Rework Station Pump - Can They Be Repaired ?
    • 31068
    Re: Rework Station Pump - Can They Be Repaired ?
    if the diaphram is suposed to be on the polepiece, when it pushes it should cover the 4 outer holes, and when it pulls it should expose them.
    • xelectech
      retired tech
      • Nov 2014
      • 238
      Okay, that makes sense, kind of similar to reed valves in operation - but it seems like it would always be sucking then, unless it's ported something like a 2-cycle diesel engine.
        • 31068
        good point - we need much closer foto's of the pole ends and diaphrams.
        • xelectech
          retired tech
          • Nov 2014
          • 238
          I concur - also would like to see where the heat-wand sources its air from (or plugs into or whatever) 8^)
          • mmartell
            • Oct 2013
            • 3189
            I will try to take some better pictures guys I know the ones I already posted are not the best.
            The holes in the diaphragms are just positioning holes. They fit into the four prongs on either end of the piston maybe to keep the piston from torquing so it stays true between the electromagnets.
            • mmartell
              • Oct 2013
              • 3189
              Here's two pictures I pulled from the net of the same unit with it partially disassembled.
                • 31068
                sooo.... how many air couplings are on it?
                i see one on each diaphram cover - is it one in and one out?
                • mmartell
                  • Oct 2013
                  • 3189
                  The two lines from the diaphragm covers go into some sort of equalization chamber which has a single line out feeding the wand. So one line in, one line out.
                  • xelectech
                    retired tech
                    • Nov 2014
                    • 238
                    If it's ok to cover those holes then maybe you could add a rubber washer, to stiffen the diaphragm - maybe even 'super-goop' it to the top, being careful that it's concentric and
                    any glue layers are even, all depending on if there's room for the additional material in the manifolds - could just be a very tempoary repair, but might be worth the trouble, probably easier than finding new diaphragms.
                    I bet there's a reed valve in those manifolds 8^)
                    • mmartell
                      • Oct 2013
                      • 3189
                      Two more pics and a new theory.
                      The first pic is the unit right side up. One hose goes in the top into the main chamber while the other end is just left hanging inside the case. Maybe just to keep the main chamber itself from pressurizing. Each diaphragm goes into the rear chamber (purpose ??) and one hose leaves that chamber and goes to a plastic tank. The outlet of that tank feeds the hot air wand.
                      The second pic shows the valves on the inside of the diaphragm cover.
                      Do you think the piston should contain two permanent magnets or some non-magnetized steel ? If there was no attraction then the piston would sit properly until the coils were energized.
                        • 31068
                        it's what i originally said about the 4 holes by the look of it.
                        the air enters the center around the coil, gets pushed through the end pieces and combined before going into the white box that is probably a filter or expansion chamber.
                        • xelectech
                          retired tech
                          • Nov 2014
                          • 238
                          or depressurizing...
                          just a guess, to provide higher volume resevoir...
                          Dam, no reed valves...
                          I think it should have magnets, with no current thru the coils the attraction should be about the same in either direction; but, if it works ok with just metal pieces then I guess the designer saved the mfg. a few pennies. I'm curious as to how many cfm that pump is good for. Also, can you tell whether it uses line freq. or its own generated AC to run the motor? If there's a way to vary the airflow, maybe it has a miniture variable frequency drive on that control board, hmm...
                          • mmartell
                            • Oct 2013
                            • 3189
                            No. The four holes are locators that fit into matching tits on either end of the piston, presumably to enforce proper orientation.
                            • mmartell
                              • Oct 2013
                              • 3189
                              They are definitely magnets on the piston was just wondering aloud if they became magnetized when they shouldn't be.
                              The coils are fed voltage controlled a/c, maybe you can gleen more from the pic of the control board I don't know enough about that. I measure 77v at lowest speed and 110v on high so that much seems to be working right even though the piston was essentially stuck in place and not moving.
                              What the hell could be wrong with this thing ?
                                • 31068
                                so it's what i said,
                                when the pole pulls inward, the diaphram will flex away from the pole and allow air to leak through those holes - a bit.
                                and when the pole moves outwards it will press against the holes and seal them.
                                at this point, if the housing is not cracked, start looking at how the coils are driven - incase it's a current issue not moving the pole far enough.
                                  • 31068
                                  if you assemble it without the diaphram on one end and with the end section missing - can you move the pole or is it sticking?
                                  • mmartell
                                    • Oct 2013
                                    • 3189
                                    Pic 3 and 4 show what looks like a "button" that fits over the assembly before the nut gets tied down so that part of the assembly is sealed, as it is around the perimeter when the diaphragm is fully installed.
                                    There is too much play - the magnetic forces are too strong and overcome whatever should be keeping the piston centered in the coil assembly. Need to find a way to simulate keeping the piston centered to see if it will oscillate properly under test conditions.
                                    • xelectech
                                      retired tech
                                      • Nov 2014
                                      • 238
                                      can you measure the frequency that the different voltages are at also?
                                      As far as what's wrong, I thought you said that the spindle was getting stuck to the poles, I've been going on that assumption - Or do you mean, why are they doing that?
                                      • mmartell
                                        • Oct 2013
                                        • 3189
                                        Your assumption was based on my assumption lol. I was thinking that the diaphragms may be designed to support the piston in place (beside their obvious function) in which case they have failed. Need to design a test to float the piston and see if it functions properly.
                                        • xelectech
                                          retired tech
                                          • Nov 2014
                                          • 238
                                          Since looking at the newer pics I can't agree with that possibility anymore, having seen those manifolds. Before those pics, it seemed debatable whether the work was being done inside the inner chamber or outside it; I do still think it's possible that the diaphragm is supposed to be secured somehow to the ends of the spindle so its lateral movement is more limited (not to say that that makes it true &^).
                                          I'm wondering now about the noise it made when it failed, did it make a big noise and then quit, or did it start making a noise and then you turned it off because of it?
                                          • shahnld
                                            wds-580 rework station issue
                                            by shahnld
                                            Good day.
                                            i received used bga rework station wds-580 which was not going above 300c despite the parameter was set to 350c, Everytime beeps at 300c so i did a factory reset and by mistake washed data and log etc. now the station boots to a white screen.
                                            Does anyone has a firmware for this station and want to share with me. i will really appreciate any help possible..
                                            kind regards...
                                            03-28-2024, 01:14 PM
                                          • minimania
                                            Need Schematic for jbc am6800 rework station
                                            by minimania
                                            hi all im looking for a Schematic for jbc am6800 rework station
                                            mine has stopped working fully
                                            it started with turning off when switched on then after a few off and ons it worked sort of for awhile
                                            now it wont turn on at all...
                                            01-28-2025, 03:44 PM
                                          • shahnld
                                            Seamark ZM-R6200 Rework station
                                            by shahnld
                                            Good day Experts.
                                            I have recently aquired a rework station SEAMARK ZM-R6800,. Is there anyone using this or some other similar station and give me some info about profile temp curve etc for removing leadfree soldered gpu chip..? just 1 profile will be enough to get started.
                                            Kind regards
                                            01-24-2024, 10:55 AM
                                          • petemanuk
                                            Help with IR6500 rework station
                                            by petemanuk
                                            I been playing with a recently acquired IR6500 rework station and watching lots of YouTube tutorials to see how to use it with not much success. I’ve only recently joined badcaps but going through the forums there is a lot of knowledge here, so though it best is if I ask my question here.
                                            1. Firstly is the IR6500 any good for BGA rework or should I be spending my money on a better one.
                                            2. The instruction manual is pretty useless on explaining how to set the PID loops (no information at all!!) both top and bottom heater for th Kp, Ki and Kd...
                                            10-14-2022, 12:31 AM
                                            ZD desoldering station pump rebuild
                                            by stj
                                            just did one.
                                            works great.
                                            so here's the discoveries.
                                            the pump "modules" have 4 parts, the main body, the outside bit, the inside bit - screwed to the main body, and the diaphram.
                                            the failure is the inside bit, it has a rubber coating for some reason that becomes tacky and breaks down - contaminating the diaphram.
                                            so you need to clean everything to get rid of all the tacky black stuff.
                                            then reassemble it.
                                            *BUT*
                                            you must put the 2 screws into the assembly only finger-tight.
                                            if you tighten it properly the valves dont work....
                                            08-21-2024, 05:59 PM
