Importance of wicking during rework?
  • caphair
    • Nov 2011
    • 1249
    I'm wondering how crucial it is to remove as much of the old solder on a bga chip and corresponding PCB pads.
    Is it best practice to always wick before applying fresh leaded solder? (Presuming most original solder will be lead-free)
    Or could you just make a few passes with a big glob of leaded solder across the pads with the iron?
    Any side effects if both types of alloys mix together?
  • brethin
    • Dec 2008
    • 1907
    Re: Importance of wicking during rework?
    Whatever works best for the job, no problems with mixing.
      • 31255
      most wick wont work well with lead free solder, the makers have not bothered to update the flux formula yet.
      • caphair
        • Nov 2011
        • 1249
        So it won’t affect melting temp or not mix properly if all the old solder isn’t removed first before reballing? There’s conflicting info about the subject when I searched.
        Some say it creates poor connections that can cause issues
        • diif
          • Feb 2014
          • 6978
          • England
          I've always cleaned with a ball of leaded solder followed by removing the rest with some decent braid. I've never had any issues.
          Of course it all needs removing, otherwise there will be uneven melting of the leaded solder on the BGA whilst the motherboard still hasn't melted due to the lead free.
          Why wouldn't you remove all the leaded solder ? it's not difficult or time consuming.
          • llonen
            • Sep 2014
            • 495
            • hampshire
            Always remove as much of the remaining solder for bga rework, come to think of it for rework really, SMD or otherwise although I make use of a pace solder extractor for through hole plated stuff and if I am feeling particularly lazy I will use on single sided non plated through rework as well. I don't have problems with lead free and various wicks but then I add flux anyway.
            • corrize
              Best way to solder LVDS connector for beginner (and qfn) ?
              by corrize
              Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
              I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
              I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
              See the test :
              https://youtu.be/bNAzC-EvqHs?t=1767
              With hot air from bellow the board, that's...
              03-09-2023, 02:57 AM
              Multifix 425-01 and 450-01 Rework Flux Datasheet
              REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
              - No Clean Formulations
              - Low residue
              - Range of activity to deal with different component solderability
              - Halide free
              - Suitable for dispensing
              - Compatible with solder coatings and/or No Clean flux cored solder wire product range
              Both products are supplied in syringes or cartridges for application by dispensing....
              10-07-2024, 06:02 AM
            • myth77
              UV solder mask - high temp resistent, recomendation?
              by myth77
              Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
              Is there any solder mask...
              03-28-2022, 04:04 AM
            • acedogblast
              by acedogblast
              11-02-2024, 05:13 PM
            • sircastor
              Solder not reflowing - what am I doing wrong?
              by sircastor
              I'm trying to fix a broken MacBook Air, and got a parts board to salvage components from. Following the suggestions of many folks here, I wanted to get in a little practice of using my hot air station (A Quick 957DW+) on the parts board so I know what kind of behavior to expect.
              For the life of me, I can't get anything done with this thing. I have tried multiple temperatures (from 210-425c), different air speeds, preheating the board (with the hot air, just warming it all around). I have applied what feels like excessive amounts of flux (Amtech V2-TF-559) and the solder on these components...
              03-03-2024, 02:44 AM
