Tools / technique for boards with eMMC repair?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8036
    Re: Tools / technique for boards with eMMC repair?
    This vid is interesting, how he flashed the eMMC on board.
    https://www.youtube.com/watch?v=Ff4S9Z2phIE
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8036
      It is possible to flash the EMMC with the programmer off the board and then solder the flashed EMMC to the board. I proved that. No problems.
      • megaraider
        • Jul 2015
        • 307
        • Portugal
        Next step will be to read (and write if needed) without removing the eMMC from the board (ISP)...
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8036
          I am not sure if you did read this thread: https://www.badcaps.net/forum/showthread.php?t=74150
          As long as the EMMC itself is good, I can read and write from and to it without taking it off the board. That is, IF one knows where to hook up the wires to. I have already proofed that in that thread above.
          • megaraider
            • Jul 2015
            • 307
            • Portugal
            I hadn't read that thread earlier.
            Then it's done: you've proved it to be possible in both ways
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
            • jb_Bak
              by jb_Bak
              CN6401
              Pin 01 NC
              Pin 02 NC
              Pin 03 "BL_ON": 0V
              Pin 04 "N/C"
              Pin 05 "STBY 3.3V": 3.5V
              Pin 06 "GND": N/C
              Pin 07 "AC_OFF"...
              09-27-2021, 04:52 PM
            • canadaboy25
              Panasonic TC-P54VT25 No image. A or D board?
              by canadaboy25
              I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
              I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
              01-17-2021, 01:06 AM
