DPS5020 dual power supply build
    Re: DPS5020 dual power supply build
    You are switching AC to the AC load so a NO NO to put diode across the load, you will see nice fire works when that diode conducts. You will put diode across the RELAY DC winding with proper DC polarity to the relay winding.
    RC snubber of for the switch contact.
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      #102
      Yes, I know that That's why I mentioned DC as a separate topic.
      Wattevah...
      • redwire
        • Dec 2010
        • 3912
        To suppress back EMF from an inductive load, an RC snubber is commonly used. A DC inductive load usually has a diode across it to clamp the back EMF.
        You can guess a snubbers value based on the transformer's size.
        I would use 33-47nF and 22-100 ohms 1-3W as a ballpark for a 1,500VA transformer. The film cap needs to be HV rated, a junkbox X-cap is OK but if the cap fails short, the resistor burns up.
        Leakage current from the cap doesn't matter, the transformer might have 1mA flowing all the time but it will stay asleep. Although some loads will still have weak ghost power from that.
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          #104
          This is great info. Sorry for replying so late, but it's only recently that I started working on the project again
          If I use a double-gang switch to cut both the L and N AC lines, should BOTH sides of the switch get a snubber across them ? Silly question perhaps.....
          Wattevah...
          • redwire
            • Dec 2010
            • 3912
            It turns out dual-switch contacts are never identical, so one will close last (power-on inrush current) and another will open last (power-off arc). I had a boss yell at me that it would not last any longer than using one switch contact, when I tried them in parallel.
            Electrical codes here in NA forbid switching both line and neutral in a device. You can only switch line or hot. But I see your breaker panels and motor contactors seem to disconnect both.
            I would use two snubbers, one across each switch contact if you want to open both line and neutral. That is the best way to have no spikes when you switch off. I tried a MOV across the transformer primary but still got a spike.
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              #106
              Ah yes, now that you mention it, I remember hearing about this before (including the boss part ), so you probably answered somewhere in the earlier posts.
              I think this is because EU plugs are not polarized, so either conductor can become hot at one time....just a thought. I, as an ordinary do-it-yourselfer, always choose to cut both wires whenever possible "around the house", like if I wire up a simple power strip for instance...
              Wattevah...
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                That is right that dual contact switches one will make/break before the other and that one will die first, but I was wondering about that electrical code requirement for switch both line and neutral at the same time... Switching protective ground is clearly very bad, but would think that neutral would not be so bad...
                I've seen a lot of computer equipment that has both line and neutral switched, and seen/have some DPST wall toggle switches. Is this really against code? The most I saw in the electrical code rules is that if neutral gets disconnected, line MUST be disconnected at the same time, which implies DPST are OK.
                On the other hand, I also saw that "grounded" conductors must not be switched, and whether neutral, which is "ground" also counts as "ground" that must not be switched. Now that remains a curiosity for me...
                  • 31196
                  neutral is not considered grounded in the device or even a building - it would be a dangerous asumption.
                  any bonding is at the power company's side - either at the box or the transformer.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    That would agree with what I see so far - meaning a DPST is okay since neutral is not ground, but I still don't quite understand the statement in post 105...
                    • megaraider
                      • Jul 2015
                      • 307
                      • Portugal
                      #110
                      I'm not aware of the electric regulation on Canada.
                      Nevertheless, it's a common mistake wrong labeling and interpretation about Earth connection.
                      While the Line is sometimes referred as Hot without raising any problems,
                      the Neutral is often mislabeled or referred to as Ground leading to wrong assumption and confusion with Earth .
                      Therefore, with exception for the electric house panel where Neutral, and Earth (off course), must always remain connected (only the Line can be switched),
                      it's very common to switch both Line and Neutral.
                      In contrast switching Earth is totally forbidden.
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        I'd imagine Canada have much similar rules as USA which is described in the NEC. However even https://en.wikipedia.org/wiki/Electr..._North_America has some wording implying that neutral switching is taboo in most circumstances:
                        Originally posted by wikipedia Electrical wiring in North America
                        North American standards state that the neutral is neither switched nor fused except in very narrowly defined circumstances.
                        Agree that it should not be fused, but should be okay to be switched IFF hot is switched off first, and hot is on last.
                        Need to find the explicit rule, and then again whether this is only for building wiring or does it apply to end run pluggable equipment as well...
                          • 31196
                          end equipment often has double-pole switching - it just makes sense once you understand that earth-neutral bonding cant be assumed.
                          what if it's an old building with earth on a gas-pipe or just non-existant?
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8701
                            So is there a difference between end equipment and building code rules and hence is why post 105 is confusing?
                              • 31196
                              yes, there is a plug and socket or a atleast a junction-box for fixed / industrial stuff.
                              the supply side is "infrastructure" the thing connected is an "appliance"
                              different rules apply to each.
                              • emir0815
                                • May 2020
                                • austria
                                #115
                                Hi guys,
                                I connected a battery with reverse polarity and some parts blew up. Does someone have details on
                                1. F1 rating
                                2. component left of F1
                                3. component above with DT on the pcb
                                I do have a dps5020
                                Thanks in advange
                                Karl
                                • Dannyx
                                  CertifiedAxhole
                                  • Aug 2016
                                  • 3912
                                  #116
                                  I could provide some close-up pics of my board if you think it'll help you, but can't possibly know any of the values unfortunately...maybe try chatting with a seller on Aliexpress see if they got a schematic they're willing to share :|
                                  Wattevah...
                                    • 31196
                                    people have done that mistake before, there is a thread on eevblog about it with the guy who designed it posting some info
                                    • Dannyx
                                      CertifiedAxhole
                                      • Aug 2016
                                      • 3912
                                      #118
                                      No reverse polarity protection ? I think I'll be adding a diode myself, having heard about these having a tendency to blow up like this
                                      Wattevah...
                                      • megaraider
                                        • Jul 2015
                                        • 307
                                        • Portugal
                                        #119
                                        • Dannyx
                                          CertifiedAxhole
                                          • Aug 2016
                                          • 3912
                                          #120
                                          Just thought I'd share with you guys some pics of my first DPS supply build.
                                          The case work belongs entirely to my old man, so I take no credit for that
                                          The IEC 13 inlet I used on the back has 2 Y caps going between each of the "live" wires and PE (which is useless ATM, because there's no earth on most outlets around here). The PCB on the back where the choke is, is an EMI filter I pulled out of an ATX supply or something, already assembled like that: mains comes in, mains comes out. I thought I'd install it just for the sake of it, though I have no idea if it actually helps in any way or not. It's got some Y caps of its own there, plus some resistors, an X cap and that choke. I actually took some close-ups of this board and discussed it someplace else, but can't remember where right now, unless I start searching around my older threads...
                                          What it's lacking is X caps across the two-pole main power switch on the front panel (right of picture) and Y caps+resistors between secondary GND and PE like we've discussed and debated over...
                                          Wattevah...
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                            03-31-2024, 02:12 PM
                                            07-01-2024, 06:34 AM
                                          • kitedude
                                            DPS5020 "power supply"
                                            by kitedude
                                            Hello. I have the dps5020 and I've blown the mosfets which I've replaced but the D5 diode is unrecognizable.Maybe someone has the schematic or the same device? Anyone knows what it is and where does the cathode go? (left or right) I'm a noob so I know nothing about anything. Complicated answers will not be understood.
                                            Damage was due to reverse polarity for a second but it worked for months with bulged mosfets, then the final blow was more input voltage than 50v.​
                                            11-26-2024, 04:55 AM
                                          • shamsudeen
                                            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                            by shamsudeen
                                            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                            i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                            07-19-2025, 07:14 AM
