new style led tester
  • vinceroger69
    • Mar 2012
    • 6714
    Just saw this on ali express so it looks like it powers the leds and tests the amps? would this show us shorted leds easier
    https://ru.aliexpress.com/item/AC-22...3-2e39c91e7e13
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: new style led tester
    This looks good but the labels are in...is that Chinese??
    • vinceroger69
      • Mar 2012
      • 6714
      yes i think it is chinese ive been looking for a user manual but cant find one theres no videos on youtube either of this unit in action.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        I'll see what I can find...
        • vinceroger69
          • Mar 2012
          • 6714
          just wondered if it was better than the type shopjimmy sell as this one seems too tell the amps too so wondered if that would suggest a shorted led etc
          • sspoonmann
            • Mar 2012
            • 12
            • king
            the one from shop jimmy works great. shows shorted led and is automatic.
            SID GJ2C LED TV Backlight Tester
            http://www.shopjimmy.com/sid-gj2c-le...ght-tester.htm
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              Yes. I have the GJ2C also and found backlight troubleshooting very easy with it. I also have a CCFL backlight tester and I am using it a lot these days as there are a lot of CCFL/EEFL backlights failing now......I have successfully converted LCD TVs to LED TVs....well 5 of them so far as some customers prefer to just get a new TV.
              • dskall
                • Oct 2016
                • 2905
                • usa
                Looks nice for you 220v guys. Looks adjustable although I can't read Chinese or russian
                  Notes from web site:
                  0-180 V Output LED Backlight LED Tester LCD TV LED backlighti Tester Lamp beads Light light board Tester FREE SHIPPING
                  multi-adjustable LED lamp repair tester
                  Operating Voltage: AC 180V-240V ( not international)
                  output voltage (withstand voltage): 0-180 In
                  1. Adjustable output voltage, output current. ( Please change the test current voltage because there is no soft start protection technology.
                  instant large current may cause a malfunction of your lamp
                  2. Adjustable brightness lamp beads.
                  3. Medalions leak detection.
                  4. Two high-precision meter reading data, high precision.
                  5. Automatic adaptation of control lamp beads / lamp voltage panel.
                  6. The voice prompts lamp beads without seeing and increase efficiency.
                  7. Electrical insulation safer, touch one end of the power is not a man. (Note: do not touch the positive and negative ends at the same time)
                  8 can be detected below 180 V LED voltage.
                  multi-adjustable LED lamp beads service tester tests and operation of the LED lamp beads equipment. specially designed for the majority of electronic enthusiasts. lamp beads to solve caused during assembly does not shine the light does not cause any problems. you can quickly identify problems that lamp beads. thus effectively improve service efficiency and save maintenance time, reduce indirect labor costs.
                  the operation is very convenient and simple, red pen and a black pen alignment plate or lamp beads can detect positive and negative, the normal lamp beads Lights. when the two faced pen, forming the path of light.
                  Output current range: 0 ~ 20mA
                  Package includes:
                  1 PC. tester
                  2 pcs. test pen (Black and Red)
                  1 PC. LED panel light transmission cable
                  1 PC. EU plug power adapter
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    Package includes:
                    1 PC. tester
                    Thanks budm for that information would you use one of these? or prefer the shopjimmy model they sell as it automatically does the soft start voltage etc.
                      I would use the one with soft start. You can get the same tester that SJ sells from Amazon too.
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        Thanks i will order one asap as its a handy tool to have.
                        • nubinator
                          how can i test individual leds without tester
                          by nubinator
                          Hello I have TCL 65S4 and it has no backlight, seems common problem on this tv to have bad LED's. I have no tester though I thought I could just test each LED with 2xAA batteries for 3v but it doesnt light up at all?
                          I saw a vid with LED tester on this TV and it had 130v for 1 good line which is 24 LEDs does that mean it needs around 5.5v per LED?
                          10-25-2022, 11:05 PM
                        • Pipolups
                          Corsair K70 LUX RGB dying LEDs
                          by Pipolups
                          Hi there !
                          I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                          Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                          10-08-2024, 11:58 AM
                        • lmcancu
                          RCA RLDED 4331B: 43 inch LED TV: Backlight issue
                          by lmcancu
                          Hi I am having an issue with the LED backlight of this TV. I can see the picture with a flash light, so I determined it was a backlight issue.
                          Initially, after opening it I found 2 shorted and 1 open LED on 2 strips (total of 4). I removed the LEDs and shorted the pads together to verify if the backlight would work.
                          Testing it, I found the backlight turned on and I measured 54V when TV was in standby (off), and 100v when TV was turned on. The 4 strips each contain 9 LEDs, so 36 in all minus 3.
                          Instead of putting it back together I decided to replace...
                          04-01-2023, 01:11 PM
                        • Fisher8865
                          MacBook Pro A1990 stuck at 5v .592 amps
                          by Fisher8865
                          Hi guys
                          I have a MacBook Pro A1990 that takes 4.9 Volts and .592 to .615 amps on one port. The other port on the left side power cycles with about the same amount of volts an amps but quickly power cycles. The same thing happens on the other side but opposite. So on the left side the bottom port stays on and on the right side it's the top one. I think it is a CD3215 chip but I am not sure how to test it or where to get one. I have checked for voltage at ppbus_g3h and it has 12.6 V which is also on fuses f7000 and f7001 I checked pp1v2_s3 and it has 1.2 V then...
                          05-30-2024, 07:36 PM
                        • Lifeisfun
                          Trying to troubleshoot DDR4 SODIMM slot with slot tester
                          by Lifeisfun
                          Hi folks!
                          I have some kind of memory problem on Lenovo laptop. I was initially able to install windows after several tries since the laptop did freeze in middle of those attempts.
                          Eventually I discovered that it was related to moving the laptop.
                          Later on it even stopped booting unless I pressed around the memory slot. (no keyboard LEDs only power button responds)
                          If I remove the RAM I get the beeps that RAM is missing. Inserting the RAM there is silence and it will not boot most of the time. No picture.
                          I removed the board got one of those memory slot testers...
                          06-04-2025, 02:26 PM
