Atmel168A-PU-based ESR meter - using on a PSU
  • xelectech
    retired tech
    • Nov 2014
    • 238
    I finally got caught up on my reading and have really been enjoying my new tool. Occasionally though I get unexpected results, especially while I was trying to locate defective components in an Antec psu.
    Twice I was on the backside of the ckt. bd. on the component leads and got a real low (like, say, 57pf) reading but after taking the cap out and measuring again the part reads ok.
    This occurred on a 22uf one and a 220uf one.
    Lots of OST in the box, and tan glue here and there, so far on the bigger caps I've checked
    I get what seems like reasonable readings for several caps in parallel. There's a copyright date of 2006 on the psu so I suppose it ought to be fully recapped but I don't know if I'm up to it. looks like it'll take forever...
    Anyway, what a pain to work on a crammed-full box like this, anyone have any tips?
    • 31246
    Re: Atmel168A-PU-based ESR meter - using on a PSU
    the reason you cant reliably do in-circuit testing is because other parts like diodes and chips have a capacitance!
    this effects all esr meters - the problem is many have been sold on lies!
    • xelectech
      retired tech
      • Nov 2014
      • 238
      Oh, okay, so it's pretty normal to have to pull some items, shoot 8^(
        12-31-2023, 06:04 AM
      • jorpec
        by jorpec
        Hi
        Thnaks
        01-23-2023, 10:37 AM
      • chth96
        by chth96
        03-09-2024, 10:03 PM
      • SuperAman
        PS5 HDMI port diode reading?
        by SuperAman
        I did an hdmi port repair for a PS5 and I lost the small diode z71 SOD923 on the back of the port. I did a trace repair for pin 19 of the port as well. Without the diode I get no display at all. I tried replacing the diode twice but after I get flux on it the marking comes off so I can't tell if I have it on the right orientation. When I measure I get a reading of 1(open) and 923 in diode mode. Is 923 a normal reading for these and also which side should the reading be with regards to the arrow on the board?...
        02-03-2024, 10:16 PM
      • Stephan Mathers
        EDMI ATLAS MK10 Electronic Meter Discussion
        by Stephan Mathers
        Greetings, new guy here but always interested in the crazy universe of modding
        We just finished construction of around 25 vacation houses, all inside the same private area.
        Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
        The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
        Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...
        05-20-2025, 09:09 AM
