Repair BGA Machine
  • caspian
    • Oct 2015
    • 1589
    • Laptop
    Repair BGA Machine
    Dear Technicians,
    High-quality BGA machines are expensive. They may degrade or fail after some period of time. Now the questions are:
    1. What kinds of such BGA machines are repairable?
    2. What parts of such a BGA machine are repairable by laptop technician?
    3. What parts of such a BGA machine do not worth repairing even by machine manufacturer?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Repair BGA Machine
    Any machine has the ability to fail and be repaired.
    I guess the heaters will age and need repacking at some time maybe. Or adjust the profile until it's to far out of spec.
    • caspian
      • Oct 2015
      • 1589
      • Laptop
      BGA machine is the main cost for a Laptop repair shop. It would be great if Laptop technician knows how to repair his/her own BGA machine.
      I heard home-made BGA machines and cheap BGA machines may burn the chip. So we have the only option of an expensive BGA machine.
      I am a computer hardware technician and do not know about PID controllers and analog electronics.
      • Stefan Payne
        • 1267
        You know about Louis Rossman?
        He's saying you are wrong.
        And a BGA Repair Machine is the last thing you need.
        And be honest, for what do you want/need one?!
        To replace Chips you can't get!!
        Or are too expensive anyway - like CPU. And they are so expensive that you can easily replace the Motherboard.
        Buttom Line:
        The main tool is your brain and a good Soldering Iron and Hot Air station.
        Also some Multimeters and a Powersupply. That's most of what you need.
        If you need to replace a BGA Chip its mostly beyond economical repair...
        And just think about how long it takes you to replace a big BGA Chip like Chipset or Graphics card. An Hour?? 30min??
        And if we are talking about hourly cost of 50€/h is it really worth it?
        Especially if we are talking about an i7 CPU for 500$ or more...
        • caspian
          • Oct 2015
          • 1589
          • Laptop
          I think we should find a way to make BGA chip replacement economical. But I do not know how.
          • diif
            • Feb 2014
            • 6978
            • England
            It takes less than an hour to strip, reball/replace a chip and assemble the motherboard.
            Makes it economical on motherboards over £100 IMO.
            £500 for a BGA rework station is not expensive and many people make their own.
            It's just a bottom heater and hot air/IR at the top and a way of controlling them.
            • caspian
              • Oct 2015
              • 1589
              • Laptop
              I heard home-made BGA machines and cheap BGA machines produce uneven heat to the chip and cause some damage to the chip. This damage is not detected at first. After a few months, the chip may become faulty.
              • jasko_jacker
                • Oct 2014
                • 1137
                • italy
                I built one of these bga rework machines, I used the same components of the best brands and I have been using it for years without problem.
                The bga are very sensitive at the top temp of the profile, if you don't use a good thermocouple (omega is one of the best brands) or use a wrong profile the solder process fail for many reasons.
                • dellxps15
                  • Feb 2014
                  • 1588
                  • italy
                  saying that bga rework is useless just because luiss sayd that is no sense.
                  1) he was so lazy to even not reballing the chip with leaded, and resolder it with lead free and not proper flux application (according to some video ' ve seen)
                  2) wich suppliers he got bga chip from ?
                  i rework from years and when a chip is good, it will last years without any problem.
                  i reworked also their own bga and working fine from more then 3 years.
                  problem on bad bga rework are:
                  1) good profile not too fast ... process need at least 6 minutes on air rework and 6-8 on infrared, plus depend if we are in winter time or summer time
                  2) take care of new bga, reball with lead free balls using low temperature and more time
                  3) good flux and proper amount. good flux make whole zone temperature equal... it lower the temperature of working area, but make it more equal.
                  4) proper pads cleaning with good solder wick and proper flux amount
                  5) try not to use ultrasonig on bga for cleaning, and wait a bit after reballed before cleaning it and resolder it.
                  6)get lots of experience
                  7) check why bga has failed; dust, bad heatsink proportion respect bga heat, overcurrent, bga dead because of something else.
                  if u do a proper rework and have skill to not have a good bga rework, but keep in mind that things, u can make a rework also with cheper bga rework machine.
                  there are company that their work is get bad bga for reuse. they sacrifice pcb, heating it only from the bottom for getting a good bga chip. they also reball it using laser that melts only balls and dont heat bga. so a used bga can be good as new, if they get it out of pcb in the proper way.
                  • caspian
                    • Oct 2015
                    • 1589
                    • Laptop
                    It seems most laptop technicians (such as me) are computer technicians who do not have enough Electronics knowledge. They only know basic components such as resistors, capacitors, and some ICs. Thus, I do not know much about the parts used in making a BGA machine, such as PID controllers and Triac and Sensors.
                    It would be great if a laptop technician knows how to repair his/her own BGA machine. for example, if a part in the machine gets faulty, the laptop technician should be able to detect it. the part should be a standard part available in the market so that the laptop technician can buy it and replace it.
                    The idea of Laser-based BGA machine seems great, but I do not know how well they are in BGA rework.
                    Now, which one do you recommend : a home-made BGA machine, or a cheap BGA machine, or an expensive BGA machine such as ZM-R5860C ?
                    • dellxps15
                      • Feb 2014
                      • 1588
                      • italy
                      i have a full ir bga rework, and the pcb is full of 3 pin transistor... maybe 30 or more, one bigger chip and that's all. dont know if repairing it will be easy...
                      for bga machine, ofcourse big price = bigger quality and features.
                      bigger price also means bigger heat, plus some bga around 5000 ollars offer also an auto allignment for bga place on pcb. that is very useful if no marks on pcb such as macbook.
                      home made or already done machine ? well depends...
                      on already made bga rework, u can focus only in make a good profile...
                      on home made, u have to assembly, find some tutorial on google, make the chassis, fan placement, mainboard (arduino or others) that control pid and so on. then u can focus on profiles...
                      how much time u have for it ?
                      edit: also when try to make some rework... u can try with non working board, but in that case who know if u have done the work right ?
                      so first u have to practice in desolder and solder bga, reballing too and see if resolder is done properly ( not bend bga or pcb balls as it can solder more one side and less the other).
                      after that u have to practice on working laptop and see if they work too after rework.... and thatcan be a lot of money waste...
                      • jasko_jacker
                        • Oct 2014
                        • 1137
                        • italy
                        I think that a laptop technician should have a full electronic knowledge because otherwise only simple problems are solved.
                        A welding machine is very simple, it is made of a few pieces and a technician should have no trouble understanding its operation.
                        If you do not know how it works you will probably have a lot of problems in using it especially on low-cost machines that need to be slightly modified.
                        I do not mean that you must know the concepts of physics, such as infrared penetrate into different materials, black body theory, etc.
                        Probably the only soldering machine is not enough, you need a good stereoscope (not usb digital) and quality products, stencils, flux, etc.
                        (instead of triacs, digital relays are used; one for the top heater and second for the bottom heater in the simplest configuration)
                        I preferred to build my welding machine not to save money but because those that cost around 1000 - 3000 eur as jovy re8500, achi, etc had constructive problems because they are built to be used in different situations. I spent about 1000 EUR and I would only change it for an automatic soldering machine that costs over 10,000 euros.
                        • caspian
                          • Oct 2015
                          • 1589
                          • Laptop
                          thanks a lot.
                          A computer hardware technician only knows digital components of Electronics and has a digital view of Electronics. For example, they know AND/OR gates, digital ICs, low-voltage Mosfets, voltage dividers, bulk converters, digital power circuits, and other digital circuits. They do not know about triacs and relays which are analog components. They do not know about analog power circuits. They do not know about electronics control systems such as heater controllers.
                          That is why computer technicians always need electronics technicians. Probably, electronics technicians need computer technicians in software problems.
                          • jasko_jacker
                            • Oct 2014
                            • 1137
                            • italy
                            I was talking about motherboard repairs (laptop, desktop, etc) at the chip level and consumer electronics (ups, routers, drone, etc) as you know on a motherboard there are not only digital components, for example mosfet and transistor do not work in digital and also resistors and capacitors ...... A PID works in digital as well as a relay in the rework machine. If you know digital well, then you surely know how to program a micro like a pic or an atmega328.
                            Personally, after I have repaired a laptop, I install the operating system and drivers only not software engineering, hacking, etc
                            • caspian
                              • Oct 2015
                              • 1589
                              • Laptop
                              What kinds of BGA machines use standard parts which are available in the market for part replacement?
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                • Romania
                                Pretty much all of them use fairly standard parts. I have seen both IR plates of all shapes and sizes and heaters for the machines that use hot air. On most BGA stations under $1000 you will also find the same type of programmable PID controllers. For the more expensive machines with touchscreen control, if you noticed, it almost always says "MCGS" on it - that is the manufacturer name, and apparently a lot of Chinese industrial equipment uses the same screen so you won't have a problem getting that, either.
                                So i am pretty sure that spare parts would not be your concern. Either way, even on cheap machines, there are rarely actual component failures, it's mostly wiring and/or terminal blocks which tend to fail, and those can easily be replaced with parts from the local hardware store.
                                A working TV? How boring!
                                • jasko_jacker
                                  • Oct 2014
                                  • 1137
                                  • italy
                                  this is the reason why I preferred to build the rework machine instead of buying it, the first picture shows the profile of my machine, the second of a commercial machine (achi ir6500 ?)
                                  • Th3_uN1Qu3
                                    Believe in
                                    • Jul 2010
                                    • 6031
                                    • Romania
                                    It is very well known that the IR6000 and 6500 and all variations use really poor quality plates for the top heater (except the IR-Pro-SC which is better). A very popular modification is fitting an Elstein plate for the top heater.
                                    The IR6000 is very cheap now but i would not waste money on it, it is not adequate for today's sensitive chips.
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 4955
                                      • New Zealand
                                      Another question I would ask - did the people with failed BGA rework jobs preheat the board and BGA to remove moisture?
                                      Many chips nowadays (and the PCB to an extent) are moisture-sensitive. If you do not bake the board\IC according to manufacturer specifications, to remove the moisture, you can cause damage when you do the rework.
                                      https://en.wikipedia.org/wiki/Moistu...sitivity_level
                                      -David VanHorn
                                        ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
                                        This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                        09-12-2024, 03:28 PM
                                      • CG2
                                        Janome DC3050 Sewing Machine Pedal Resistance
                                        by CG2
                                        OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
                                        Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
                                        04-14-2023, 07:53 AM
                                      • Soulzink
                                        Samsug washing machine. Power supply DC41-00189a board issue
                                        by Soulzink
                                        I am trying to fix a samsung washinmachine power supply main board.
                                        I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                        Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                        The power supply board reference is the following: DC41-00189a
                                        I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                        04-19-2025, 06:26 AM
                                      • unimatrix93
                                        How to stabilize AC voltage to CNC machine
                                        by unimatrix93
                                        Hello there everybody, I'm not sure if it's the right topic to ask this but I hope so.
                                        I have a CNC machine wired to 3-phase 230V AC.
                                        It's a smaller CNC machine with a 3500W motor, do it does not uses much power.
                                        The problem is, when the residents come home and put load on the network, the voltage can drop to around 207V which is fine for most household items but by CNC machine stops working from this.
                                        I contacted the electricity company but they refuse to help me solve this problem.
                                        So I started to look around for some DIY...
                                        03-17-2025, 05:52 AM
                                      • xdever
                                        820-01700 not booting, 4V PP2V5_NAND_SSD0 but 2.5V when the machine is off.
                                        by xdever
                                        I got a 820-01700 of a friend that doesn't turn on. I read that a typical issue with these boards is the TPS62180 generating the NAND voltages, so this is where I started looking. Sure enough, PP2V5_NAND_SSD0 is 4V when the machine tries to turn on (I try to determine this by measuring PP2V5_NAND_SSD1, which is 2.5V as it should in this case. The PP0V9_SSD0 and PP1V8_SSD0 power supplies for the SSD are on at the same time when PP2V5_NAND_SSD0 is 4V). The extremely weird thing is that when the machine is off (PP2V5_NAND_SSD1=0, PP0V9_SSD0=0 and PP1V8_SSD0=0), PP2V5_NAND_SSD0...
                                        01-15-2025, 08:44 PM
