CPC desoldering station offer (again)
    • 30983
    this time it should run till mid febuary!!!
    https://cpc.farnell.com/duratool/d00...g/dp/SD0138405
    • Jul 2011
    • 6036
    Re: CPC desoldering station offer (again)
    And if you live in USA
    http://www.mpja.com/Desoldering-Stat...info/19034+TL/
    • petehall347
      • Jan 2015
      • 4426
      hakko
        • Jul 2011
        • 6036
        https://www.circuitspecialists.com/C...yABEgKI8_D_BwE
          • Jul 2011
          • 6036
          hakko
          They are lot more money
            • 30983
            60£ does not translate to 120$
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              is there a service kit for these i cant seem too find one for the filters etc i can add too my order then
              EDIT!! found it and ordered both
              https://cpc.farnell.com/duratool/d00...-me-pd-mi-acce
                • 30983
                i recomend adding an inline filter.
                the one in the handpiece is not great, and i lost 2 weller pumps to poor filters!!!
                https://www.banggood.com/5X-Universa...-p-913243.html
                cant argue that price!!
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  thanks for the link i have just ordered some.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    great service from cpc ordered this station yesterday just had it delivered today
                      • 30983
                      i find setting it to 260 is enough for anything.
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        Thanks i will set it up tomorrow and test it out
                          • Jul 2011
                          • 6036
                          This is true most of the time except when you have double sided boards with very large ground planes then you have to maximize the temperature setting to all the way ON and maybe a hot air temperature controlled gun also together
                          Most of the time I have mine set a 775* F unless I am doing a single sided board then I have it set to 550 to 650* F
                            03-31-2024, 02:12 PM
                          • armini
                            18VDC PSU completely dead - ZD-915 desoldering station
                            by armini
                            Hi everyone!
                            Three years ago I got a ZD-915 desoldering station which failed just after a few months of light use. During a short desoldering session, the station simply shut down, and since then it has been completely dead and unresponsive. The failure was silent, without any pops.
                            Due to a lack of time, I set it aside and didn't look at it.
                            Yesterday, I took it apart and did some basic measurements. The 18v terminal shows 0v. In addition, there is no visible damage to the board itself.
                            According to replies in 18VDC PSU has dropped to...
                            04-25-2023, 07:49 AM
                            07-01-2024, 06:34 AM
                          • rippergr
                            Desoldering station ZD 915 no indications, no heating
                            by rippergr
                            Hello all,
                            I tried to power on my desoldering station ZD915 today and altough the LCD has power and it's on I don't have any indications on the screen and the gun is not heating at all.
                            I open it up and I don't see any visual fault anywhere.
                            Does anyone has any clue what should I check?
                            10-24-2023, 11:46 AM
                            ZD desoldering station pump rebuild
                            by stj
                            just did one.
                            works great.
                            so here's the discoveries.
                            the pump "modules" have 4 parts, the main body, the outside bit, the inside bit - screwed to the main body, and the diaphram.
                            the failure is the inside bit, it has a rubber coating for some reason that becomes tacky and breaks down - contaminating the diaphram.
                            so you need to clean everything to get rid of all the tacky black stuff.
                            then reassemble it.
                            *BUT*
                            you must put the 2 screws into the assembly only finger-tight.
                            if you tighten it properly the valves dont work....
                            08-21-2024, 05:59 PM
