esr or cap tester
  • mmartell
    • Oct 2013
    • 3189
    Re: esr or cap tester
    Hey Behemot do you have his contact info ?
    • Behemot
      • 4845
      • CZ
      #202
      Try support@radiodevices.ru or Skype mike_rd1.
      • mmartell
        • Oct 2013
        • 3189
        Thanks bro. I forgot the damn url was printed on the device.
        • mariushm
          • May 2011
          • 3799
          #204
          His username here on this forum is RusMike ... if you give him a PM, he's gonna receive an email with the PM.
          Be patient, he doesn't check his emails often.
          • mmartell
            • Oct 2013
            • 3189
            I sent an email to support@radiodevices.ru
            • mmartell
              • Oct 2013
              • 3189
              For anyone who may find this info useful in the future remove and check R1. It should be 1ohm. Mine was over 30ohms. Replacing it temporarily with a jumper brought it back to life. Waiting on some 1ohm resistors to repair it properly.
              Cheers!
              • Kiriakos GR
                Banned
                • May 2012
                • 940
                • Greece
                #207
                Is that another funny story of yours?
                Are you saying that a resistor on that PCB suddenly from 1 Ohm become 30 all by it self?
                This is the most ridicules story ever.
                • Behemot
                  • 4845
                  • CZ
                  #208
                  It's possible. It is true that usually the resistor burns completely, but this may happen. It works there as a fuse - if you connect charged capacitor to it, the input transil shorts it but you get huge currents flowing through the 0,25W (in later versions 0,5W) resistor.
                    I have seen the resistor failed mode like that many time from many repair works. If you work on many many many many kind of electronics for so many many many many years, you will see lots of failure modes of the components.
                    • Kiriakos GR
                      Banned
                      • May 2012
                      • 940
                      • Greece
                      #210
                      I am not going to debate over this, even if I do not consider possible such event at the fraction of a second, to be capable to do such damage.
                      From the other hand if the true reason of such a damage in one ESR meter is due bad handling or irresponsible use, I am not surprised.
                      Before some time, some one got a fresh cheap multimeter and his first measurement was an electric fence.
                      The meter got toasted and he learned something useful too.
                      • Behemot
                        • 4845
                        • CZ
                        #211
                        I think that several mF at several volts carry quite a power
                        • Kiriakos GR
                          Banned
                          • May 2012
                          • 940
                          • Greece
                          #212
                          One 1000uF at 16V does not looks a nuclear reactor to me, but the boys who are planing to play with super capacitors, they must be 100 times more careful with them.
                            16V into 1 Ohms is 16 A but at very short period of time. After 1TC, the voltage on the cap will be about 6V.
                            t = (C*V)/I.
                            http://www.coilgun.info/theorycapaci...orcharging.htm
                            • tibimakai
                              • Jan 2012
                              • 3680
                              Mine died too. I barely used it a couple of times? I don't remember, that I have used it improperly.
                              I have replaced the batteries, but didn't change anything.
                              I should check that 1.0 Ohm resistor?
                              I have the 4.0 version and I have purchased it in April 2012.
                              • mmartell
                                • Oct 2013
                                • 3189
                                Yes check the one ohm resistor - it is between where the test leads are soldered to the board on mine (R1).
                                I replaced mine temporarily with a jumper and that restored the calibration function.
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  I have measured it and it's fine.
                                  I have started measuring other components and while I was measuring one of the transistors, I have just heard the startup beep.
                                  Not sure what happened, but it's working now.
                                  • Behemot
                                    • 4845
                                    • CZ
                                    #217
                                    Cold joint maybe? Also check the transil, it's there to protect the device from charged capacitors.
                                    • mmartell
                                      • Oct 2013
                                      • 3189
                                      Oops sorry I didn't realize yours was dead.
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        What is a transil?
                                        • Behemot
                                          • 4845
                                          • CZ
                                          #220
                                          http://en.wikipedia.org/wiki/Transil
                                            Microsoft Surface Redbank i5/8/256 Blue Notebook Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Redbank i5/8/256 Blue Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Redbank i5/8/256 Blue boardview and Surface Redbank i5/8/256 Blue schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-07-2024, 05:50 AM
                                            Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook 300 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I3-1215U 4GB 128GB BLUE boardview and IP3 15 I3-1215U 4GB 128GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                            09-07-2024, 05:00 AM
                                            Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R7 5825U 8GB 512GB BLUE boardview and IP3 15 R7 5825U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                            Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I5-1235U 8GB 256GB BLUE boardview and IP3 15 I5-1235U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                            Lenovo IdeaPad IP3 15 R5 5625U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IP3 15 R5 5625U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R5 5625U 8GB 256GB BLUE boardview and IP3 15 R5 5625U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
