A good PIC programmer.
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    I wanted to start playing with PICs a little bit. Just a little right now though. But I was wondering, what's the best programmer to get? I've heard the PicKit3 is a cheaper buy but it's a bit slower when it comes to in-circuit debugging. I heard ICD 3 is fast but around 200$. Does anyone have any suggestions? Is it worth spending the extra cash and getting the nicer one?
    E-Bay sells some ICD 3's for about half the price, claiming they're new, but they appear to be a different colour. I'm questioning whether they're counterfeit or not. I believe the company that makes the ICD 3's have some rule where they'll replace it if it breaks, even if it's because of something the user did...I highly doubt they'd cover counterfeit products...
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
    • 31091
    Re: A good PIC programmer.
    pickit3 is the way to go.
    this clone even comes with an adapter!
    http://www.ebay.com/itm/261644304088
    • Spork Schivago
      • Mar 2012
      • 4734
      Can you tell me why the PicKit3 is a better choice over the ICD 3? From what I've read, spec wise, the ICD 3 seems to be a superior system in most ways. The PicKit3 seems to be "open hardware". I do like open hardware, however, I see the PicKit3 is full speed USB while the ICD 3 is high speed. Does this really make a difference? I'm guessing I'm going to be making a lot of mistakes and needing to reflash the microcontroller many times.
      In-circuit debugging is nice as well. Is the ICD 3 truly faster? Just because it has a faster interface, am I ever going to notice it? You know, one of those, if my car can only go 20 MPH, even if the speed limit changes from 30 to 65, I'm still only going to be going 20 MPH kinda things.
      Could you tell me why the PicKit3 is the way to go? Is it just personal preference Stj? Have you used both of them? Thanks!
        • 31091
        i dont know about icd3, but i know the pickit3 is directly supported by mplab-x
        i also know that it uploads a fiie into the programmer for the device you want to work on, so if new devices come out the programming hardware shouldnt need updating.
        i also like stuff that's open and cheap.
        so i have one of these.
        http://www.ebay.co.uk/itm/261574745774
        • LDSisHere
          • May 2012
          • 727
          • U.S.A.
          If you are into DIY and want something more universal I would recommend the Open Programmer. It does PICs, Atmel, SPI, I2C, and more. It is also completely open source and does have ICD. (I have never used the ICD.) The real drawbacks are that you would have to build it yourself, and it is not directly supported from MPLab.
          http://openprog.altervista.org/OP_eng.html
          http://sourceforge.net/projects/openprogrammer/
          • Spork Schivago
            • Mar 2012
            • 4734
            Damn, I can't seem to get the pics you uploaded to load. Maybe they're at the end of those links? I'll check them out and see if I can find them.
            • Spork Schivago
              • Mar 2012
              • 4734
              Hey Stj,
              How easy is it to use one of those PicKit3's to extract the hex file from a programmed PIC (if it doesn't have security bits active or whatever they call it)? Do you have to leave the chip soldered in and hook to the pins if there's no schematics available? Can you just desolder the chip and plop it in the PicKit3 or do you need to buy some sort of ZIF attachment? I'd like to stay away from clones. If a small increase in speed is all I'm going to get for 150$, I might just buy one of the PicKit3's.
              • Spork Schivago
                • Mar 2012
                • 4734
                I am into DIY but right now, I just don't really have the time. I'd imagine because the PicKit3 is open hardware, the MPLab would be open sourceware and there'd be a Linux version available. I really like the Linux compatible stuff. The only PC in the work room (the only working PC at least) is a Linux box. It's my main machine.
                  • 31091
                  to read an unprotected pic you need about 5 wires.
                  it's often easier to solder some wires to the target than lift the chip.
                  i'v had to do this a few times wih both pic and avr to upgrade firmware on obd2 interfaces.
                  • STKR123
                    The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                    by STKR123
                    Greetings badcaps community,
                    I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                    So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                    Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                    I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                    These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                    I learned that desoldering...
                    10-29-2024, 06:03 AM
                  • dicky96
                    CH341 Programmer - any good for 1.8V?
                    by dicky96
                    Hi guys
                    I have a TL866 CS Eprom programmer and up until now it did everything I needed to do
                    However for the first time I have come across a 1.8V Eprom and my programmer will not do 1.8V
                    I need to program a 25Q64FWTG
                    I could splash the cash and buy a V11.71 TL866II. These come with various attachments and the kit including a 1.8V adapter is either €62 with 12 adapters or €68 with 1 7adapters. I also have the option to buy just the programmer for €46.70, if I could get the 1.8V adapter separately and use the other eprom adapters from...
                    01-31-2022, 06:14 AM
                  • Teeheeze
                    RT809H Programmer Firmware Corrupted
                    by Teeheeze
                    This is a shot in the dark, but I was just using my RT809H programmer and it got stuck in a certain state so I power cycled it. Now, the device LED just flashes quickly and does not connect to the software. I've tried to update the BIOS of it and it fails. I went so far as to remove the ROM from the programmer itself but it's some weird chip (I believe ATMEL, but I can't find any datasheet on it) so I've been unable to read the BIN from it w/ my other programmer. Chip has ATMLHC4C56BM CN written on it (I think). I'll upload an image. I have the programmer's BIN ready to program it manually. Anyone...
                    02-13-2025, 04:51 PM
                  • irepair559
                    Ps4 1215a hdmi diode readings good everything good but no pic??
                    by irepair559
                    PS4 1215A HDMI DIODE READINGS GOOD EVERYTHING GOOD BUT NO PIC? everything is good! what else can it be? if hdmi diode values are good that means encoder and filters are good right? idk what else it can be guys...
                    01-05-2023, 12:32 AM
                  • Mgiffune
                    by Mgiffune
                    06-09-2024, 10:28 AM
