Agilent power supply
  • ricosavy
    • Jul 2012
    • 457
    • united states
    My brother gave me this power supply what guys think about it.
    Re: Agilent power supply
    That is a keeper, it is not cheap stuff. You should download the user/service manual.
    http://www.keysight.com/en/pd-838240...a?cc=US&lc=eng
    http://www.ebay.com/sch/i.html?_from...3610A&_sacat=0
    • retiredcaps
      • Apr 2010
      • 9271
      I don't have one, but the HP power supplies are held in very high regard by eevblog members. Dave did a video on it.
      https://www.youtube.com/watch?v=-04CQ0Mug1o
      --- begin sig file ---
      --- end sig file ---
        I have HP E3617A more than 10 years, built like a tank.
        Happy New Year Retiredcaps.
        • retiredcaps
          • Apr 2010
          • 9271
          Happy New Year budm. It just turned 12:01AM as I saw your message.
          I'm just re-watching Dave's video and think I see Nichicon capacitors in the PS. It looks pretty well built inside.
          • CapLeaker
            Leaking Member
            • 8158
            That's a keeper.
              You can use it to power up the main board and check the current draw, and to find out if it is sending the PS_ON, BL_ON, etc without the power supply board (unless the main board needs the AC OK or other error feedback signals).
              • ricosavy
                • Jul 2012
                • 457
                • united states
                That sound great i will play with it.i have main board that has problem maybe i can figure out.
                • retiredcaps
                  • Apr 2010
                  • 9271
                  Like any tool, you should test it out and make sure it works on stuff you don't care about.
                  It is easy to provide too much voltage or current if you don't know what you are doing and ruin the main board with too much of either.
                  • Longbow
                    • Jun 2011
                    • 623
                    Personally I don't like this line of supplies because they do not have a current crowbar. Anything that puts out d.c. and has metering does the job, but must have an adjustable current crowbar to protect the stuff you are testing.
                    Is it plugged in?
                    • ricosavy
                      • Jul 2012
                      • 457
                      • united states
                      No it is not plugged in
                        by sam_sam_sam
                        03-31-2024, 02:12 PM
                        by sam_sam_sam
                        07-01-2024, 06:34 AM
                      • JimBanville
                        Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                        by JimBanville
                        The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                        Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                        I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                        I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                        09-13-2023, 07:21 AM
                      • CMCM
                        Russound CA4 Power Supply Repair
                        by CMCM
                        Hello Everybody,
                        Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                        Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                        The outputs marked 12v and 20v are all measuring only 1v.
                        The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                        The capacitors physically look clean (no bludgesor leaks) and...
                        07-03-2025, 01:12 PM
