CH341a - Questions
  • akande
    • Dec 2017
    • 278
    • Nigeria
    Re: CH341a - Questions
    Originally posted by stj
    read the chip, then use the verify option - do it atleast 5 times.
    that will tell if it's reading o.k. - if not then it's probably a bad connection to the chip or adapter.
    Tanks for quick response, what i mean is that i was able to backup my bios bin before earasing and writing another bios i downloaded from the internet, but programming the verification faied which so that the bin mismartch with the bios. after that, i try to rewrite my backup bin but the verification still doesnt march . pls friends i need ur assistance cos my laptop is brink
      • 31294
      did you desolder the chip, or use a clip?
      • akande
        • Dec 2017
        • 278
        • Nigeria
        i desolderd the chip
          • 31294
          and how many times did you read it - more than once i hope!
          i think you need to start with a new chip - then we can see if the programmer is good.
          btw, are you using a socket, or soldering the chip to a header every time?
          • akande
            • Dec 2017
            • 278
            • Nigeria
            thanks for reply, am scared its not my programmer cos i have to write another hp 655 bios which as also result to death of the pc. i have a black ch341a programmer pls help me out
              • 31294
              well lets find out.
              get a chip, and erase it.
              then verify that it's erased.
              then fill it with something - anything.
              then verify it.
              then repeat a few times.
              now a quick lesson for everybody - and i mean everybody.
              when you dump a chip, dump it atleast 3 times.
              and if it's using a socket, take it out and put it back between each read.
              then compare the files - if they dont match you have a bad dump - and a problem.
              a simple way to compare files is to use a checksum program.
              https://github.com/sunjw/fhash
              just to add, the bigest problem with dumping/programming is a poor connection between the chip and programmer.
              • megaraider
                • Jul 2015
                • 307
                • Portugal
                #27
                (...)then compare the files - if they dont match you have a bad dump - and a problem. (...)
                Recently I've experienced several annoying setbacks using the ‘CH341a - Black Edition' reading S25FL128:
                - It simply refused to give consistent dump results!
                After excluding several causes it came to my attention I had to doubt the programmer software.
                Turns out that the version I was using, v1.30 (and version v1.29) was the problem.
                Falling back to version v1.27 solve the problem (consecutive dumps were consistent and later dump contents were verified to be right).
                  • 31294
                  i wouldnt know, i use 1.18
                  the hardware is now supported by "flashrom" btw,
                  so there is a total of 3 different softwares to use.
                  https://www.flashrom.org/Flashrom
                  • armand
                    • Nov 2011
                    #29
                    Originally posted by sadecebel
                    I tried to uptade the driver from chosen location, windows said that this driver not used for this device and I try old device modul from device manager to install the driver therefore windows says this driver can not suitable for amd64 driver I try all version of driver and/or all versiyon program packet (until version 1.31) nothing change ...
                    hi sadecebel, did you manage to solve the problem? same issue here
                    • megaraider
                      • Jul 2015
                      • 307
                      • Portugal
                      #30
                      Thanks, i was unaware
                      • akande
                        • Dec 2017
                        • 278
                        • Nigeria
                        #31
                        well lets find out.
                        then verify it.
                        then compare the files - if they dont match you have a bad dump - and a problem.i dont want to risk another bios which of d progammer more reliabl the give accurate result?
                        • Haris27
                          • Mar 2023
                          • 8
                          • Pakistan
                          #32
                          HI. can anyone help me i bought a CH341 and a test clip with it. my laptop HP 840 G3 has bios password which I wanted to remove. first of all the clip wasn't actually fitting on the chip because the clip was large. so i cut it a little and sometimes the clip fitted perfectly but there was no light in at power led. i tried running it through ASprogrammer but it shows an error like FFFFFF(Unkown) something like that. can anyone help me what should i do right? is the clip not fitting perfectly or there is another problem> Thanks
                          • lotas
                            • Jan 2016
                            • 4899
                            • Russia
                            #33
                            For the correct reading of the dump, you need to desolder the flash and read it separately into non-circuits.
                            • Haris27
                              • Mar 2023
                              • 8
                              • Pakistan
                              #34
                              Thanks. appreciate your advice. but that was not the point I didn't want to desolder the bios chip but now it seems like this is the only solution. I am initially scared to do that and don't even know how to do it. so now I am just gonna take it to a shop and get the password removed. Again thanks for the help!
                              • R_J
                                • Jun 2012
                                • 9625
                                The ic you are trying to read is not isolated from the rest of the circuit, when you are powering the memory chip with the clip from the programmer you are also powering (or trying to), everything else connected to the ic's vcc such as the microprocessor, any memory etc. The usb programmer can't supply the current and if it did the microprocessor would likely interfere with any reading
                                • Haris27
                                  • Mar 2023
                                  • 8
                                  • Pakistan
                                  #36
                                  Sorry for asking too many questions. so you are saying that my only option is to desolder the chip and then read the ic? btw thanks for helping
                                    • 22191
                                    Youve been using a SOP8 clip with a WSON8 chip, it is the wrong adapter to use .You can solder wires to the gold pads ,then to the programmer adapter, or cut the clip off and use those wires
                                    • Haris27
                                      • Mar 2023
                                      • 8
                                      • Pakistan
                                      #38
                                      Thank you so much. man, I thought that maybe I was using the wrong clip because It wasn't fitting the chip lol.
                                      thanks for the help.
                                      • Haris27
                                        • Mar 2023
                                        • 8
                                        • Pakistan
                                        #39
                                        So let me understand completely. Basically, you are saying that cut the wires from here and solder them onto the gold pads and then use the rest of the programmer as it is right?
                                        Really appreciate your help!
                                          • 22191
                                          yes
                                          https://www.badcaps.net/forum/showthread.php?p=1075236
                                          https://www.badcaps.net/forum/showth...ads#post938122
                                          https://www.badcaps.net/forum/showth...ds#post1141917
                                          • acedogblast
                                            by acedogblast
                                            11-02-2024, 05:13 PM
                                            How to add chip support to NeoProgrammer software for the CH341A Programmer
                                            by SMDFlea
                                            Adding chip support is quite easy,there`s even some instructions included with NeoProgrammer,although its not obvious where they are
                                            and once you do find them there`s a few crucial steps missing.
                                            Extract chiplist.zip to a folder,the instructions are in Import_EN.txt and in Import.xml .Its the xml file where we add the new chip.
                                            Open Import.xml with notepad or any other text editor.In this example i`m adding a Macronix MX77L25650F SPI_NOR chip.
                                            After adding the chip save the xml file and copy it to the root directory of the...
                                            05-26-2024, 07:15 AM
                                          • DynaxSC
                                            ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                                            by DynaxSC
                                            Hi
                                            I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                                            08-04-2025, 12:20 PM
                                          • intelg
                                            HP Elitedesk 800 G6 lost BIOS admin password
                                            by intelg
                                            Hello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
                                            Here is the hardware identification specs:
                                            HP EliteDesk 800 G6 Desktop Mini PC
                                            Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
                                            BIOS ver S21 Ver. 02.05.01 01/05/2021
                                            Born on date: 07/26/2021
                                            SN MXL11841GN
                                            SKU 3X8V9UCHABA
                                            UUID 8116E79EF6FFE94DB0B98A3188270C5C
                                            SYSTEM BOARD ID 8710
                                            SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...
                                            11-03-2023, 02:05 AM
                                          • BMCappelletti
                                            Asus Chromebox CN62 - wrong chip put on BIOS reader
                                            by BMCappelletti
                                            Long story short:
                                            - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                                            - gave the computer to his son a couple years later
                                            - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                                            - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                                            (seems like the story was not that short)
                                            He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                                            01-08-2025, 07:27 PM
