[emission only] vacuum tube tester safety
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Well, I was able to acquire a vacuum tube tester. It's a cheap crappy emission only (i.e., no transconductance/mutual resistance) tester - but I realized it was even crappier than I thought. The power supply is an autotransformer, and the "floating wire" top cap lead has an electrical path to line power! Touch the cap wire, get electrocuted!
    I would suspect all those old console tube testers were isolated especially if it had one of those flying top cap leads... or at least I hope it would. This one is indeed cheap cheap cheap, alas it does get the job done...
    • 31044
    Re: [emission only] vacuum tube tester safety
    well i suspect it's normal, back in tube days tv's & radio's where often live.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      They did have live chassis like the AA5 but you can't touch any part of the live portion with your finger... but in this case if the tube cap wire touches something, it could be quite problematic...
        • 31044
        that's not completely true, you could touch the antenna connector etc at the rear - and with a 2pin plug you have a 50/50 chance of winning!!
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          I thought AA5's had internal loop antennas, if not, they are capacitive coupled with a really small capacitor (so that any leakage would be less than ~1mA to GND at 60Hz)?
            • 31044
            go watch some "carlson's lab" vids - it will put you off old stuff forever!!
            he had a chrome plated radio the other day, plug it in the wrong way and the whole shell can go live - and it did!!!
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              If things like this were fine back then and modern CCC/poor design is not, what has gotten into us???
              Hooray...found some broken vacuum tubes, at least my stockpile of vacuum tubes is going down, no sense in keeping the bad tubes...
                • 31044
                it's down to education.
                in the past people simply knew that you dont touch metal bits when something is on!
                also, people used to do risky shit a lot more.
                fixing a fuse with the foil from a pack of smokes was so common that it was more likely than a working fuse!!!
                2way adapter?? no, just poke the wires into the wall and smash the plug into the socket over them - saw that a lot.
                and my fav'
                making an extended cable by twisting the wires and wrapping it in tape.
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  I wonder if I could hack this tube tester to do transconductance tests by feeding some signal into the grid... :o
                    • 31044
                    well you can find schematics for most B&K gear - so your only limited by time & patience.
                    • desert-rat
                      • Mar 2014
                      • 4103
                      The ones I remember all had a power trans. I remember the days when some of the gorcery stores had a tube tester . Found these links for you .
                      https://fairradio.com/?s=+tube+tester+
                      https://www.ebay.com/sch/i.html?_fro...ester&_sacat=0
                      • dicky96
                        Sun Seeker
                        • Mar 2017
                        • 1825
                        • Spain
                        Surely any electronics lab (apart from where you are working solely on low voltage devices) should have an mains isolation transformer powering the test bench. They are not even expensive
                        Follow me on YouTube
                        Learn Electronics Repair
                        • kc8adu
                          • Nov 2003
                          • 8832
                          • U.S.A!
                          this set must have been missing its isolation hardware.
                          not unusual for these parts to have degraded in the last 70+ years and replaced with metal parts by someone who did not understand why the chassis mounts were made of "cheap" plastic or rubber.
                          or used a metal knob in place of a plastic one.
                          aa5 sets require a bit of caution when testing/repairing them.
                            ZD-915 vacuum pump motor mount service alert
                            by sam_sam_sam
                            If you have this Desoldering Gun Station there is something you should be aware of the two screws that hold the motor to mounting for pump can come loose and make raddling noise
                            One note this unit has been repaired already once because of switching power supply regulator ic chip failure
                            Now this with the vacuum motor mounting issue yes I give this Desoldering station a very hard work out and use about every weekend to do some type of project
                            The fix is taking the vacuum pump assembly out and take the metal cover off and you will see the two screws on it
                            09-19-2021, 02:15 AM
                          • Schoenradt
                            ECH81/6AJ8 Vacuum Tube Question
                            by Schoenradt
                            Recently I acquired an Eico HFT 92 AM/FM radio made back in 1958. The unit has had some decent modifications done such as replacing the rectifier tube with silicon diodes and replacing the main filter capacitor with electrolytic capacitors. When I powered it up FM wouldn't tune past 105Mhz. I checked the FM tuner front end assembly and found a capacitor not soldered to the coil from the Plate B+ to and ground on the other side of the coil. Some calibration was needed on the trimmer capacitor on the tuner. My question is AM is extremely weak. When I tap on the tube I get all kinds of snapping and...
                            06-10-2021, 05:49 PM
                          • ex250
                            SDJ01RM vacuum robot not powers on, all dead
                            by ex250
                            Hi friends, I have this vacuum robot at home that is not starting any more, no leds working, power button doing nothing, battery reading seems ok arround 14.4v, I suspect that mainboard is faulty, seems that there is not any clear brand model on it, and of course could not find any schematic. The trand of the vacuum is the Roidmi SDJ01RM, on some sites appears as vacuum mop Eve plus 60 or similar
                            If any one could point for where to start... would appreciate, new board is quite expensive arround 100 USD or more
                            Many thanks and Merry Christmas to all...
                            12-24-2022, 05:12 AM
                          • tony359
                            Ring tester
                            by tony359
                            I'd like to add a ring tester to my toolbox to test flybacks but also low frequency transformers if possible.
                            I found a few products online, some based on the "diodegonewild" design, others are different designs. Some are available to build DIY, others are not.
                            Any suggestions on a DIY one I could put together? Ideally something which would also be able to test low frequency transformers, that might be handy.
                            So far I found these two:
                            http://bobparker.net.au/Basic%20Digital%20Ringer/ (the posher version...
                            09-13-2023, 07:34 AM
                            Here is a good USB C tester that actually works first time you connect it to a device
                            by sam_sam_sam
                            Here is where you can find one
                            https://www.ebay.com/itm/11450939852...53.m2749.l2649
                            I am not getting paid for this recommendation nor was it a free item from the seller
                            I have bought several USB A/C type testers are not worth a crap for USB C you have to connect it several times to a USB C device before it recognizes the device to me this is worthless
                            The only downside of this tester is that it does not tell you what protocol you are accessing but this to me is not a very big deal because I would...
                            06-06-2022, 05:42 PM
