Ut 61e multi meter
  • hazim
    • Mar 2016
    • 62
    • egypt
    Ut 61e multi meter
    i want to ask IS ut61e digital multi meter measure frequency til 220mhz ??
    and what's the correct way to measure frequency on laptop mb with ut61e ?
    thank for all of you
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Ut 61e multi meter
    Modern CPUs you will not see the main clock output on the board, so you won't see the GHz numbers. You should be able to measure PCI/PCIe clock speeds though most multimeter probes probably add so much load that it will affect the operation of the machine...
    ... then again I saw specs of a UT61E and it says the bandwidth (probably 3db) is only 10KHz, so you won't see PCI/PCIe clock frequency either.
      • 31010
      it can read 220MHz and even a lot higher, but i'm not sure what the minimum voltage of the pulses are.
      • Longbow
        • Jun 2011
        • 623
        Sorry folks, but a US $50 multi meter is not going to function as a frequency counter much beyond 100 KHz. The front of the unit says 250000 counts. That does not translate into 250 MHz capability. A f.c. for 250MHz is precision lab test equipment not to mention the expensive HF probe that would be needed to sniff a 3 volt (or less) clock line.
        A good quality scope might be able to do it. It is important to know the limits of your equipment. This does not mean you can't do a lot of good troubleshooting with this meter, however.
        Is it plugged in?
          • 31010
          times change, i have an 8digit 2.4GHz counter for £8 from china.
          i tested it at 446MHz using a radio and it was spot-on and very sensitive.
          • hazim
            • Mar 2016
            • 62
            • egypt
            (It is important to know the limits of your equipment)
            i'm agree with (longbow) it's good opinion thanks for all my friends specially (stj)
            i bought ut61e from 10 days
