Default oscilloscope channel trace colours
  • japlytic
    • Oct 2005
    • 2086
    On eBay, I happened to observe varying degrees of consistency of oscilloscope default trace colours per channel between a number of manufacturers, especially the Chinese manufacturers.
    I concluded that LeCroy and Sigelent use the same default trace colours, and most major Chinese manufacturers follow the Tektronix trace colour scheme to varying degrees (Micsig follows it completely, Hantek for certain units, Rigol with the exception of Channel 4 - Atten and Tonghui also follow this scheme despite not manufacturing 4 channel units).
    • 31199
    Re: Default oscilloscope channel trace colours
    all my traces are blue.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Lucky blue...
      All 4 of my traces are green, dang that P31
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        Turquoise here... Dang odd hybrid digital/analog techtronics scopes......
        Follow the white rabbit.
        • pb1911nt
          MacBook Pro A2251 - 820-01949 Voltage Drop and unkown issues.
          by pb1911nt
          Hello forum,
          I'm still relatively new to the world of electrical repairs.
          I have a Macbook here that I can't figure out
          When the battery is gone, the USB input consumption goes up to 20 V and 0.06A. But it breaks down after about 2-3 seconds and you can also hear a small ticking on the logic board. But I can't pinpoint it exactly.
          I removed the logic board and took a few measurements.
          But I can't really figure it out.
          At first I thought the infamous CD chip was defective - but then of course you read more on the internet...
          09-07-2025, 11:35 AM
        • eccerr0r
          old X58 triple channel board... memtest86 memory speed?
          by eccerr0r
          Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
          Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
          Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
          06-28-2025, 09:06 AM
        • spleenharvester
          Reverse engineering of 18650 4-channel tester
          by spleenharvester
          Hi friends
          I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
          05-04-2025, 02:43 AM
        • chth96
          Is it possible bridging tiny broken trace
          by chth96
          When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
          cutting tiny trace.
          This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
          Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
          But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
          12-03-2022, 11:32 PM
        • mikey5791
          Help on car amplifier only one channel works
          by mikey5791
          Hi all forum members,
          Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
          My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
          08-06-2025, 10:36 PM
