Conform Coatings Application On Motherboard /Circuit board
  • LENOVO-A880
    Not A Bad BIOS
    • Feb 2014
    • 79
    • MALAYSIA
    Hi Badcapers,
    Would like to ask I'm having a few boards which some are memory modules PC100/PC133, motherboard from Acer Aspire V76M desktop system, wireless card and laptop memory modules which are not working properly likely due to minor shorts causing crashes on systems. Can any light conformal coatings usage in aerosol/spray mode be used on these circuits boards as a protective layer/film to prevent from dusty environment? What kind of brands available out there will be specialised for insulating boards against chemical or corrosive attack? THANK YOU..
    "If you cannot do great things, do small things in a great way."
    -Napoleon Hill
    "The chip that functions abnormally will be desoldered, as they say."
    -Charles Stross
    "Why is it you're always too small or too tall?"
    -The Mad Hatter
  • llonen
    • Sep 2014
    • 495
    • hampshire
    Re: Conform Coatings Application On Motherboard /Circuit board
    The boards you describe will come with a con-formal coating already applied to protect the printed circuits and related equipment from their environment, that said if you have had to remove any of the coating to effect repairs then I have found Electrolube products quite useful in the past. In particular their Acrylic Coating and for better protection maybe Polyurethane Coating both can be obtained in aerosol form, KEEP the stuff away from and DO NOT APPLY to any bare or plated contacts such as edge line connectors or sockets for obvious reasons.
    • LENOVO-A880
      Not A Bad BIOS
      • Feb 2014
      • 79
      • MALAYSIA
      Originally posted by llonen
      ...that said if you have had to remove any of the coating to effect repairs then I have found Electrolube products quite useful in the past...
      Will it be truly necessary to completely remove the existing coat on these memory module before even applying the new acrylic coat. What will happen if I don't remove the coatings as I don't have the necessary tools to do it?
      -Napoleon Hill
      -Charles Stross
      -The Mad Hatter
      • llonen
        • Sep 2014
        • 495
        • hampshire
        I am not sure what you are trying to achieve here, if the con-formal coating is intact and you have not removed any of the material to effect repairs I am not sure why you would need to add another layer.
        • Sparkey55
          • Jan 2010
          • 1523
          Originally posted by LENOVO-A880
          Hi Badcapers,
          I am assuming that you have your computer equipment in a wet humid enviroment. Try keeping it in a room with plenty of cool air circulating so as moisture does not cause a problem. The best method to keep electrical contacts clean and rid of moisture in the air is to use a product similar to DeOxit D5 or ProGold. Must be safe to use on electronics.
          • Geeker007
            9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
            by Geeker007
            Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
            I am new to electronics repair, so my queries could be naive but I am ready to learn.
            So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
            01-28-2025, 03:31 PM
          • glovecaps
            by glovecaps
            11-25-2024, 04:23 PM
          • Docus
            Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
            by Docus
            Hi everyone 😀,
            I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
            To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
            Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
            1. I already own the exact same model, but its plastic chassis is badly damaged.
            06-10-2025, 04:24 PM
          • Archimedes
            HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
            by Archimedes
            Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
            Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
            Fans are spinning. Blindly could install windows11 and got the device manager...
            07-30-2024, 05:14 PM
            ASUS P5GC-MX motherboard recap
            by momaka
            Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
            This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
            So here is what the motherboard looked like with its original caps:
            CPU VRM area up close…...
            01-27-2021, 11:59 PM
