CH341a - Questions
  • katfish
    • Jul 2016
    • 76
    CH341a - Questions
    First, I saw in a video that the pin numbers printed on the adapter board are incorrect (black model w/green adapter board). And pin 5 is supposed to be pin 1. Can anyone confirm this?
    Also, any documentation on what the jumper does? Comes default on pins 1-2.
    And last ... I am working with a Winbond W25Q64FW from an HP 15-F010WM. I've managed to read the original chip ok, and saved the file. It was 8,192kb in size. But after successfully writing to a new chip, computer will not post. Put the old chip back on the mainboard, boots ok. Am I dealing with some HP nonsense ... or possibly a program limitation for the CH341?? I am using v1.29.
    I downloaded the bios update from HP to see what was in it. Extracted the exe file ... and there are 5 different BIN files in it. All are 8,963kb in size. Too large according to the CH341 software. I assume there are five different ones for 5 different models and this one download covers the 5?? Just a guess.
    Anyway ... looking for some input. Did a bit of google searching first. Didn't come up with much. I know there are a few of you here that are probably pretty familiar this device. Thanks.
  • katfish
    • Jul 2016
    • 76
    Re: CH341a - Questions
    Seems the jumper might be for different voltage choices.
    And after some more reading, I need a bios dump, not the exe from HP support. Is copying the original chip to a BIN file with the programmer, not a dump? Not new to computer repairs ... but I am new to bios related meddling like this
      • 31015
      pcb marked "YFT246837" pin wiring is correct.
      the jumper switches between programming and usb2serial adapter.
      good for hooking up to serial pins in stuff like routers.
      that more difficult.
      did you read the new chip to verify the data does match the original?
      and is it exactly the same part number?
      because if it is, they may be hiding security data in the one-time area. (read the datasheet)
      • katfish
        • Jul 2016
        • 76
        Thanks for response.
        Did verify ok after writing the BIN file. Same exact chips. It's been a long time since I've meddled in anything bios related. I seem to recall many moons ago that HP did some strange stuff with DMI I think?? But that's old stuff.
        Maybe I'm putting the adapter board on backwards then. Wasn't able to read the chip at all with pin 1 to pin 1 on the YFT board. With pin 1 on pin 5, it read ok. Or did it? LoL ... I watched a video on some discussion about it. Host claimed it was incorrect.
        Here's a pic ... should the adapter on top be rotated 180 degrees?
          • 31015
          pin1 on the adapter is printed and the pad is square.
          the socket on the programmer is used differently for 24series and 25series though.
          • katfish
            • Jul 2016
            • 76
            Shows how much I pay attention. :P Tried it the other way around ... same result. Read original ok, flash new one ok, laptop still doesn't post with the new bios on it. Post fine with the old one.
            The new chip is a donor from another HP board. That board has issues, so maybe I have something wrong with this chip. Going to dig through my pile of boards and see if I have another.
            In the meantime ... think I'll get this software registered and updated as well. Seems like it might come in handy later.
            • jostein
              • Jan 2014
              • muenchen
              Hi Katfish, could you tell me anything about the right position of the adapter board onto the CH341A mini programmer? I've got the same model but in my case the card can read bios (MX25L1005) only with adapter rotated of 180 degrees, as you said... Could you help me? And I'd like to see the discussion video you referred to... Thanks in advance for answer.
              • diif
                • Feb 2014
                • 6978
                • England
                You are correct. You need to rotate the adapter 180 degrees to the photo above.
                • sadecebel
                  • May 2017
                  • 3
                  • turkey
                  Hi, I've just bought CH341a pro black pcb from chine. I use windows 7 64 sp1 I try to load all drivers (SER or PAR ) but when I try to usb it says Device can not be recognized (code 43) I bought two and both of same error I try everything (on internet registry adjustment, usb.inf and usb.pnf copy to windows inf, restart when power off, uninstalling usb driver e.t.c... but the devices are not functional my pin assigment to 1-2 (I try other pins but nothing) can you help me ? what do I make wrong ? both of the ch341 pro are broken ? I try another laptops and desktops with different Windows (Win 7 32 bit, win xp, win 8.1 ) the all system as the same thing "Unknown device code 43" I have tried from 15 days. please help,
                  thanks,
                    • 31015
                    i know nothing about win7,
                    but if it's like xp you should be able to get a list of recognised hardware on the screen.
                    anything not recognised will have a yellow questionmark against it.
                    do you have that screen, and is the programmer showing up there?
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      stj is this the one you have too move that jumper ? there is a youtube video regarding it
                      • sadecebel
                        • May 2017
                        • 3
                        • turkey
                        thanks for answering. my jumper set 1-2 but I try both ch341A pro 2-3 jumper no jumper and e.t.c (originally jumpers are 1-2) when plug the usb my ch341a first right bottom corner USB can not recognized the device appears first then when I check the device manager there is yellow question mark in the usb section with unknown device when I check the properties on it "the device stpped because of there is a problem (Code 43) " as written (Sorry for my english I'm from turkey and not my original language). My programmer is not shown orijinal name or something like that ...
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          what drivers are you using for the programmer itself these are the ones im using on a old vista and a windows 7 laptops
                            • 31015
                            good, at this point you can tell it to update the driver from a chosen location.
                            then point it to the driver you downloaded.
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              Just wondered if you managed to get the programmer working?
                              • sadecebel
                                • May 2017
                                • 3
                                • turkey
                                I tried to uptade the driver from chosen location, windows said that this driver not used for this device and I try old device modul from device manager to install the driver therefore windows says this driver can not suitable for amd64 driver I try all version of driver and/or all versiyon program packet (until version 1.31) nothing change ...
                                • TranTrien
                                  • Mar 2017
                                  • 7
                                  Wrong connected ! Should rotated 180 degrees
                                  • akande
                                    • Dec 2017
                                    • 278
                                    • Nigeria
                                    MY PROBLEM WITH THE PROGRAMMER IS THAT AFTER WRITING BIN FILE IT SAY CHIP AND CONTENT MISMACHED , EVEN WITH THE BACKUP BIN IT SHOW MIS MATCH CAN SOMEONE HELP ME ON THIS PLS. MY EMAIL nasirakande@gmail.com
                                      • 31015
                                      read the chip, then use the verify option - do it atleast 5 times.
                                      that will tell if it's reading o.k. - if not then it's probably a bad connection to the chip or adapter.
                                        • 31015
                                        btw, happy new year
                                        • acedogblast
                                          by acedogblast
                                          11-02-2024, 05:13 PM
                                          How to add chip support to NeoProgrammer software for the CH341A Programmer
                                          by SMDFlea
                                          Adding chip support is quite easy,there`s even some instructions included with NeoProgrammer,although its not obvious where they are
                                          and once you do find them there`s a few crucial steps missing.
                                          Extract chiplist.zip to a folder,the instructions are in Import_EN.txt and in Import.xml .Its the xml file where we add the new chip.
                                          Open Import.xml with notepad or any other text editor.In this example i`m adding a Macronix MX77L25650F SPI_NOR chip.
                                          After adding the chip save the xml file and copy it to the root directory of the...
                                          05-26-2024, 07:15 AM
                                        • intelg
                                          HP Elitedesk 800 G6 lost BIOS admin password
                                          by intelg
                                          Hello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
                                          Here is the hardware identification specs:
                                          HP EliteDesk 800 G6 Desktop Mini PC
                                          Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
                                          BIOS ver S21 Ver. 02.05.01 01/05/2021
                                          Born on date: 07/26/2021
                                          SN MXL11841GN
                                          SKU 3X8V9UCHABA
                                          UUID 8116E79EF6FFE94DB0B98A3188270C5C
                                          SYSTEM BOARD ID 8710
                                          SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...
                                          11-03-2023, 02:05 AM
                                        • BMCappelletti
                                          Asus Chromebox CN62 - wrong chip put on BIOS reader
                                          by BMCappelletti
                                          Long story short:
                                          - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                                          - gave the computer to his son a couple years later
                                          - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                                          - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                                          (seems like the story was not that short)
                                          He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                                          01-08-2025, 07:27 PM
                                        • Troystain
                                          Help EZP2023+ updated chip database for w25q256jveq?
                                          by Troystain
                                          Hello, anyone here have updated ezp2023+ chip database in .dat file format.
                                          I need to add w25q256jveq chip but I do not know what data should I type.
                                          I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
                                          The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
                                          11-25-2024, 12:53 AM
