esr or cap tester
    Re: esr or cap tester
    Hey Behemot do you have his contact info ?
      Try support@radiodevices.ru or Skype mike_rd1.
        Thanks bro. I forgot the damn url was printed on the device.
          His username here on this forum is RusMike ... if you give him a PM, he's gonna receive an email with the PM.
          Be patient, he doesn't check his emails often.
            I sent an email to support@radiodevices.ru
              For anyone who may find this info useful in the future remove and check R1. It should be 1ohm. Mine was over 30ohms. Replacing it temporarily with a jumper brought it back to life. Waiting on some 1ohm resistors to repair it properly.
              Cheers!
                Is that another funny story of yours?
                Are you saying that a resistor on that PCB suddenly from 1 Ohm become 30 all by it self?
                This is the most ridicules story ever.
                  It's possible. It is true that usually the resistor burns completely, but this may happen. It works there as a fuse - if you connect charged capacitor to it, the input transil shorts it but you get huge currents flowing through the 0,25W (in later versions 0,5W) resistor.
                    I have seen the resistor failed mode like that many time from many repair works. If you work on many many many many kind of electronics for so many many many many years, you will see lots of failure modes of the components.
                      I am not going to debate over this, even if I do not consider possible such event at the fraction of a second, to be capable to do such damage.
                      From the other hand if the true reason of such a damage in one ESR meter is due bad handling or irresponsible use, I am not surprised.
                      Before some time, some one got a fresh cheap multimeter and his first measurement was an electric fence.
                      The meter got toasted and he learned something useful too.
                        I think that several mF at several volts carry quite a power
                          One 1000uF at 16V does not looks a nuclear reactor to me, but the boys who are planing to play with super capacitors, they must be 100 times more careful with them.
                            16V into 1 Ohms is 16 A but at very short period of time. After 1TC, the voltage on the cap will be about 6V.
                            t = (C*V)/I.
                            http://www.coilgun.info/theorycapaci...orcharging.htm
                              Mine died too. I barely used it a couple of times? I don't remember, that I have used it improperly.
                              I have replaced the batteries, but didn't change anything.
                              I should check that 1.0 Ohm resistor?
                              I have the 4.0 version and I have purchased it in April 2012.
                                Yes check the one ohm resistor - it is between where the test leads are soldered to the board on mine (R1).
                                I replaced mine temporarily with a jumper and that restored the calibration function.
                                  I have measured it and it's fine.
                                  I have started measuring other components and while I was measuring one of the transistors, I have just heard the startup beep.
                                  Not sure what happened, but it's working now.
                                    Cold joint maybe? Also check the transil, it's there to protect the device from charged capacitors.
                                      Oops sorry I didn't realize yours was dead.
                                        What is a transil?
                                          http://en.wikipedia.org/wiki/Transil
