Desoldering station vacuum pump. Looking for recommendations.
  • Agent24
    I see dead caps
    • Oct 2007
    • 4960
    • New Zealand
    Re: Desoldering station vacuum pump. Looking for recommendations.
    The gun looks the same as the one for the ZD985, if it is, then all things being equal, they are probably much the same.
    -David VanHorn
    • clearchris
      • Dec 2013
      • 687
      I did a write up on here about that unit. Still happy with the unit. I cant imagine going back to a plunger type solder sucker.
      • popeye
        • May 2011
        • 155
        I would recomend adding leaded solder to the joints you want to clear before desoldering keep the tips clear and you will not have them clogging so much.
          • 31051
          adding solder is what fluxes up the desoldering tip.
          • Agent24
            I see dead caps
            • Oct 2007
            • 4960
            • New Zealand
            True, but lead-free solder or 63/37 stuff does like to clog the nozzle better than 60/40 too. I can add fresh solder and run 60/40 through my Den-on all day and only stop to clean out the flux residue and the waste solder pipe.
            When I start working on lead-free or that 63/37 stuff I have to crank up the heat and even then I sometimes have to pull lumps of solder out of the back end of the nozzle. (Which to be fair, is about 80mm long)
            -David VanHorn
            • jeffescortlx
              • May 2011
              • 40
              #26
              Just an update: But I did get the Hakko FR300 a few days ago, and I did get a chance to use it a few times. So far so good.
              Feels nice. It does have a heat light, but wish it had a power light on the back side so it could easily be seen. If it came with different size tips and had a real stand that was included it would be a winner for sure.
                • 31051
                80mm ????
                what the hell is it?
                most desoldering units the tip&heater are no more than about 50
                • keeney123
                  Lauren
                  • Sep 2014
                  • 2536
                  That is like 3 1/8" long for those of you not on metric scale. I agree stj that is huge.
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 4960
                    • New Zealand
                    #29
                    Mine is a Den-On SC-5000. It's an earlier version (I think from the 80s/90s) of the currently produced SC-7000Z: http://www.denondic.co.jp/en/doc_sc7000z.php.
                    Actually the tips are just over 90mm long.
                    They sell the new model at http://www.howardelectronics.com/den-on/sc7000.html if anyone's interested. I expect the new one would work much better for lead-free solder. Mine does work very well on 60/40 which I expect is all it was designed for.
                    -David VanHorn
                    • jeffescortlx
                      • May 2011
                      • 40
                      #30
                      It has a switch to reverse the pump for hot air rework. That's pretty neat!
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 4960
                        • New Zealand
                        #31
                        It's a clever idea, although I've never actually used it since I already have a hot air station anyway so I can't say how well it functions for that.
                        -David VanHorn
                          • 31051
                          probably not good, it does not regulate the air temp, only the tip temp.
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 4960
                            • New Zealand
                            #33
                            That's where the really long length comes into play!
                            -David VanHorn
                            • jeffescortlx
                              • May 2011
                              • 40
                              #34
                              Well 8 days after receiving the hakko FR300 I noticed the clear plastic canister that catches the solder is full of cracks.
                              Hasn't been dropped or handled rough. Buy a Hakko they said.
                              • redwire
                                • 3910
                                jeffescortlx, don't make me cry
                                I'm not sure if the filter-pipe cracking is from physical stress (the spring, not put in right) or is from heat or it's just cheap plastic. I would email Hakko California, they answer quickly.
                                So far, I find all their stuff good except for the chinese knockoffs.
                                  • 31051
                                  hot solder on cold glass - what temp are you running at?
                                  • jeffescortlx
                                    • May 2011
                                    • 40
                                    #37
                                    It's not glass, it's plastic.
                                    I work with pretty small leads, I only need the #2 setting. I believe it goes up to 5 or 6.
                                    I contacted the seller and he is going to replace the canister.
                                    • popeye
                                      • May 2011
                                      • 155
                                      #38
                                      That looks like poor quality to me I have had a phillips model for getting on for 20 years just managed to crack it don't know why no spares for it now will have to buy a gun for one of the others that spares are available for just need to make sure about the wireing.
                                        • 31051
                                        it needs to be glass,
                                        and what the hell is #2 setting? you need to know the exact temperature your using!
                                        • Agent24
                                          I see dead caps
                                          • Oct 2007
                                          • 4960
                                          • New Zealand
                                          #40
                                          Some Hakko (and other) tools don't have a temperature dial, just marked 1-10 or such.
                                          Why do you need to know the exact temperature? It's not going to be that precise anyway... tip temperature is measured in the tip or heater, while the work will always be cooler. Just use the lowest temperature which works effectively.
                                          -David VanHorn
                                            ZD-915 vacuum pump motor mount service alert
                                            by sam_sam_sam
                                            If you have this Desoldering Gun Station there is something you should be aware of the two screws that hold the motor to mounting for pump can come loose and make raddling noise
                                            One note this unit has been repaired already once because of switching power supply regulator ic chip failure
                                            Now this with the vacuum motor mounting issue yes I give this Desoldering station a very hard work out and use about every weekend to do some type of project
                                            The fix is taking the vacuum pump assembly out and take the metal cover off and you will see the two screws on it
                                            09-19-2021, 02:15 AM
                                            ZD desoldering station pump rebuild
                                            by stj
                                            just did one.
                                            works great.
                                            so here's the discoveries.
                                            the pump "modules" have 4 parts, the main body, the outside bit, the inside bit - screwed to the main body, and the diaphram.
                                            the failure is the inside bit, it has a rubber coating for some reason that becomes tacky and breaks down - contaminating the diaphram.
                                            so you need to clean everything to get rid of all the tacky black stuff.
                                            then reassemble it.
                                            *BUT*
                                            you must put the 2 screws into the assembly only finger-tight.
                                            if you tighten it properly the valves dont work....
                                            08-21-2024, 05:59 PM
                                          • flat-earther
                                            Hoover FM216LI cordless vacuum refuses to charge
                                            by flat-earther
                                            I have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
                                            I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
                                            5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
                                            So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries....
                                            06-06-2025, 03:14 AM
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
                                          • hans_meier
                                            HP EliteBook 840 G6 how to dump without desoldering
                                            by hans_meier
                                            I have an "HP EliteBook 840 G6" and would like to know how to dump the BIOS flash chip without desoldering. Putting 3.3V on VCC of the BIOS chip with a programmer does not work (seems to enable the PCH). I have read some general notes about connecting the CPU reset to ground or to bypass oscillators. There does not seem to be a reset line for Intel i5-8365U. Just RSMRST, but it's only accessible on the other side of the mainboard. Is there an easy way to dump the flash without desoldering and without removing the mainboard? Does anyone have experience with this? Maybe...
                                            01-04-2025, 04:11 PM
