Solder differences and desoldering tools/technique
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8696
    Re: Solder differences and desoldering tools/technique
    Speaking of solder, I have some noname 99.3/0.7 (Sn/Cu) lead-free solder. It is supposedly "rosin core" flux but when I cut a piece of the solder wire off, the "core" looks white-ish.
    Recently I got a small tub of pipe solder flux, and this stuff is white (!!!).
    This is 0.4mm wire solder so it's definitely not for pipes. Anyone know what kind of in-wire flux this is? I sure hope it's not the white acidic flux.
    Incidentally, when heated and vaporized, this stuff does smell like rosin. Just looks too light colored to be rosin...?
      • 30979
      leadfree solder cant use pure rosin, the big delay developing lead-free solder was the time taken to get the flux right.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8696
        Ah, interesting. That would explain things, the flux core must be some mixture of rosin and something else or something else entirely.
        I wonder if this roll of 99.3/0.7 will start growing whiskers. and oops, this is actually 1mm solder, not 0.4mm, but in either case it's not pipe solder which tends to be quite thick...
          • 30979
          i think the wiskers thing is mostly myth.
          to get something to crystalise it has to come from somewhere - maybe poor cleaning at a pcb factory leaving a very thin layer of tin-plating solution on the board.
          i'v seen no evidence online on anything hand-soldered.
          for serious work, there are even special solders from company's like Fuji with stuff like Bismuth added - but that shit costs a fortune!
          • clearchris
            • Dec 2013
            • 687
            To replace caps on motherboards I often use a hot air SMD station (preheat), soldering iron and desoldering gun. On stubborn caps sometimes I heat each lead and gently rock the cap back and forth until it comes out.
            A few years back I bought a Aoyue 474A++ and I'd never want to go back to a solder sucker. It's really quite a luxury that makes repairs so much quicker.
            • mattch
              • Mar 2010
              • 121
              #26
              I found some SS dental picks I use to Poke hole through solder pad, no heating required!
              • Curious.George
                • Nov 2011
                • 2305
                • Unknown
                #27
                On stubborn <whatever>, I physically destroy the component to leave just the "pins"/leads in (or on!) the board and then remove the remains, individually. Particularly useful when removing from solder (foil) pours that haven't been sufficiently thermal-relieved!
                • acedogblast
                  by acedogblast
                  11-02-2024, 05:13 PM
                  Multifix 425-01 and 450-01 Rework Flux Datasheet
                  REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                  - No Clean Formulations
                  - Low residue
                  - Range of activity to deal with different component solderability
                  - Halide free
                  - Suitable for dispensing
                  - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                  Both products are supplied in syringes or cartridges for application by dispensing....
                  10-07-2024, 06:02 AM
                • chth96
                  Is it good to use chemistronic flux off es835b for flux remover?
                  by chth96
                  I want to purchase any good flux remover But "chemistronic flux off es835b" is the most common flux remover in my nation..
                  Or I have to purchase "3m novec flux remover" which is quite expensive in my nation?
                  11-17-2023, 07:25 AM
                • myth77
                  UV solder mask - high temp resistent, recomendation?
                  by myth77
                  Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                  Is there any solder mask...
                  03-28-2022, 04:04 AM
                  03-31-2024, 02:12 PM
