Bob Parker's Blue ESR Meter Assembly & Comments
  • Agent24
    I see dead caps
    • Oct 2007
    • 4950
    • New Zealand
    #41
    Re: Bob Parker's Blue ESR Meter Assembly & Comments
    Originally posted by Moody
    hi can someone show me a completed circuit board of the blue esr meter when assembled and working
    There are pictures of assembled meters in this thread somewhere, IIRC. What do you want to know?
    -David VanHorn
    • Bob Parker
      Technician
      • Feb 2007
      • 182
      This is my "master" photo.
      It is a good shrubbery. I like the laurels particularly...
      • chth96
        by chth96
        03-09-2024, 10:03 PM
        12-31-2023, 06:04 AM
      • jorpec
        by jorpec
        Hi
        Thnaks
        01-23-2023, 10:37 AM
        Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
        12-14-2023, 07:45 PM
      • Stephan Mathers
        EDMI ATLAS MK10 Electronic Meter Discussion
        by Stephan Mathers
        Greetings, new guy here but always interested in the crazy universe of modding
        We just finished construction of around 25 vacation houses, all inside the same private area.
        Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
        The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
        Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...
        05-20-2025, 09:09 AM
