Trio oscilloscope cs1022
  • Kapetan Nemo
    replied
    Re: Trio oscilloscope cs1022
    The RAR file works fine, try downloading again and if it fails use the latest version of WinRAR.
    Thank you so much just made it happen WinRar was bad at my laptop, update it and it worked fine thank so much!!
  • Per Hansson
    replied
  • Kapetan Nemo
    replied
    the rar link does work fine ive just re downloaded the rar files i think the pdf will be too large too upload on the forum.
    I did try to download it and it did, but when I export it doesn't open it gives me this message : "rar unexpected end of archive" so thats why I asked if someone could put another .rar file again? Could you?
    His English is also weak so ill be translating the manual to him in Serbian while we work on it together...
  • vinceroger69
    replied
    im using 7 zip to unzip the files and works fine.
  • Kapetan Nemo
    replied
    Originally posted by R_J
    I will try uploading it again, its too big to upload as a pdf so I will rar it.
    Hi everyone, Im hellping a local audiophile who has a problem with his oscilloscope, Im trying to find a service manual to help him fix his scope, would you guy be so kind and upload the pdf again?? I tried with the .rar link but it could not be exported properly.
    Thanks in advance greeting from Serbia
  • vinceroger69
    replied
    Originally posted by finno12
    Thanks m8
    Just got my hands of on a CS-1022 and have tried to locate a servicemanual for it, nothing but suspect money-grabbing sites claim to have it
    I will share it too
    i still havent tested my scope as yet but have got it on my work bench now so over the next few days will see if it works doing some basics tests etc it powers on ok and has a trace etc so its a start i guess.
  • finno12
    replied
    Thanks m8
    I will share it too
  • eccerr0r
    replied
    It definitely didn't work that way debugging my 2440. Needed to see the screen and use another scope to monitor the signals at the same time. Luckily I could use the internal screen since it's not nearly as big as an arcade.
    replied
    not really, you can check the image, once you see the issue - or see nothing,
    you can check the circuits without having to view the output.
  • eccerr0r
    replied
    Cool. I thought most people used mirrors so they could see the screen, but I guess this works too :o
    I guess you have a need for more than one scope then, eh? One for the display, second for tracing signals!
    replied
    the idea is you can test a pcb without a fucking huge 26" crt in an open frame sitting on the floor to see the output!
  • eccerr0r
    replied
    Ah, thought you were doing so just for fun (I thought fixing the CRT to work was the plan, then again having it show up on the scope helps determine which side is broken), as displaying a raster image on an XYZ scope is really of limited use
    Though maybe someday I'd still like to make my 2465 show a raster image for the heck of it
    replied
    i use x-y mode, i fix vector arcade pcb's
    starwars looks impressive.
  • eccerr0r
    replied
    Well the trick is, it needs to be processed in software on the digital scopes (including "digital phosphor" (I hate that term)) - if not, no chance, but at least this kind of stuff is theoretically possible. Indeed it will make a trade off of screen refresh rate and CPU/resource utilization. The screen update circuitry gets the shaft over the trigger and capture circuitry.
    My 2440 DSO XY mode plots dots, which is OK for lissajous figures, but not OK for vector graphics. I doubt it does XY mode at full sample bandwidth either - probably a small fraction as a gimmick.
    Anyone actually use XY mode anymore? I've always thought of this as a hack to get around the limitations of a single channel analog scope without needing to implement a second channel as this was kind of expensive to do (dual gun CRT) before fast transistors/ICs became available.
    replied
    the problem with using a digital scope as a monitor, is even if the capture rate is 5GHz most have relativly slow screen refresh rates.
    also, persistance of vision / time-lumenance tricks wont work on most of them.
  • eccerr0r
    replied
    Well, don't get too excited. Only analog scopes that have XY mode can be used as a vector monitor, and ones with XYZ input can be made into a raster monitor. Then again I'd be surprised if digital scopes could not have software to display NTSC directly...
    I know my old 20MHz scope can not do XY mode and thus cannot do vectors or lissajous figures. My 300MHz scopes do have XY mode, and my analog 300MHz scope can do full XYZ and thus with some external circuitry, display raster images. Note when I say Z, this is brightness, not third dimension; however yes it is a third dimension to a scope.
    The XY mode on my 300MHz DSO is crappy at best. I doubt it can do vector graphics justice, but you can do lissajous figures. However I don't have it calibrated perfectly yet so even with X=Y I get an oval indicating a phase error. In any case, using lissajous figures on DSOs have mostly been deprecated as the signal processors can mostly get information gained by lissajous figures by direct computation.
    My old vacuum tube (amplfiers, not just the CRT) Eico scope that's at my parents' place, has XY mode and is also single trace. Dang these mini dual trace scopes! Alas it doesn't even have a triggering mechanism...
    That being said, I think the CS1022 does have XY mode, or at least the CS1021 has XY mode according to Wikipedia
    replied
    you can use an analog scope as a vector-monitor to test old arcade stuff like "asteroids"
  • eccerr0r
    replied
    Depending on what you're doing, having a DSO may or may not matter.
    At first I had a old 20MHz analog scope, which is probably very similar in capability to your CS1022. I used it to repair a more advanced 300MHz analog scope with digital control. I subsequently got a broken 300MHz digital storage oscilloscope and used the newly fixed 300MHz analog scope to fix it, though the old 20MHz analog would have done just fine too.
    Still surprising what you can do with old analog scopes, a lot of the time it's just thinking about what experiments you can do to work around limitations.
  • vinceroger69
    replied
    Originally posted by eccerr0r
    Watch out, this scope that he is demonstrating with is a Digital Storage Oscilloscope (looks like he mentions it at the end), but your CS1022 is not a DSO. The behavior will be different: a non DSO can't hold or "store" things on the screen so if your time/division sweep speed is less than several ~50 ms/division (so it takes ~500ms to sweep across the screen), you'll see a dot sweeping across the screen instead of seeing a line. This is normal for "analog" or non storage oscilloscopes. At 50ms/div you'll see significant "flicker" but should be able to see the waveform.
    DSOs are computerized scopes.
    There's also some old analog storage oscilloscopes but I've never actually used one. I'm curious how they actually work.
    Thanks again i have not watched the video untill the end as yet but thanks for your help.
  • eccerr0r
    replied
    cheers stj im just reading the manual again too so i know what switches etc goes where and just found this video that looks quite good too and explaines using a scope thats easy too understand for a begineer like me.
    https://www.youtube.com/watch?v=6WFl...st=WL&index=64
  • repair-it
    Need advice testing a samsung power supply board with scope
    by repair-it
    I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
    07-12-2025, 11:00 AM
  • Tarot Superstars
    How not to Damage an Oscilloscope
    by Tarot Superstars
    Hello.
    I have jut got my first analogue oscilloscope. An Isotech 620 20MHz.
    I want to learn how not to damage it, and I found instructions on the internet obscure.
    They talk about ground, earth, floating ground, this, that....
    But they don't actually say anything anything useful so far.
    I want to know:
    Don't connect exactly this to exactly there or it blows up.
    For example, I am tracing a signal from a function generator in an audio amp, or testing for voltages in different parts of a circuit.
    I want to know what not to connect...
    08-29-2023, 02:27 PM
  • AureliaKitsune
    Request for Boardview – RX 6900 XT MSI GAMING Z TRIO
    by AureliaKitsune
    Subject: Request for Boardview – RX 6900 XT MSI GAMING Z TRIO
    I am looking to repair my MSI RX 6900 XT GAMING Z TRIO graphics card and need the boardview to perform an accurate diagnosis.
    Would it be possible to provide it to me or let me know where I could obtain it?
    Thank you in advance for your help.
    Best regards,
    Aurelia...
    02-06-2025, 02:21 PM
  • Evets
    Dynamco analogue oscilloscope
    by Evets
    I have recently acquired a Dynamco D7100 analogue oscilloscope without a user manual. As this is the first time I have owned or used an oscilloscope I would like to try and find an instruction book. The manufacturers no longer hold any information and a Google search only found one site but when I downloaded a 'service manual' all I got was gobbledegook. Any help would be gratefully appreciated or even pointers to a generic manual where I could learn more.
    08-30-2024, 06:54 AM
  • SolomonMan
    Vintage BK Precision 1403 Oscilloscope....
    by SolomonMan
    All,
    Some of you have helped me in the past and I am very appreciative of all the help! (I have fixed TVs/Stereos/ and other small appliances with your efforts...Thanks so much!!!
    Today I went to a local HAM Radio Festival. It was one of the smaller ones in our area. My stepfather is the HAM operator. I tinker in electronics but am a Software Programmer (27 years now).
    I was looking for a few odds and ends for some electronics work I have to do for the household/farm. Typically these type of shows have the grab bags or a electronics vendor...
    12-03-2023, 10:39 PM
