Chinese soldering iron?
  • Yamashiro
    • Sep 2015
    • 19
    • Israel
    I bought a cheap Chinese soldering iron for a few bucks it still works but the tip got ruined and I find it difficult to find different tips that will fit it.
    It was also weak and I had to wait too long for it to heat up.
    Now I want to buy a better quality one that has many tips that are cheap and easy to find, I saw this one which use 900M tips.
    What do you guys think about it?
    Did anyone try a more expensive Chinese soldering iron before?
    I don't want to spend more than that, I just need to do very little soldering with a small Arduino project and fixing caps on my monitor, so there's no point in buying a $100 soldering station.
    • 31198
    Re: Chinese soldering iron?
    leave it,
    get one that uses T12 or T15 tips.
    • Yamashiro
      • Sep 2015
      • 19
      • Israel
      I don't think there's a soldering iron that use them that isn't a part of a station and that cost around $30, all I can find are Hakko soldering stations and they aren't cheap.
      Those tips are kind of expensive too, one costs at least $5.
        • 31198
        that's because the tip is combined with the element for high speed heating (seconds) and fast reaction times.
        if you have a 24v transformer / psu you can get a cheap kit.
        http://www.ebay.co.uk/itm/181846168899
        cheap tips.
        http://www.ebay.co.uk/itm/390685073859
        • Yamashiro
          • Sep 2015
          • 19
          • Israel
          Unfortunately, I don't have this kind of transformer.
          Combining the tip and heating element is cool.
          Why do you think the Chinese one I linked is bad?
          • dj_ricoh
            • 2073
            YES! But there is a catch!
            You won`t really appreciate a soldering station until you get that chines crap and struggle with it.
            Even that crap station from 1st pic is much better but for me that is way far behind me.
            the second and third that makes me do stuff FAST!
            the wd1 its a dream and the ec2100 shows that i know what i`m doing.
            If you will work with this station you need to learn and earn that station because it will make you look good , you will make progress and on top of that you will be focus on your project not that silly iron how to maintain it.
            You will make mistakes on clients products if you don`t invest in a good station.
            I been in your path and believe me its no sunshine there.
            this one i show you its at home that feeds my fraking hobby.
            at work i got other 2 wd1`s( i love them ).
            • dj_ricoh
              • 2073
              when swap a KBC controller, i solder 4 pins then i fill all the pins with solder and swipe and it comes off.
              it takes like 5-7 min to change it and i check it with the microscope but 99% its always good.
              The tip!
                • 31198
                the man does not have the money for a weller unit.
                to answer the question, the 900 series tips dont transfer the heat from the element well.
                they never did even when they were from hakko before the chinese cloned them.
                the kit i linked could be driven from a 19v laptop charger.
                • Yamashiro
                  • Sep 2015
                  • 19
                  • Israel
                  @dj_ricoh I'm just a part time hobbyist, no clients or anything, I just need to solder a few wires and components and a little desoldering and that's it so there's no point in investing in it.
                  @stj, I'm a little afraid of wiring things with higher voltages than 5V, I'm not an electrician and those voltages can really hurt or cause fire.
                  I already take good precautions against fire, but I don't think I know enough to be certain I won't be electrocuted.
                  I assume it needs at least 3A?
                  One of those could work?
                  http://www.ebay.com/itm/Universal-AC...item3f52ea8f55
                  http://www.ebay.com/itm/New-3-42A-19...3D271974043477
                    • 31198
                    those would work, anything over 3a is good.
                    as for shocks, you wont be harmed by 24v, it's the same voltage used in large vans and trucks,
                    • rievax_60
                      • May 2012
                      • 897
                      • australia
                      I have been using a Hakko 936a clone station for many years. The main advice I have is to get the 936a, the "a" usually means that it has the better Japan made heater element which is has higher wattage and is more reliable.
                      The plastic nut that attaches the barrel to the handle can be fragile on some. Be sure to get a K tip for the big jobs.
                      • Yamashiro
                        • Sep 2015
                        • 19
                        • Israel
                        The shipping on those stations makes them very expensive
                        @stj, I understand that using a laptop PSU can work in theory but do you know of anyone that tried it before? Is there an online guide maybe?
                          • 31198
                          ask the ebay seller for the instructions.
                          the psu supplies power to that controller board, the board then sends controlled pulses to the iron to vary the temperature.
                          all very simple really.
                          • ahendricks18
                            • Oct 2015
                            • 16
                            I'd like a nice soldering station, but I still have a cheap soldering iron from 3M. Bought it at walmart a few years ago when our local one still sold electrical stuff. It works great but it needs a new tip. I was wondering if this one would be decent for my purposes?http://www.radioshack.com/soldering-...n/6402184.html.
                              • 31198
                              oh hell no - fucking NO!
                              i had one of those scam-irons.
                              they are just a mains iron connected through a lamp dimmer!!
                              your in the u.s.
                              so maybe a T12 clone from here:
                              http://www.circuitspecialists.com/so...-bk3000lf.html
                              otherwise, a china clone.
                              • corrize
                                Quality solder iron tips and Kapton ?
                                by corrize
                                Hello, I have a solder iron pen (50w) with tips « 900m » (hollows ones, standard). I'm searching to replace mines because it's impossible to tin, they remain black and impossible to unsolder a mini SMD capacitor with. Bad ones.
                                I'm looking to replace the iron tips but, on Amazon, Ebay… all no names, the sames. Sold by 10, 15 or more at low price and « pro » websites only one Hakko tips sold 20 dollars. I'm lost.
                                Do you have brand of qually tips pls ?
                                Same question for Kapton (for my other hot air iron), do you have brand or good place to buy, the true...
                                05-24-2021, 11:35 PM
                              • tony359
                                Kaiweets USB soldering iron
                                by tony359
                                I am testing a USB powered soldering iron. It's made by Kaiweets but I believe it's also sold under other names.
                                As a standard test, I checked whether there was any voltage leak from the tip - that said the thing runs on USB-C power delivery so am I correct that the whole unit is floating and not grounded? If I check, I measure 90V at the tip but I have a feeling that that is not relevant? Maybe caused by that capacitor between primary and secondary inside the PSU? I do not see current flowing at all.
                                In other words, do you think it's expected and...
                                02-06-2024, 12:51 PM
                              • SarcasticOP
                                Seeking Guidance on Motherboard Diagnostics
                                by SarcasticOP
                                Hello everyone!
                                I hope this is the correct place to post this, if not please let me know and I will post in the appropriate location.
                                I'm venturing into the intricate world of board repair within electronics, and I'm reaching out to this community for some guidance and shared wisdom. I have tried to do some research myself and find this information on my own, but I don't know what I don't know, and that is really starting to become an insurmountable issue that I cannot overcome. The only person I had nearby that I could turn to passed away recently so I do not have anyone...
                                01-10-2024, 03:35 PM
                              • acedogblast
                                by acedogblast
                                11-02-2024, 05:13 PM
                                Acer Chromebook Acer Chromebook Spin 713 CP713-3W - (Intel Core i3-1115G4, 8GB, 256GB SSD, 13.5 inch QHD 3:2 Touchscreen Display, Google Chrome OS, Iron) Chromebook Spin 713 Specification for Upgrade or Repair
                                This specification for the Acer Chromebook Acer Chromebook Spin 713 CP713-3W - (Intel Core i3-1115G4, 8GB, 256GB SSD, 13.5 inch QHD 3:2 Touchscreen Display, Google Chrome OS, Iron) Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Chromebook Spin 713 CP713-3W - (Intel Core i3-1115G4, 8GB, 256GB SSD, 13.5 inch QHD 3:2 Touchscreen Display, Google Chrome OS, Iron) boardview and Acer Chromebook Spin 713 CP713-3W - (Intel Core i3-1115G4, 8GB, 256GB SSD, 13.5 inch QHD 3:2 Touchscreen...
                                09-07-2024, 03:10 AM
