Hakko 808-5 desolder gun
  • BigAlNZ
    • Mar 2008
    • 65
    I was thinking about getting one of these.
    http://www.hakkousa.com/detail.asp?PID=838&Page=1
    or maybe even the Hakko 850 rework station, but I think it might be SMD only?
    Are they any good? How quicky can you remove a cap? Does it leave a nice clean hole?
    How quick is it?
    Cheers
    -Al
  • severach
    • Aug 2007
    • 1055
    Re: Hakko 808-5 desolder gun
    I never found any spring or bulb desoldering tools to work well. The motorized vacuum pump connected to the heat source was the first tool that really made the solder move. It makes a lot of work fast and easy that otherwise would be impossible.
    Good solder pulls easily and the hole is clear and with a little care there is no board scuffing. Because the gun is trapped on the terminal there is less risk of burning yourself. Some solder is difficult to pull though it may be because I don't use any flux. Terminals soldered to ground planes are difficult to desolder though it may be because I keep mine on the lowest setting for long tip life. Adding heat to the other side with another iron is much more effective.
    Once the part is removed you can use a regulated iron at the lowest setting (392*F, 200*C) with a pointed tip in conjunction with the Hakko 808 to clear through holes of any size. Two irons heat fast to minimize board damage.
    Though the directions warn against it, the Hakko 808 makes an excellent soldering tool.
    If you discover that Hakko 808 tips are shockingly expensive some Aoyue tips are compatible. I haven't used any of my Aoyue tips to find out how well they are made. The Hakko tip looks like it will last forever.
    The supplied tip is a bit too small to fit over some common parts. This is only a problem when the tip is new. As it is used it will open up. You will eventually plug the tip with something solid that the Hakko ram rod can't remove. Drilling the tip will remove the obstruction and the tip will become wider. Have a set of tiny drills handy.
    sig files are for morons
    • BigAlNZ
      • Mar 2008
      • 65
      Ill take that as a thumbs up for the 808?
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        I've looked at the 808 and thought about getting one.
        Then I got my hands on an old Pace Desoldering Station which it the same setup as I used in the Navy and works fine for me.
        It does the same thing except the pump is connected to the hand tool by way of tubing your arm isn't holding the weight of the pump all the time.
        Without having tried one I'd still give the 808 a thumbs up based on reviews I've seen on it.
        Shop around though.
        I've seen it occasionally [somewhere] for under $175.
        I think Frys Electronics carries them....
        Mann-Made Global Warming.
        - Dr Seuss
        • bgavin
          • Jan 2007
          • 1355
          I have no experience with these, but am finding an increasing need to quickly and accurately clean the holes. Especially when fitting the polyers with thicker leads.
          A foot pedal activated sucker would sure be handy...
          • NxB
            • Feb 2009
            • 1595
            $5 Radio shack sucker works pretty well for me on bigger stuff that's a pain to mop up. It leaves the holes clean as well. Otherwise its braid and iron. Its probably nice and convenient but for $200+, oh my. Aoyue probably has a cheaper clone too. I know their 3 in one station has a weak pump and clogs up the little solder tank so I would see if they have a dedicated gun like the hakko.
            Ultimately the decision comes down to how much volume you pull. If it can pay itself on the time you save fixing stuff then I would get it. An ebay BGA rework is $400 and would get a faster return on laptop boards and xboxes. But if your drowning in boards...
            • KeriJane
              Mac Enthusiast
              • Sep 2008
              • 681
              Hello.
              Funny you should mention the Hakko 808 desolder gun...
              I just bought one last week! I was going to write a review on it soon, but now is OK too.
              I got one with the optional plastic case. It comes with an extra plastic solder reservoir, some filter pads and some metal shields. There is also a wrench for removing the tip, two cleaning rods and a handy high temperature sleeve to stick the tip in so you can put it away before it completely cools down.
              A quick look reveals a few things:
              1-- The tip heater is on whenever it is plugged in so you must unplug it when not in use.
              2-The only switch is the trigger button that turns on the vacuum pump.
              3-There is a recessed temperature control that you adjust with a screwdriver. The manual indicates that multi-layer boards require the most heat.
              4-The tip wrench unscrews the barrel which retains the tip.
              5-The solder reservoir is an acrylic tube open at one end and having a metal shield and rubber seal at the other. The filter pad fits into the spring loaded plunger that holds the tube in place.
              6- It is supplied with one 1.0mm tip and matching cleaning rod. Other sizes are available.
              The Hakko 808 is a bit heavy to hold and grows a bit warm during use. During operation you are advised to contact only the solder and component lead, not the circuit trace. This done, the solder melts rapidly, you press the trigger and the solder gets sucked into the tip, passes through the hollow heater and enters the reservoir tube and strikes the metal shield.
              If a clog occurs, the pump stops. The pump sounds suspiciously like an aquarium pump but really it's a two-chamber vacuum pump that you can easily look at by taking off the rear cover.
              For desoldering single-sided PSU boards, it's perfect. Zap, the hole is clean in a second or so. Just pull the now loose cap out cold.
              For desoldering multi-layered motherboards, I found that I usually have to add a little solder first. Sometimes it pulls the solder out perfect on the first try, other times it needs a little effort.
              It's ALWAYS way easier than either the Radio Shack bulb sucker or the fingernail-breaking spring-loaded solder sucker contraption from Hades.
              The manual is written for the soldering professional and contains a full parts list, repair instructions, calibration procedure, recommended desolder techniques and temperature settings. This is NOT an idiot-proof consumer-level disposable toy and is well worth the price of admission.
              This is my first Hakko product and I'm impressed. The only things I don't care for is the fact that the handle eventually warms up a bit during use and the lack of a Power switch.
              The quality seems better than my Weller soldering irons, so maybe I'll try a Hakko station sometime.
              Have Fun!
              Bzzzz! There goes another BadCap!
              Keri
              PS. Wow! it's the Mac Pro of soldering equipment! (ducks)
              The More You Learn The Less You Know!
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                The Pace units are foot activated. [At least those I've used.]
                It is indeed a great feature!
                - Dr Seuss
                • bgavin
                  • Jan 2007
                  • 1355
                  Damn, darlin' we're gonna have to smack that Mac-shit out of you...
                  ( big grin )
                  I bought the Hakko 936 station for about $75 USD.
                  I'm seriously impressed with the quality of the unit.
                  If they make a foot pedal operated sucky-thingy, all the better.
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    I have 3 Hakko 926's which are the previous generation of the same thing.
                    I picked them up used in a box with 5 handsets and cables for $30.
                    Pretty beat up and ugly but they work fine.
                    - Dr Seuss
                    • BigAlNZ
                      • Mar 2008
                      • 65
                      I got a 936 and love it.
                      Thanks for the review of the 808. I will have to look at these pace units too.
                      -Al
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        i have the basic spring-powered solder sucker. i use it with my xytronic soldering iron. cost me a total of 25 bucks. the trick is to add some silver-bearing solder to the hole, thrn suck all of it out. the silver solder makes the existing solder melt better and suck out cleaner. who needs a fancy pump or de-soldering iron?
                        sounds stupid, but i do this whenever the iron + sucker doesn't do it. also, the extra solder give more area to contact the iron. i swear this works.
                        sigpic
                        (Insert witty quote here)
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          Oh ratdude, you just opened yourself up to flaming fireballs from the peanut gallery.
                          There's a BUNCH of people here that absolutely hate those things.
                          If you 'have the nack' for them, get a good one and use it right those things do work well.
                          Problem is many people either get a bad one, aren't coordinated enough, or don't learn how to use them right [or all of the above] and they end up sucking out via's or banging it into the work when it recoils.
                          - Dr Seuss
                          • BigAlNZ
                            • Mar 2008
                            • 65
                            Also, would the 808 be any good for removing ROM chips from HDD PCB's, or is it another tool all together for that?
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              yeah, but what if you have no MONEY?
                              sigpic
                              • KeriJane
                                Mac Enthusiast
                                • Sep 2008
                                • 681
                                Hi BiggAINZ
                                You mean the Surface Mount Device (SMD) chips on the bottom side of HDD's?
                                The Hakko 808 isn't really designed for SMT/SMD removal though you can suck the solder off of the simpler ones with it.
                                What is meant for that is a SMD, SMT or BGA rework station. Those use hot air or infrared light to heat the solder without contact.
                                Just google "SMD Rework" or "BGA rework"
                                Have fun,
                                Keri
                                • KeriJane
                                  Mac Enthusiast
                                  • Sep 2008
                                  • 681
                                  Hi Ratdude!
                                  YOU
                                  ARE
                                  ON
                                  THE
                                  RIGHT TRACK!
                                  To make some money, that is. Serious, "nice" money. (no, not Filthy Rich, but "nice")
                                  Right now, consumer electronics are not worth fixing. Cheap Chinese Slave Labor combined with modern production and distribution methods have reduced the cost of new stuff below that of repair costs.
                                  That has not always been the case, nor is it likely to continue for long.
                                  This, combined with a couple of generations of people that are used to our throwaway society leaves Y O U as a Fixer of Things in a strong position for the long term.
                                  Continue studying the basic principles of EVERYTHING .
                                  Continue practicing Repair and especially Diagnosis. Get to know the Why and Wheretofor AND what to do about it.
                                  The current crop of people willing to throw out all manner of fixable technology gives you a golden opportunity to Learn and Practice.
                                  Upon these basic Principles you can make a Steady Income.
                                  and, incidentally buy that Hakko or Tektronix or AnaTec or SunMoon (or even KeriProductions!) thing or other.
                                  Happy FIFTH of July,
                                  Keri
                                  PS. Do you know what Computers used to cost in the mid 1990's? I do.
                                  A "Cheap" i486SX with minimal memory and no Math Co-Processor was roughly $2,000. Anything DECENT was $2,500 or $3,000.
                                  People (including me) made a LOT less money back then too.
                                  PPS> If you can master the Pogo Stick From Hades style of solder sucker, Great! I prefer the softer touch of the Radio Shack bulb sucker or the convenient Hakko pump sucker.
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    i dont like the bulb. i like the pogo stick because i can cock it, wait fir the oint to liquidfy, and wham, join cleared. use thumb to recock and continue.
                                    also, the bulbs are a pain in the ass to clean, right?
                                    sigpic
                                    • NxB
                                      • Feb 2009
                                      • 1595
                                      The bulbs make a mess. I usually blow the solder on the floor. The spring type is ok. I don't like that I have to keep re-cocking it.
                                      • BigAlNZ
                                        • Mar 2008
                                        • 65
                                        Hi BiggAINZ
                                        Have fun,
                                        Keri
                                        Yeah, although the ROM chips are generally biggish compared to some of the very fine SMD stuff.
                                        Thanks for that detailed review on the 808 too.
                                        • LearningToRepair
                                          How to correctly desolder through hole IC?
                                          by LearningToRepair
                                          Hi!
                                          I tried to desolder through I had IC that I wanted to replace but failed. And now I came here to learn what's the correct way for doing this. I tried to use soldering wick but the capillary force kept solder in the hole. With soldering wick I only managed to remove the part of solder that was outside the hole. But the solder that was inside the hole never got out. And of course when I moved on to next pin the solder in previous hole hardened again so no matter how many times I did all the pins there was still solder in holes.
                                          Question 1: what would have been correct...
                                          07-19-2020, 04:01 PM
                                        • redwire
                                          Hakko 950 SMT hot tweezers but no base or stand
                                          by redwire
                                          I got gifted a Hakko 950 SMT hot tweezers but no base or stand.
                                          Any suggestions for building one?
                                          "The 950 is compatible with the Hakko 936, 937, 939, 703, 926, 927 and 928 soldering stations." Apparently it has two heaters in parallel "24V 50W", one RTD temperature sensor 43-58Ω at room temp. 5-pin DIN.
                                          I don't have any of those, have a 470-2 (no RTD in) and a FX-888A.
                                          04-17-2025, 03:01 PM
                                        • 13mh13
                                          Aluminum SMD caps vs thru hole caps (reliability)
                                          by 13mh13
                                          The PCB motor for 1987 Technics SLP-120 CD player has slow spin-up issues. Similar to what another tech in the below video reported.
                                          https://i.postimg.cc/kGrR6BpZ/image.jpg
                                          I replaced the three bi-polar 47uF electros but that made no difference. The orig three bi-polar 47uF electros tested okay on my ESR M-tester.
                                          I have not tested/replaced those alum. SMD electro PCB caps.
                                          Are Al smd caps are more prone to failure (or degradation) than regular thru-hole electros?
                                          All the thru hole electros I removed / replaced on this CDP (and most...
                                          04-05-2024, 07:41 PM
                                        • corrize
                                          How to desolder this component beside chemical cap ?
                                          by corrize
                                          Hello, I need your advise pls ?
                                          The black component at the center of picture is dead, I need to replace it (it's a Nikon D5 camera). It's easy to desolder with hot air. But beside, there is a chemical cap, and I don't want to destroy it.
                                          How do you do ?
                                          I have low melt solder and good capton. Is it better to desolder the cap (for safe) with iron, then desolder-resolder the black component with hot air ? Or these caps are strong enough and capton and other cover can avoid hot air damage ?...
                                          07-04-2022, 03:36 AM
                                        • NWArkGuy
                                          Samsung UN65TU8000 - Panel Issue [ hole in ribbon cable ]
                                          by NWArkGuy
                                          Well, I will be the first to admit that I screwed up...
                                          In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
                                          I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
                                          I have 2 that I have found and have in my possession. ...
                                          10-12-2023, 10:13 PM
