[emission only] vacuum tube tester safety
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8706
    Well, I was able to acquire a vacuum tube tester. It's a cheap crappy emission only (i.e., no transconductance/mutual resistance) tester - but I realized it was even crappier than I thought. The power supply is an autotransformer, and the "floating wire" top cap lead has an electrical path to line power! Touch the cap wire, get electrocuted!
    I would suspect all those old console tube testers were isolated especially if it had one of those flying top cap leads... or at least I hope it would. This one is indeed cheap cheap cheap, alas it does get the job done...
    • 31277
    Re: [emission only] vacuum tube tester safety
    well i suspect it's normal, back in tube days tv's & radio's where often live.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8706
      They did have live chassis like the AA5 but you can't touch any part of the live portion with your finger... but in this case if the tube cap wire touches something, it could be quite problematic...
        • 31277
        that's not completely true, you could touch the antenna connector etc at the rear - and with a 2pin plug you have a 50/50 chance of winning!!
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8706
          I thought AA5's had internal loop antennas, if not, they are capacitive coupled with a really small capacitor (so that any leakage would be less than ~1mA to GND at 60Hz)?
            • 31277
            go watch some "carlson's lab" vids - it will put you off old stuff forever!!
            he had a chrome plated radio the other day, plug it in the wrong way and the whole shell can go live - and it did!!!
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8706
              If things like this were fine back then and modern CCC/poor design is not, what has gotten into us???
              Hooray...found some broken vacuum tubes, at least my stockpile of vacuum tubes is going down, no sense in keeping the bad tubes...
                • 31277
                it's down to education.
                in the past people simply knew that you dont touch metal bits when something is on!
                also, people used to do risky shit a lot more.
                fixing a fuse with the foil from a pack of smokes was so common that it was more likely than a working fuse!!!
                2way adapter?? no, just poke the wires into the wall and smash the plug into the socket over them - saw that a lot.
                and my fav'
                making an extended cable by twisting the wires and wrapping it in tape.
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8706
                  I wonder if I could hack this tube tester to do transconductance tests by feeding some signal into the grid... :o
                    • 31277
                    well you can find schematics for most B&K gear - so your only limited by time & patience.
                    • desert-rat
                      • Mar 2014
                      • 4103
                      The ones I remember all had a power trans. I remember the days when some of the gorcery stores had a tube tester . Found these links for you .
                      https://fairradio.com/?s=+tube+tester+
                      https://www.ebay.com/sch/i.html?_fro...ester&_sacat=0
                      • dicky96
                        Sun Seeker
                        • Mar 2017
                        • 1825
                        • Spain
                        Surely any electronics lab (apart from where you are working solely on low voltage devices) should have an mains isolation transformer powering the test bench. They are not even expensive
                        Follow me on YouTube
                        Learn Electronics Repair
                        • kc8adu
                          • Nov 2003
                          • 8832
                          • U.S.A!
                          this set must have been missing its isolation hardware.
                          not unusual for these parts to have degraded in the last 70+ years and replaced with metal parts by someone who did not understand why the chassis mounts were made of "cheap" plastic or rubber.
                          or used a metal knob in place of a plastic one.
                          aa5 sets require a bit of caution when testing/repairing them.
                          • DCJack
                            B&K 707 tube tester. I need help.
                            by DCJack
                            Hi everyone!
                            I managed to get my hands on a rough condition B&K 707 for "the best price" because it was not working. It's my first tube tester and I'm really wanting to get it up and running. I downloaded that manual that has the schematics and tested every resistor and capacitor and replaced the ones that failed. I replaced the missing 83 rectifier tube with a used but tested-good one. I also have a number 80 rectifier tube that I have used in tests before I found the 83 tube.
                            Initially I noticed that I was not getting the red on-light to turn on, but it...
                            03-05-2024, 05:05 PM
                          • flat-earther
                            Hoover FM216LI cordless vacuum refuses to charge
                            by flat-earther
                            I have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
                            I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
                            5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
                            So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries....
                            06-06-2025, 03:14 AM
                            ZD-915 vacuum pump motor mount service alert
                            If you have this Desoldering Gun Station there is something you should be aware of the two screws that hold the motor to mounting for pump can come loose and make raddling noise
                            One note this unit has been repaired already once because of switching power supply regulator ic chip failure
                            Now this with the vacuum motor mounting issue yes I give this Desoldering station a very hard work out and use about every weekend to do some type of project
                            The fix is taking the vacuum pump assembly out and take the metal cover off and you will see the two screws on it
                            09-19-2021, 02:15 AM
                          • Schoenradt
                            ECH81/6AJ8 Vacuum Tube Question
                            by Schoenradt
                            Recently I acquired an Eico HFT 92 AM/FM radio made back in 1958. The unit has had some decent modifications done such as replacing the rectifier tube with silicon diodes and replacing the main filter capacitor with electrolytic capacitors. When I powered it up FM wouldn't tune past 105Mhz. I checked the FM tuner front end assembly and found a capacitor not soldered to the coil from the Plate B+ to and ground on the other side of the coil. Some calibration was needed on the trimmer capacitor on the tuner. My question is AM is extremely weak. When I tap on the tube I get all kinds of snapping and...
                            06-10-2021, 05:49 PM
                          • howardc64
                            Don't probe Samsung LED conector with LED tester, connect may not make contact afterwards
                            by howardc64
                            Samsung have been using this style LED connector for few years now
                            Usually good idea to test the LEDs before opening the panel to change them. I do this without the PSU stil connected. With this connector (white one) have to jam the LED tester probes in the very narrow thin slot where the PSU blade style male prong inserts into. I've done this on many Samsungs without problem until today...
                            The female terminal inside the white connector has fragile fingers that grabs onto the male blades on the PSU's black connector. If the LED tester probe spreads open...
                            10-12-2025, 08:13 PM
