Thoughts on this ESR meter
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8688
    Re: Thoughts on this ESR meter
    I don't have any supercapacitors in my spare parts box, but do have 0.3F, 0.22F, and ~100mF capacitors. Also a bunch of ones from 10mF to 56mF; at least the 6.8mF, 10mF, 27mF are within that range.
    These >50mF caps are quite large... they're all on the order of a half liter bottle. I just wonder how long it takes for it to measure capacitance on these big capacitors...
    My portable DMM already takes forever to measure 100uF capacitors, and 0.22F takes a while on my Sencore... annoying...
    • gearhead63
      • Jul 2014
      • 14
      I know EVERYONE wants an ESR meter, but I still use my EICO 950B, can test caps for leakage at up to 450 volts! ESR meter can't do that!
      • chth96
        by chth96
        03-09-2024, 10:03 PM
      • jorpec
        by jorpec
        Hi
        Thnaks
        01-23-2023, 10:37 AM
        Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
        12-14-2023, 07:45 PM
      • Stephan Mathers
        EDMI ATLAS MK10 Electronic Meter Discussion
        by Stephan Mathers
        Greetings, new guy here but always interested in the crazy universe of modding
        We just finished construction of around 25 vacation houses, all inside the same private area.
        Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
        The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
        Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...
        05-20-2025, 09:09 AM
      • eccerr0r
        lowest current galvanometer/analog meter (passively powered!)
        by eccerr0r
        Most analog meters are actually current driven - a current is needed to deflect the pointer full scale. They can be lots of different values. There are ones that can take several amperes to swing the pointer as they have internal shunts.
        On the other hand there are many that are rated in microamps for the intent that they draw as little power as possible from the devices under test. Some are 1mA, 500µA, 200µA, 100µA, and the ubiquitous 50µA frequently used in analog VOMs. There are even 20, 25, 30 µA and even down to 10µA. Been collecting a bunch of different ratings and...
        04-16-2025, 12:41 AM
