Xytronics LF-852DII or just the LF-852?
  • Stefan Payne
    • 1267
    Im thinking about buying a decent hot air station.
    The Xytronics LF-852D(II) are pretty cheap and don't look too bad.
    The difference between the two seems to be 50€ and 400W.
    Is it worth getting the II instead of the older 852??
  • Stefan Payne
    • 1267
    Re: Xytronics LF-852DII or just the LF-852?
    Hm, what do I want to do with that?
    I'm not really sure...
    I plan to use it for PSU disassembly but maybe some other stuff as well (desoldering BGA stuff from old broken boards to make key chains) or something like that.
    And I'm not sure if the II is worth the extra money or not.
      • 30979
      just get a cheap chinese 30Euro job from ebay.
      • Stefan Payne
        • 1267
        Well, I don't (want to) buy cheap.
        I want to buy some quality that lasts a lifetime.
        That's why I have a Makita HR2450 drillthing lying around here
        • LP_tekh
          • Oct 2015
          • 95
          • Laos
          I'm using Atten at858d+ for four years now. I replaced the heater last month, working like new again.
          http://www.aliexpress.com/item/High-...rchweb201560_5
          • Stefan Payne
            • 1267
            I'm from Germany, there isn't that big a choice...
            The only thing that makes sense (price wise) is a ZD-939 for 84,95€. (Reichelt)
            A TOOLCRAFT AT850D for 179,90 (Conrad) doesn't make any sense over the LF-852D for 189,95€.
            The 852DII would be 239,95€
            (both Xytronics are also Reichelt.de).
            ELV.de also just seem to have rebadged Xytronics things.
            But I'd like to order @ Reichelt because they are way cheaper with the Panasonic caps than Conrad...
            That leaves Amazon.
            But still, I'd like to get something remotely decent and don't want to save that much money on this toy
            Though I could buy other things, but I don't want to ^_^
            • Stefan Payne
              • 1267
              I ordered the 852D today.
              I think the 852DII would be a waste of money.
              I ordered a couple of capacitors and other things instead of the 50€ for the 852DII
              • Stefan Payne
                • 1267
                Was delivered today before noon.
                It comes with 5 pairs of tweezers.
                An adittional heating element. And some other stuff.
                And I already tested it
                First:
                The clunky power switch seems like it disconnects the power. But it does not
                Its more like a 'soft power switch'. If you power it of, the thing isn't off!
                Well, the heating element is but the pump is not, don't know if it is on a timer or not, but there is some kind of delayed turnoff implemented.
                It also comes with 4 nozzles:
                one small round one.
                one bigger round one.
                and two for smaller QFN package chips...
                The Heatingelement is (of course) in the handpiece.
                The air comes out of the main unit...
                And here is what I don't particularly like:
                'only' one tube goes from the main unit to the handpiece.
                Inside this tube is a cable for the heating element...
                Why don't just make a double cable like they did with the DIA100 desoldering tool?
                Then you don't have something inside the tube blocking the airflow...
                On the other hand, you can not burn the cable that easily...
                  • 30979
                  the delayed shutdown is like a nuclear power plant, you need to keep the cooling for a while to prevent a meltdown!
                  as for the pipe with wires in it and the pump in the base - that's why i tell people to buy the newer chinese units with a fan in the handle!
                  • madyoyo
                    Samsung QE55Q65B with shorted D001 diodes on panel board: Worth saving or not
                    by madyoyo
                    Hi
                    I have a Samsung QE55Q65B with a seemingly common problem: it turn off and back on after a few seconds, (sometimes more, and in rare instances works for hours). D001 on the left side of the panel is very hot. I may be able to remove it with a very fine iron, but i don't have the equipment to re-solder such small parts.
                    Is there a risk to run the tv without this diodes diodes? And is it worth to pay someone else to replace it. I read many people who ended up with bad lines after trying to remove/replace them, , or the panel failing in another way, so i want to weight...
                    12-01-2023, 09:28 AM
                  • cashkennedy
                    Onn tablet screen
                    by cashkennedy
                    An ebay seller shipped me this broken tablet by mistake, and so I got my money back, but there are a decent amount of these seemingly in perfect shape but with screen issues (this tablet was clearly a return that had never been used or setup, so I don't think any physical damage occurred, also is a kids model so large bumpers on cover that isn't in picture) Is this a loose lvds cable or anything repairable beyond replacing the screen which would come with its own integrated tcon which is maybe where the problem would be?
                    The power on screens just exhibit the sideways smear, once...
                    07-14-2025, 06:12 PM
                  • Cartel
                    FORD 1996 ECU RECAP: Aluminum - Polymer worth bothering?
                    by Cartel
                    I will be pulling my crown vic ECU and recapping it. 3 in total, 47uf 16v x2 and a 10uf 63v
                    I hope they havent puked yet. I was thinking of replacing them with Aluminum - Polymer thru hole caps. probably 47uf 25v and 10uf 80v
                    They arent cheap. Anyone have any experience with them? Am I wasing my money on premium caps?
                    Nichicon PLV series
                    thanks
                    06-01-2025, 04:58 AM
                  • Hondaman
                    Windows 11 buying advice needed
                    by Hondaman
                    My mother may soon need to upgrade from Win7 (to continue safe browsing, e-mail, and office tasks, without a printer). Right now, she uses an Intel Core2Quad 9550 CPU (not sure of motherboard). Video is either the Radeon 6670 or 6770, completely air-cooled, with fins like a motorcycle engine (I think I pointed a 120mm fan at it). PSU is probably Seasonic, still running after 14 years (I choose quality). I am not sure of the RAM, or the PCI-e wifi chip. Probably 8 GB or 16 GB. Perfect for WIndows 7.
                    She does not want to switch to Linux. And she does not want to use a laptop because...
                    04-14-2025, 11:35 PM
                  • Francesc V.
                    Coil replacement - is it worth it?
                    by Francesc V.
                    Hi:
                    I am trying to repair this ATX SMPS and I realised once I've replaced the 5V IC that also the coil is gone.
                    Where (and how) do you look for these parts? same piece or similar that I could try to use it? is it worth it? :-)
                    Regards,
                    Francesc....
                    04-07-2023, 12:52 AM
