress.com/item/4001275635593.html
    Is there any good soldering station which is possible to use 900M-TJ-I tip and have inexpensive or reasonable price in aliexpress?
    Any reply would be appreciated.
    11-24-2023, 05:08 PM
  • caprider
    Recommendations of quality soldering station and (separate) hot air station
    by caprider
    Hey,
    I'm looking for some recommendations of a decent quality soldering station and a separate hot air station. I'm just a hobbyist, so even if (ultra)premium tools are not required, I still want some good tools. They should be available in Europe.
    I now have a TS100 and some soldering irons and looking for some better tools.
    1. Soldering station, budget around 200-240€
    JBC BT-2BWA seems to be a good product in the budget.
    2. Hot air station, budget around 200€
    Up to now I've found ATTEN ST-862D to be a good option....
    01-15-2022, 02:05 AM
  • Peter_1402
    Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
    by Peter_1402
    Hi Everyone,
    I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
    1. Soldering iron works great
    2. There is a burnt mark on the hot air gun handle.
    I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
    Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
    Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
    Reed switch tested ok with a magnet.
    From the above test, I can conclude...
    07-12-2025, 11:50 AM
