Analogue T12 style controller - anyone tried it?
  • Agent24
    I see dead caps
    • Oct 2007
    • 4954
    • New Zealand
    I see the "T12" stations are quite popular now, and what I found fascinating was this thread here: https://www.eevblog.com/forum/review...p)-conversion/ - which includes an analogue control circuit for the T12 cartridges.
    Since I'm not really a fan of devices powered by undocumented microcontrollers, I'd rather have an analogue version - so much easier to fix (and cheaper).
    Has anyone used this circuit? One user in that thread says it works well and many people have built one - but so far as I can see, most people just seem to go for the OLED etc versions with more flashing lights.
    I'm quite tempted to build this controller and get a nice aluminium "Quicko" T12 handpiece for $20. Seems like a great deal - if it works.
    -David VanHorn
    • 31028
    Re: Analogue T12 style controller - anyone tried it?
    looks like bs, i cant see how it's using any tip feedback - it's just a variable current drive circuit.
    to work properly it needs to pulse the tip really fast, and read back the sensor between pulses.
    btw, there are open-source microcontroller based controllers you could make from scratch, or based on arduino/blue-pill
    • Agent24
      I see dead caps
      • Oct 2007
      • 4954
      • New Zealand
      From what I understand, it should basically work - unless I have interpreted it incorrectly.
      U1B will drive Q2/Q1 on while C2 charges via R4, until C2's charge reaches about 1/2 Vcc, then U1B should switch the heater power off.
      C4 (which would have charged up to 24v during heater power) will now discharge through the heater/TC until its voltage reaches the thermocouple voltage, and if that is lower than the voltage set by R2, U1A will go low and start to discharge C2 via D1, then the cycle repeats.
      If the iron is hotter, and the thermocouple voltage is higher, then the charge on C4 will keep U1As output high, and U1B will stay off until the thermocouple voltage drops.
      So in terms of temperature regulation and actually reading the thermocouple, I think it does do that. The question is whether or not it does it well.
      -David VanHorn
      • Agent24
        I see dead caps
        • Oct 2007
        • 4954
        • New Zealand
        Well, perhaps that is how it is supposed to work.
        But in https://www.eevblog.com/forum/projec...soldering-tip/ someone says he bought one and it did not function correctly.
        They seem to think the main problem is no thermocouple amplification, and there are probably other issues as well.
        Do you have any links to the open-source microcontroller versions?
        -David VanHorn
          • 31028
          one with oled is on eev,
          several are here:
          http://dangerousprototypes.com/forum/viewforum.php?f=56
          • Agent24
            I see dead caps
            • Oct 2007
            • 4954
            • New Zealand
            Thanks, I'll take a look.
            -David VanHorn
            • master3112
              ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
              by master3112
              I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
              When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
              10-29-2024, 09:32 PM
            • chth96
              Is it possible to test small ceramic disc capacitor with analogue meter?
              by chth96
              I read EBOOK of Testing Electronic Component and found that
              "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
              Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
              It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
              Is it really possible to test small ceramic disc capacitor with analogue...
              03-09-2024, 10:03 PM
            • ronnygracias
              Help with freemotion incline trainer with controller comm error
              by ronnygracias
              The treadmill was working fine, one day the belt snapped and after checking the unit I also noticed that the display is now showing the Controller comm error. So I opened it up and the treadmill had two boards. One is a power supply board and the other is the motor controller. I noticed there was a mouse nest, so I took power supply board out, cleaned it up, replaced the big capacitor and that did nothing. Then I took apart the motor controller and cleaned that up, and when I plugged it in, it started right up. I thought I fixed it. But when the belt arrived, I installed it and tried to power...
              11-04-2024, 01:32 PM
              Tankless hot water heater controller board not powering up when power is applied
              by sam_sam_sam
              I recently bought a used tankless hot water heater and the controller board is completely dead no power up when power is applied the display board works however the main controller board does not work correctly at all the fuse is good
              I bought a used replacement controller board that also had issues that I was able to fix and now the tankless water heater works correctly now
              However I would like to know if I could figure what happened to this controller board if possible
              Tomorrow I will take some better pictures of both side of both boards
              The...
              12-09-2022, 09:14 PM
              Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
              by sam_sam_sam
              This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
              I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
              I am comparing them to a brand new one that I installed
              The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
              I going to let it run for several days before I remount back on the wall next to the...
              09-05-2024, 06:48 PM
